| lynnnsr |
 lynnnsr Nova Slayer
 Posted: 15:38 - 09 Jan 2017 Post subject: Rusty chain is it finished? |
I last rode my bike about a month ago. It's a 16 plate CB650F which I've had from new last summer. It's now done the grand total of 2,000 miles.
last time I went out it got absolutely filthy from a week's commuting, general road dirt more than anything else but I was not aware that any salt gritters had been out as it has not been that cold.
Anyway went to ride it this morning, front wheel won't turn, battery flat, a good bit of corrosion on the aluminium footpeg brackets and and the chain red with rust!
I am quite ashamed that I put it away in the garage in such a state and just left it dirty, but would we expect this level of corrosion to happen on a new bike? I freely admit to leaving the bike filthy, but I was a bit surprised by the impact it had had.
Most of all, though, I'm a bit worried about the chain, will it sort itself out with oil and use or am I going to have to replace it? I can still wheel the bike about in neutral easily enough. ____________________ NSR 125 (with L-Plates) > 1994 NTV 650 > 2015 CB650F > 16 VFR800F |
| MarJay |
 MarJay But it's British!
| andi |
 andi Crazy Courier
| Azoth |
 Azoth Brolly Dolly
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
| bigdom86 |
 bigdom86 Traffic Copper
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:13 - 09 Jan 2017 Post subject: |
Modern Honda aren't immune to tin worm.
Don't fret about the chain and ignore any doom merchants. The chain on my GPZ hadn't moved in years when I got it, and I've had stiff links on other chains: they all came good with some TLC.
Clean and oil it, then check for seized links. Rotate the wheel and see if any stand proud as they go round the sprocket or don't fall in line as they come off.
If you have any, work them free by wiggling with two pairs of pliers. No need to be gentle, if you can't free them up then the chain is toast.
If you still have a stiffie, give it a good thorough soak with oil. Ideally, get the chain off the sprocket and lying in a bath of oil.
It's probably an O or X ring chain but if you have lost any rings, just treat it as a prolespec chain and lube it more often. If I'd listened to the naysayers, I'd have binned my Nazi Tractor chain thousands of miles ago - it's still usefully in service, popped rings and all. ____________________ Biking is 1/20th as dangerous as horse riding.
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| lynnnsr |
 lynnnsr Nova Slayer
| Beehive Bedlam |
| Beehive Bedlam |
| Hong Kong Phooey |
| Kickstart |
 Kickstart The Oracle
 Posted: 20:39 - 09 Jan 2017 Post subject: |
Surface rust on the chain I wouldn't worry about. Pretty much zero chance it will affect the strength of the chain. Might damage the O rings but probably enough oil where they touch for there to be no corrosion there.
Tooth brush and some oil will clean it up probably.
If the O rings have gone then I would be far more dubious using the chain for any length of time
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Moo. |
 Moo. World Chat Champion
| Waaarrrggghhh |
 Waaarrrggghhh Nitrous Nuisance
| Doink |
 Doink Nitrous Nuisance
| ZX-7R |
 ZX-7R Banned
| Matt B |
 Matt B World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:32 - 11 Jan 2017 Post subject: |
| Matt B wrote: | So, grind the ends of the pins down, get a chain splitter and press a link out, buy a new link, after cleaning it fit the new link and correctly rivet the pins.
Seems like an immense amount of effort just to clean a chain. |
Commentard has a YBR125, perhaps assumes all bikes have a clippy-chain. ____________________ Biking is 1/20th as dangerous as horse riding.
| lynnnsr |
 lynnnsr Nova Slayer
| talkToTheHat |
 talkToTheHat World Chat Champion
The last post was made 9 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
