VPN Help
PostPosted: 15:45 - 09 Jan 2017    Post subject: VPN Help Reply with quote
I'm setting up a VPN, it connects but I can't get network/internet access.
I've set it up on a machine running Windows Server 2012.
I've installed the role and service.
I've set the user accounts to allow dial in.
I've opened port 1723 on my server and forwarded the port firewall to my server (static ip).
I set my phone to log into the VPN and it connects successfully. But I have not local/internet access.
I'm guessing I've overlooked something, I thinking I've set up a VPN to the server and I need to forward the connection to the local network.
Can someone point me in the right direction?
Cheers,
Chris
mudcow007
PostPosted: 09:59 - 10 Jan 2017    Post subject: Reply with quote
what is giving the ip to the vpn client?
have you checked routing etc?
What is the doing the vpn'ing?
owl
PostPosted: 10:10 - 10 Jan 2017    Post subject: Reply with quote
usually routing or dns, try reaching something external via IP, should narrow it down
Observation is the greatest source of wisdom.
Jayy
Mr. Ponzi
PostPosted: 18:32 - 10 Jan 2017    Post subject: Reply with quote
Network can confuse the hell out of me but when I had one with a company a while back, it would connect but no internet either. Turned out to be ipv6 and my shit was using ipv4.
Not sure if that is of any help but there you go Laughing
PostPosted: 12:54 - 11 Jan 2017    Post subject: Reply with quote
Is the fixed address of my Router which is then forwarded to the server, it's the same IP I RD toto access the server
What do you mean what is doing the VPNing?
mudcow007
PostPosted: 13:43 - 11 Jan 2017    Post subject: Reply with quote
Is what ever your using to "tunnel in" with, getting an IP address?
Usual the VPN server will have an allocated list of IPs to give out to VPN clients.
have a look in DHCP to see if you can spot your phone
Is the VPN software on your phone able to report back any configs etc? or is it simply a username, password and host setup?
Loui5D
PostPosted: 14:45 - 11 Jan 2017    Post subject: Reply with quote
+1 for tunnelling.
What vpn client are you using? Built in windows or a Cisco one?
PostPosted: 15:23 - 11 Jan 2017    Post subject: Reply with quote
Built in Windows on the server side and it is a built in option on the android side.
mudcow007
PostPosted: 19:47 - 11 Jan 2017    Post subject: Reply with quote
Just because you are connected to server side doesn't mean you have an IP.
I would look there first.
Then its routing/ possibly what permissions on server side
checked this?
PostPosted: 13:07 - 13 Jan 2017    Post subject: Reply with quote
checked this?
I changed from DCHP to Static Pool and now have a local IP, I can Access my FTP server using the hostname and I have net access. Wicked cheers. Laughing
The last post was made 9 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 64.5 Kb
