| Gazdaman |
 Gazdaman I did a trackday!!!
| Scooby |
 Scooby Scrappy Doo
| Kickstart |
 Kickstart The Oracle
| stinkwheel |
 Posted: 01:58 - 01 Mar 2005 Post subject: |
I agree BT45 are good tyres, dual compound so they last but are sticky enough to throw about. They get a little twitchy after about 100 miles then quickly settle down again after another 50 miles when you put them on a GPZ500s. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Gazdaman |
| mr motorbiker |
 mr motorbiker Nova Slayer
| Gazdaman |
| Kickstart |
 Posted: 19:30 - 01 Mar 2005 Post subject: |
With a 140/70 HR 18, the 140 is the width in mm, the 70 is the profile (depth) as a percentage of the width, the H is the speed rating, the R is for radial and the 18 is the rim size it fits in inches.
Sticking a 140 on a rim sized for a 110 tyre would probably give you fairly hideous handling. You would probably be OK on a 120 and maybe even a 130 but a 140 tyre is 3cm wider than the stock tyre. That extra size will result in the tyre being quite deformed to fit.
Realistically a 110/70 would probably have a 3" rim while a 140/60 (as close to the same outside diameter as is readily available) is designed for a 4" rim.
| hawkeye |
 hawkeye Nova Slayer
| hawkeye |
 hawkeye Nova Slayer
| stinkwheel |
 Posted: 19:40 - 01 Mar 2005 Post subject: |
140 is quite a lot wider than 110 (IIRC it referrs to the width of the tyre in mm). It would muck up the handling and may not even fit on the rim. There is no need to fit a wider than standard tyre unless you are suffering from loss of traction under power (unlikley on an XJ600)
Bridgestone recommends (from their own website): ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Gazdaman |
| Kickstart |
The last post was made 21 years, 231 days ago. Instead of replying here, would creating a new thread be more useful? |
