| kgm |
 kgm World Chat Champion
| MarJay |
 MarJay But it's British!
| pompousporcup... |
 pompousporcup... World Chat Champion
 Posted: 14:53 - 25 Jan 2017 Post subject: |
make your own, like i did works damn well too
you will need:
1x scottoiler hose
https://www.ebay.co.uk/itm/Scottoiler-Conveyor-hose-incl-Nozzle-SA-0028-/391643368782?hash=item5b2fc38d4e:g:tcEAAOSwiONYQVIj
1x lawn mower primer bulb
1x spare brake fluid reservoir
100000x cable ties
there were some little things like adapters to link hoses together and a bit of superglue to add to the hose to make 100% sure it wont come off the primer bulb if the hose is caught accidentally.
6k miles or so and mine is still going strong Cost me roughly £30 to make with enough bits to repair it if it went wrong. |
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Pigeon |
 Pigeon World Chat Champion
 Posted: 20:04 - 25 Jan 2017 Post subject: |
I have a Loobman on one bike and a DIY affair on the other. Both were about £20. Neither is perfect.
Loobman is a good shout. It's cheap and works, just not without limitations.
It's manual, you have to hold the button down.
The reservoir is quite small (circa 500 miles worth). The flow of oil is gravity fed, so the run rate is affected by the type of oil you use and the ambient temperature. But its £20 and an electronic pump Scotoiler is £200, so...
I recommend buying a £1.50 aquarium flow control valve so you can fine tune the flow delivery.
I also put a hole in the rubber button and attached a long cable tie in a loop, so I can force the button to be held down by hooking the cable tie loop under the base of the reservoir for 2 mins while riding and avoid riding one handed, and avoid standing waiting with the button pressed.
Only downside is, have occasionally forgotten to release the button again and essentially hosed the rear tyre and anyone behind me.  |
| Pete. |
 Pete. Super Spammer
 Posted: 20:16 - 25 Jan 2017 Post subject: |
I've got the working parts of an old scotoiler on the shelf. Send me your address and you can have it. ____________________ a.k.a 'Geri'
| kramdra |
 kramdra World Chat Champion
 Posted: 00:33 - 26 Jan 2017 Post subject: |
www.ebay.co.uk/itm/351634653462
If you want an automatic, positive displacement oiler, motorcyce oil pumps are cheap. Attach a low speed dc motor and arduino to run it at a low duty cycle. |
| temeluchus |
| arry |
 arry Super Spammer
| kgm |
| secretagentmo... |
 secretagentmo... Scooby Slapper
| Pigeon |
| kramdra |
 Posted: 21:40 - 26 Jan 2017 Post subject: |
My tire looks like that every day the first mile or two. Its gone after a few corners. Tiny bit of oil does not affect grip. |
| BumpingUglys |
 BumpingUglys Trackday Trickster
 Posted: 23:06 - 26 Jan 2017 Post subject: |
Did you put that crash bobbin on with superglue, arry?  ____________________ Ducati M695 |
| arry |
 arry Super Spammer
 Posted: 06:21 - 27 Jan 2017 Post subject: |
I didn't put them on, they were already fitted. You've got me paranoid now  |
| BumpingUglys |
| arry |
 arry Super Spammer
| G |
 G The Voice of Reason
| arry |
 arry Super Spammer
| arry |
 arry Super Spammer
| V2 |
 V2 Nearly there...
 Posted: 20:34 - 28 Jan 2017 Post subject: |
Chainpal  |
The last post was made 9 years, 5 days ago. Instead of replying here, would creating a new thread be more useful? |
