Engine mounting bolts & crash bungs
Golfingbiker
PostPosted: 23:07 - 04 Jan 2017    Post subject: Engine mounting bolts & crash bungs Reply with quote
Hi just joined the forum & im hoping someone can help me out
I've tried to replace the crash bungs on my winter bike (hornet 600) & as I've removed the bolt the bike has moved on the jack I was using,which means the engine mount bolt will not thread through,so I can't replace the engine mounting bolt,I need to lift the engine approx 4mm to align the holes
Sorry if this has been asked before & hope I can get some advice on how to solve this problem.
Many thanks in advance
Pete.
PostPosted: 00:41 - 05 Jan 2017    Post subject: Reply with quote
It's normal to have to lever an engine about when fitting it. If it won't move easily you might have to loosen some of the other mounts a bit to gain a bit of movement.
Make sure that you do have the original engine bolt, they are usually fine thread so a standard thread bolt won't do.
a.k.a 'Geri'
Golfingbiker
PostPosted: 09:56 - 05 Jan 2017    Post subject: Reply with quote
Thanks I'll try loosening the other bolts to see if that'll do the job.
recman
PostPosted: 19:26 - 05 Jan 2017    Post subject: Reply with quote
What's your summer bike?
Golfingbiker
PostPosted: 23:09 - 05 Jan 2017    Post subject: Reply with quote
Hi I've just traded my summer bike in & have ordered a 2017 fireblade which is expected march time
The last post was made 9 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 42.77 Kb
