Fog lights
Meshuggah
PostPosted: 23:26 - 26 Jan 2017    Post subject: Fog lights Reply with quote
Has anyone bought a set of those
https://www.ebay.co.uk/itm/331912580418?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT#rwid
and may have a video on how to install them?
thanks
Triumph Tiger 800 2012
skatefreak
PostPosted: 00:12 - 27 Jan 2017    Post subject: Reply with quote
Do kind of want... On my R1? Rolling Eyes
jaffa90
PostPosted: 00:46 - 27 Jan 2017    Post subject: Reply with quote
Poor description and flashing light mode illegal, how can 125w and 15w be the same?
iooi
PostPosted: 06:23 - 27 Jan 2017    Post subject: Reply with quote
Flash mode will just be quick button press same as any normal light set up.
5W is because it's a Cree LED bulb.....
125W is because they are demented yanks and think that is how it would compare to a std bulb...
What they should be giving is the Lumins....
Having had a pair they are OK, but unless you have got bars to mount on already a real PIA.
PostPosted: 08:30 - 27 Jan 2017    Post subject: Reply with quote
Poor obs.
"Flux: 3000LM"
Meshuggah
PostPosted: 10:14 - 27 Jan 2017    Post subject: Reply with quote
yes, as I said cheap Chinese but I wanted them just to have more visibility from other road users. I've got a Tiger 800 and I know the bike has already a plug for fog lights. Problem is the plug is just for the oem lights which cost 250£. no so keen on that.
So I thought if there was a way to attach those to that plug maybe using a "female" attachment.... not sure. there a video of a guy who did it but it doesn't show step by step how he did it.
https://www.youtube.com/watch?v=ytU9-_AqYBg
I also suppose I'll ned to buy those https://www.ebay.co.uk/itm/UNIVERSAL-12V-FOG-SPOT-DRIVING-LAMP-LIGHT-FUSED-WIRING-LOOM-HARNESS-KIT-RELAY-/231354241558?hash=item35ddc99216:g:eRMAAOSw1x1UM9BT#rwid
Hawkeye1250FA
PostPosted: 11:03 - 27 Jan 2017    Post subject: Reply with quote
Use your (or borrow a) multi-meter to check the output voltages on the plug when the switch is on / off.
Once you know which pin in the plug is live and which isnt - you should be able to follow the supplied wiring diagram to connect the spots?
Without a pic of the plug I dont know what kind of thing you are dealing with, but there are many connector choices available, one should fit snugly enough in it (on it?) to work.
Hope that helps! Thumbs Up
jaffa90
PostPosted: 11:49 - 27 Jan 2017    Post subject: Reply with quote
Thanks for that, also what does this mean?
Note:Light do not direct line of sight,so as not to affect the front of the drive of the vehicle traffic accidents.
neptune8
PostPosted: 13:27 - 27 Jan 2017    Post subject: Reply with quote
Probably means, Do not set up the lights to be shining directly into the eyes of drivers following you, it could cause an accident
Enjoy yourself, its later than you think
The last post was made 9 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 62.17 Kb
