Keeping my bike outside all year.
Colinzor
PostPosted: 21:42 - 06 Jan 2017    Post subject: Keeping my bike outside all year. Reply with quote
Hi all. i know this topic has been talked to death and there is alot of advice online but the consensus seems to be if you leave a bike outside its done in a couple of years? so i thought id ask directly.
So i have just bought my new Kawasaki Z750 04 model off a friend of mine, after my last bike this is like new to me, kept really well and looked after bar some minor servicing and a few bits here and there. I love it so much im trying to look after this as best i can, im really afraid of it getting ruined by me leaving it outside.
As it stands at the minute i live at home and i do have room for a shed but currently selling the house in 6 months and i may be moving out on my own to a flat so i wont have anywhere for a shed to go, at the moment the bike is kept under a basic bike cover i bought off amazon, does the job to keep it dry enough i think. i ride all year but it is not my main transport i also have a car, i rinse the bike with a hose after every outing once cool and a soap wash once a week with some cheap supermarket shower gel (im told fairy liquid has salt or corrosive chemicals in it?) then i leave it and try to dry i with a towel when i can espeically around the metal then back under the cover.
i borrowed some ACF50 from a friend to put on the metal, i havnt had a chance to do this yet but im hopign this should keep it good until summer ? any more advice would be appreciated as i genuinely love this bike and im trying to keep it as best i can.
Thank you!
CBR 125R 05 (Sold) | GSX 750F 1996 (Sold) | Kawasaki z750 2004
M.C
PostPosted: 21:58 - 06 Jan 2017    Post subject: Reply with quote
It's not done within a couple of years but you do definitely see the start of rust. ACF50 + a cover helps.
Poundshop Dave This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
pepperami
PostPosted: 23:22 - 06 Jan 2017    Post subject: Reply with quote
Wash your bike and then get all the water out of those hard to get to places with one of these Thumbs Up
https://www.ebay.co.uk/itm/2800W-Electric-Garden-Leaf-Vacuum-Blower-/122294483606?hash=item1c7951ba96:g:H4cAAOSwA3dYaVUi
It`s what I do Smile
Colinzor
PostPosted: 23:27 - 06 Jan 2017    Post subject: Reply with quote
Thanks for the suggestions, saying dont ride your bike in winter but i bought it to ride i usually go out for a couple of hours once a week or so, would like to continue to do so, i try to dry around the engine as much as i can, do these bike shelters really work as suggested above?
i always thought they wouldnt heat up much being exposed to the cold ground underneath, basically a fancy bike cover, am i wrong about this?
so far
1. rinse after a run and dry off what i can
2.wash with soapy cold water once a week and left to dry or hand dried with towel
3. some acf 50 around the metal (not brakes)
am i doing the best i can? as said lack of funds and lack of room stop me from having a shed atm Smile
thanks !
NJD
PostPosted: 23:59 - 06 Jan 2017    Post subject: Reply with quote
Sounds like your making things more complicated than they need to be.
Accept the fact it's kept outside and that's that one sorted. Ensure your cover has a clip that goes underneath so it doesn't blow away in the wind and that's as good as it gets, some covers perform better than others.
What's with all this washing nonsense? Balls to standing out in the cold, the pre-ride routine's long enough without adding cleaning it down after a run to the list. Only time I bother is when I've ridden on gritted roads and even then it's only a quick wipe of the downpipes or, when needed, some brake cleaner on the discs. Only other one to keep on top of is lubing the chain.
Go make your bike spotless and then coat the thing in ACF-50 and leave it for approx. 24 hours and then don't worry about washing it, unless ridden on gritted roads, until post winter. It's common sense, not on the tyres, rubber parts or near the brake discs + calipers and you'll be fine. Give the parts at the underside of the bike, the ones that will get the most abuse, some attention and then work your way up.
result = shiny bike:
https://s28.postimg.org/frf7kanot/IMG_4083.jpg
Robby
Dirty Old Man
PostPosted: 00:00 - 07 Jan 2017    Post subject: Reply with quote
Salt makes it rust. Rain won't have much effect.
It might rust a bit more from being outside, but only surface rust on the bits that usually go a bit rusty. It isn't going to dissolve, and the surface rust isn't going to affect anything important.
Suntan Sid
PostPosted: 01:09 - 07 Jan 2017    Post subject: Reply with quote
Before taking my 2006 FZ1-N to warmer climes, it was kept outside for three years. The only protection it had was a "Stormex" cover, no magic sprays were applied, it got washed and waxed 3 times a year, if it was lucky, the bike was 8 years old when I got it.
The only sign of corrosion, after 3 years, is a very, very, small bit of rust on the gear pedal.
I will say that the cover was held on to the bike via a strap underneath, but was quite a loose fit which allowed the wind to circulate around the bike and, IMO, kept the moisture at bay!
Bear in mind this was in the Peak District, probably one the wettest, miserable, sunless, parts of the UK!
thx1138
PostPosted: 01:34 - 07 Jan 2017    Post subject: Reply with quote
All of my bikes have been kept outside since I started riding bikes in the 80s, they didn't die, sure my bikes are not always super shiny, but they never fell to bits.
Longest I've ever kept a bike was my Fazer thousand which I had for 4 and a half years.
M.C
PostPosted: 01:54 - 07 Jan 2017    Post subject: Reply with quote
I've noticed bits going rusty over the spring/summer months, and the roads aren't exactly caked in salt during the winter months round my way.
Dave70
PostPosted: 10:36 - 07 Jan 2017    Post subject: Reply with quote
I like this idea, I think. Thinking
pepperami
PostPosted: 11:03 - 07 Jan 2017    Post subject: Reply with quote
I`ve been using one of those for years to blow the wet out of all those nooks and crannies on a bike where water can hide/rust.
I used to use a compressed air line, but found that they could be a bit destructive.
These blowers don`t destroy but are still strong enough to get rid of wet/water
Works for me Thumbs Up wouldn`t be without it now.
recman
PostPosted: 11:50 - 07 Jan 2017    Post subject: Reply with quote
I've been doing this ever since I saw the acf50 blokes doing it.
I recomend attacking the radiator first, the amount of water that you blow out of there is extraordinary.
stevo as b4
PostPosted: 14:51 - 07 Jan 2017    Post subject: Reply with quote
I had a few zinc plated fasteners start to fur up and rust on the KMX after last winter in the shed. Its condensation that's the evil bastard IMO. I've since either painted over the plating, or got new bolts or where needed.
Keeping your bike under an open lean to or under a canopy or gazebo etc with the tyres on blocks or on a surface like a grate drain mesh where the water runs away is probably better than locking it in a shed that isn't well vented and has wide temperature variations like most wooden or glass buildings do.
I like the thought of keeping a bike out of torrential rain as much as possible, but anything in between say under a canopy or cover and keeping it at room temperature in a dry moisture free environment is doing it more harm than good IMO.
I might put heating and an extractor fan in my shed this year if I can be bothered to go that far with extra wiring and complication?
chickenstrip
PostPosted: 14:53 - 07 Jan 2017    Post subject: Reply with quote
NJD wrote:
Dirt on the rear brake reservoir cap...your weekend pass is cancelled! Laughing
Falco
PostPosted: 16:41 - 07 Jan 2017    Post subject: Reply with quote
Mad By the gods, I'll not have you disparage the Peak District like that. Why, one of my happiest memories is being crouched under the bike cover in the freezing cold and pissing rain, replacing the alternator cover as it hadn't stopped raining for the entire weekend long enough for me to do it.....Shifty
Condensation has been mentioned and I think it's worth considering. I have a stormex cover with a fleecy inside (supposedly to stop the paint getting scratched) stops the worst of the condensation that forms on the inside of a plastic cover.
Freddyfruitba...
PostPosted: 18:22 - 07 Jan 2017    Post subject: Reply with quote
Is a bog standard Flymo-style leaf-blower adequate for the job or do you need a high-end/high-power one, which is what that ebay link looks like ( I think?)
Colinzor
PostPosted: 20:34 - 07 Jan 2017    Post subject: Reply with quote
really liked this post thanks mate, made me feel a little less guilty about lol. at current im using this as a cover, does the job keeps the bike fairly dry although one of the straps did rip with the wind since i live up high and we did catch the tail end of a hurricane a couple of weeks ago.
https://www.amazon.co.uk/Motorcycle-Waterproof-Motorbike-Protective-Breathable/dp/B007VM4U2Y/ref=sr_1_3?ie=UTF8&qid=1483817588&sr=8-3&keywords=motorbike+cover
gonna get it washed tomorrow and put on some acf 50, that will do the job and perhaps a better cover when i get some cash up.
thanks !
recman
PostPosted: 20:58 - 07 Jan 2017    Post subject: Reply with quote
You'd be surprise how powerful a bog standard leaf blower is, more than adequate to do what you want.
Mine is an old cheap B&Q own brand job inherited from my old man, 1800w I believe.
Suntan Sid
PostPosted: 23:54 - 07 Jan 2017    Post subject: Reply with quote
So, JivebunnyMilfHunterBodyGuard929FirebladeGod.iSocketBikeDoctor007AloysiusParker, or whatever, moronic, name you're hiding behind now, what, exactly do you disagree with in my post, or am I just a liar?
Or is it just one of you're usual, tedious, random down ratings?
While we're here, here's some previous words from you, lest we forget what an utter bellend you really are:-
JivebunnyMilfHunterBodyGuard929FirebladeGod.iSocketBikeDoctor007AloysiusParker wrote:
Do you want the black slapping off your face you ni%%er cunt?
Oh look another thick ni%%er cunt.
I like the fact so many people are getting offended. I wonder how many ni%%er eyes are in this thread.
Roses are red,
Violets are blue,
Ni%%ers are black,
You know that's true.
Big lips and kinky hair,
Living off that ol' welfare.
Hope that's jogged your memory, you wrote it, you're so big and clever! Rolling Eyes Hopefully it'll catch up with you one day and bite you in the arse, you odious little shit!
See the 8th post down for the un-redacted quote:-
https://www.bikechatforums.com/viewtopic.php?t=315756&start=100
HTH!
You're a, selfish, witless, charmless, shit stirring, racist, moron!
You're parents must be so proud of you! Rolling Eyes Middle Finger
pepperami
PostPosted: 13:23 - 08 Jan 2017    Post subject: Reply with quote
A bog standard Flymo blower will be fine Thumbs Up
Colinzor
PostPosted: 00:33 - 09 Jan 2017    Post subject: Reply with quote
do these leaf blowers work that good even for a bike thats outside? jsut blow dry around the engine, metal and put the cover back over it after a rinse or a soap wash ?
recman
PostPosted: 19:54 - 09 Jan 2017    Post subject: Reply with quote
Not sure I follow.
Leaf blowers will dry/blow the water out of the nooks and crannies of your bike after a wash.
If you want outside storage corrosion protection, acf50.
The last post was made 9 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 136.44 Kb
