Should i let my bike warm up it self or ride it straight awa
ko5i
PostPosted: 11:51 - 25 Jan 2017    Post subject: Should i let my bike warm up it self or ride it straight awa Reply with quote
Hi all.
Before i was told not to ride a cold bike and let it warm up.
So i was always starting the bike and let it warm up for about 2 min until the temperature is no longer ''low''
But now i read that you should wait 5-10 seconds for some oil flow and then you shouldn't just wait and let it warm up it self but just ride [not reving high] and warm up by riding ?
So whats the best ? and why ?
Thanks !
PostPosted: 11:54 - 25 Jan 2017    Post subject: Reply with quote
Ride it normally. Don't labour the engine until it's up to temperature.
tom_e
PostPosted: 12:12 - 25 Jan 2017    Post subject: Reply with quote
Start it up, let fast idle drop which is about the time it takes me to sit on it and drop it into gear, ride, don't spank it's arse too hard until it's at a reasonable temperature.
ko5i
PostPosted: 12:13 - 25 Jan 2017    Post subject: Reply with quote
ok thanks , i was always waiting for it to warm up it self before riding for about some time so now i will just ride it
PostPosted: 12:30 - 25 Jan 2017    Post subject: Reply with quote
Depends on the bike.
YBR - press button, ride off.
Enfield - start, wait until idle settles. Usually under 2 minutes.
In both cases they don't get thrashed until I've done a few miles.
andyscooter
PostPosted: 12:44 - 25 Jan 2017    Post subject: Reply with quote
My wnfield is kickstart for a bit
Get hot
Take jacket off
Wait and repeat 😁
It mot day tomorrow
yen_powell
PostPosted: 12:52 - 25 Jan 2017    Post subject: Reply with quote
I've been round the clock mileage wise on bikes I would start and ride straight off. Just take it steady for a little while.
XT1200Z and a DR350 in bits
Kawasaki Jimbo
PostPosted: 12:57 - 25 Jan 2017    Post subject: Reply with quote
This, and a similar recent thread, has been enlightening. With the exception of my first bike (Yamaha XJR400) which would bog down if not driven off almost immediately, I've always followed the received wisdom of the day and warmed my bikes up until they come off choke/fast idle. Allowing the idle to settle makes the bike easier to ride, and I'll keep doing it for that reason. However it sounds as though the "warming the oil" argument is bogus.
The warming idea might have come from aero engines where the engine needs to be at full power for take off, whereas as tom_e said, "don't spank [the bike's] arse too hard until it's at a reasonable temperature."
PostPosted: 13:30 - 25 Jan 2017    Post subject: Reply with quote
The 'warming up' came from 70's/80's strokers. People used to jump on them, give it beans and fuck the engine.
I always used to start my bikes and let them warm up while I put on my jacket and helmet and it's become a habit I still do.
I'm sure with modern machinery it really makes no odds as long as you are gentle with the engine until it's up to temperature but I'll stick with warming mine up a bit first.
Who warms up cars first? I don't. Mind you, I don't do much else to them either. Oil? pah Embarassed
Triumph Trophy Launch Edition
kgm
PostPosted: 14:07 - 25 Jan 2017    Post subject: Reply with quote
With my carbed bikes take it off choke and let it sit for a short time a minute or two) otherwise they bog a little initially.
With my FI bikes, as others, I wait until it comes off fast idle because, as mentioned, it makes it easier to ride as I'm not having to feather the clutch so much. Usually this just means starting it, sticking helmet and gloves on, then riding off. Not totally necessary but as I said - nicer to ride.
Jimbo - indeed; it was a good 5 minutes or so until my microlight was ready for taxi - warm until oil temp was about 50degC if I remember correctly. Reduces the risk of a stoppage as you're immediately hitting full throttle when on the runway.
ko5i
PostPosted: 15:22 - 25 Jan 2017    Post subject: Reply with quote
So basically it hasn't been said a clear answer like to this because it will damage this or do this because it wont damage this or that.
Basically people warm up bikes differently up to their preferences.
What i used to do i mean i still do it since beginning turn the engine on and let it idle for the time i put my gloves neck warmer and a helmet on and fix my pants too and back pack and then it just goes from low to 43C and i just ride of but i always wait for it to change from low.
Formerly known as
P.
PostPosted: 15:35 - 25 Jan 2017    Post subject: Reply with quote
Start bike, put gloves on and leave.
I pretty much climb on mine, unlock steering, start it, walk it backwards out of the gate and ride off. No real hard riding until its sitting in the 70-80 degree range, when riding thats only a few mins.
PostPosted: 15:55 - 25 Jan 2017    Post subject: Reply with quote
And that is fine Thumbs Up
Commuter_Tim
PostPosted: 20:18 - 25 Jan 2017    Post subject: Reply with quote
The arguements over warming a bike always remind of the disagreements about running a new bike in...
Anyway just how do you run in a new bike?
Rag it from ignition or let it settle first? Whistle Pass the popcorn
I ride a Bandit 600... badly.
PostPosted: 23:41 - 25 Jan 2017    Post subject: Reply with quote
Pretty much always just start and ride off asap (just take it easy for a while). Oil will get around rapidly, but it will take ages for the engine to warm up at idle and the longer it is cold / on choke the worse.
Very few bikes I have had have been that nasty when cold. Bandit is a bit with the slide carbs if the road baffle is in the exhaust.
Major exception is when it is nobbin cold and I want the heated grips to warm up Laughing
Katy
mudcow007
PostPosted: 09:36 - 26 Jan 2017    Post subject: Reply with quote
My take on all of this is...
Start bike (bandit) with full choke, it will idle fast - back this down a touch with the choke
Put gloves on & ride away. every set of lights etc i knock the choke down a bit
Does anyone let a bike "cool down" before turning it off? My neighbour had a ER5 which he just let it sit idling after a ride to "let it cool down Shocked
Conzar
PostPosted: 09:44 - 26 Jan 2017    Post subject: Reply with quote
Cooling down is only really for turbo'd engines after being driven hard
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
davethekwak
PostPosted: 10:14 - 26 Jan 2017    Post subject: Reply with quote
All engines have an ideal (designed) operating temp range. This is the temp where all the components of the engine have expanded to designed tolerances. Oil also has a best operating temp range.
The above would suggest letting engine warm up to be best practice.
BUT
Modern engines do not function well without any load and have a tendency to glaze the bores which goes against the let it warm up idea.
Net result is you need to compromise. Engine needs to have oil circulating but that only takes a few seconds. After that you should be riding the bike to put some load on the engine but not extreme load. I work on a simple max of 40% revs and slower opening of the throttle until all is up to temp.
Above applies to petrol engines, diesels are a whole different kettle of fish
Copycat73
PostPosted: 10:16 - 26 Jan 2017    Post subject: Reply with quote
two or three minutes idle while I set the sat-nav ..brake light & headlight .. lid & gloves ..
because I get a better throttle response ..particularly the ZZR14 ..
and loading a cold engine is not good for it ...
caveat emptor
chickenstrip
PostPosted: 10:26 - 26 Jan 2017    Post subject: Reply with quote
Fazer 1000. (carbs) Start bike. No choke needed cos Ivanised Mr. Green Pull on lid and gloves. Ride off. By the time I get to roads on which I want to have some fun, it'll be warm - 2-3 miles.
Striple. (injection) Start bike. Pull on lid and gloves. Ride. Same as above: 2-3 miles and it's ready to thrash.
chickenstrip
PostPosted: 10:47 - 26 Jan 2017    Post subject: Reply with quote
Yeah, this is something I first heard about after running mine for many thousands of miles. I was told (or read, can't remember the source now) that the reason for this is that the oil in the turbo unit gets to very high temperatures (the unit on mine used to actually glow bright red after thrashing, don't know if this is common to all, but would imagine so), and sudden, rapid cooling caused the oil to crystallise on the bearing surfaces, which would damage the surfaces (on restarting? again, not sure, I'd like to know the real reasons for all of this). I figure I got away with it for so long because I always had to ride home through a last bit of residential area where my speeds were low.
Question
davethekwak
PostPosted: 11:12 - 26 Jan 2017    Post subject: Reply with quote
Turbos are cooled by a flow of oil over the bearing which are at the center of the turbo. This keeps the bearings at a lower temp than the rest of the turbo and the constant cycling of the oil over the bearings and through the oil cooler keeps the oil with its operating temp range.
Now if you raz the bike you heat the outer components of the turbo, bearings and oil remain at reasonably constant temp. If the bike is allowed to cool with engine running then the outside of the turbo cools whilst the bearings are stilled cooled by a flow of oil. If you just shut off the engine the oil flow stops but the heat of the outer components now starts to increase the temp of the bearings and the now static oil coating them.
It is this significant increase in temp that cooks the oil on to the bearing.
Next start up the bearing ain't working so well. If this continues eventually the bearing will seize.
chickenstrip
PostPosted: 11:41 - 26 Jan 2017    Post subject: Reply with quote
Best and most logical sounding explanation I've heard yet. Thanks.
kramdra
PostPosted: 10:59 - 28 Jan 2017    Post subject: Reply with quote
If your not moving its just wasting fuel, a big difference to mpg.
Copycat73
PostPosted: 16:47 - 28 Jan 2017    Post subject: Reply with quote
if your worried about mpg get a fiat panda diesel .. 75mpg..
caveat emptor
The last post was made 9 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 134.92 Kb
