Calling GPZ500 owners...
SilverWings
PostPosted: 18:04 - 29 Jan 2017    Post subject: Calling GPZ500 owners... Reply with quote
Hey guys, looking to pick some brains. I'm mulling over potentially changing the rear brakes on my ER5 from drum to discs, probably mainly using parts from a GPZ since they're already very similar bikes. The drum brake is a pain on my bike and it's out of round, I tried having it skimmed, didn't work and now there's not really enough material to try again. My options are get a new wheel (~£100) or change it to a GPZ wheel and put disc brakes on it (can pick up the parts on ebay for probably around the same price).
What I'd like to know right now is the distance between the ends of the swingarm on the later model GPZs, basically how much space does the wheel, caliper holder, spacers etc take up. I'm trying to gauge how much work it's going to take to fit on my ER5, am I going to have to modify spacers, make new ones etc.
Any responses are much appreciated, obviously this only applies to the models with disc brakes. Could you tell me the year of your bike too?
And if anybody has done this before and has any advice or tips it'll be much appreciated!
Nobby the Bastard
Harley Gaydar
PostPosted: 18:28 - 29 Jan 2017    Post subject: Reply with quote
It would be cheaper to buy another wheel than convert it to disk. After all, all you'd be doing is making it lock up quicker.
Triumph Sprint ST 1050
SilverWings
Funny, my favourite mechanic says the same thing. Can't understand why :3 Unfortunately for the moment I'm poor and this is reliable, it's not let me down once in 2 years, so I think I'll hold on to it for now Wink
SilverWings
PostPosted: 18:34 - 29 Jan 2017    Post subject: Reply with quote
It's not that it locks up...it doesn't do much at all. When it gets wet it's at best a 'slow down' lever, and even in the dry it's not very effective. The drum brakes on my own GPZ when I had one were also shite, I just didn't get on with them. Having had bikes with both drum and disc rear brakes I much prefer the feel of discs.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:36 - 29 Jan 2017    Post subject: Reply with quote
I'm out. You're obviously stupid and and don't understand the mechanics of rear brakes.
SilverWings
PostPosted: 18:45 - 29 Jan 2017    Post subject: Reply with quote
Explain please? What do I not understand? Not sure why you feel the need to insult me when I simply asked for a measurement which I assume you don't have...
It is likely to be a bit of a pain to do. Surprised at the comment on £100 for a rear wheel for one but a quick glance on Ebay shows they are surprisingly expensive (cheapest was £70).
To do the swap you will need to find a mount for the reservoir, modify the footrest hanger to hold the master cylinder, and then swap over the swinging arm. This would be the nasty bit as the GPZ500 has a single shock and the ER5 has twin shocks. You would need to weld some mounts in place on the swinging are (and not sure if there is clearance for the rear brake if the mounts were in the same place).
Personally I would stick with a drum rear brake
Katy
Kal
PostPosted: 18:47 - 29 Jan 2017    Post subject: Re: Calling GPZ500 owners... Reply with quote
Mine is at Katy's at the moment, I'm sure she would be willing to measure it for you.
What did occur to me is how do you intend to attach the calliper?
And while I've made a cup of tea she has actually already replied Smile
I understand what you mean, I prefer discs now I've been riding on them, but even on disc the rear is merely a trailing brake.
After my experience October before last I can cartographically state that the rear on a GPZ is not that effective at stopping the bike on its own.
Kal...
SilverWings
PostPosted: 18:49 - 29 Jan 2017    Post subject: Reply with quote
Would I need to change the swingarm? Looking at GPZ schematics, the caliper holder sits in place with a small piece of metal on the inside of the swingarm, could I not just get a piece welded on to mine to hold it? Yeah, ER5 wheels are expensive and hard to find, actually been looking for one since my last MOT cos it's gonna be a failure this time round. I messaged a few sellers on Ebay to ask about the condition of the drum and not one got back to me, I'm reluctant to spend that much on something that might not even be any better. Thanks for the input.
Kal
PostPosted: 18:54 - 29 Jan 2017    Post subject: Reply with quote
Assuming you switch the swinging arm out you then have the issue of a ER5 being a twin shock and a GPZ being monoshock.
Sorry to be a pain n the ass.
Kal...
SilverWings
PostPosted: 18:55 - 29 Jan 2017    Post subject: Re: Calling GPZ500 owners... Reply with quote
Kal wrote:
What did occur to me is how do you intend to attach the calliper?.
The caliper on the GPZ sits on a holder that goes on the axle. I'm reasonably sure the axle on the ER5 and the GPZ are the same width, if not the same axle, so fitting it shouldn't be a huge pain. I can get the holder pretty cheap on ebay. I know the rear brake is not the 'main' brake but it would be nice for it to do *something* o.O
PostPosted: 18:57 - 29 Jan 2017    Post subject: Reply with quote
More to the point. The single pot sliding callipers they used on 90's kawasakis are FUCKING shit.
The drum is better and also has the advantage that it can't spit its brake pads out.
Fix your drum.
SOURCE: Me. I've had a GPZ500 with a drum and one with a disc. The drum brake was WAY better.
SilverWings
PostPosted: 19:02 - 29 Jan 2017    Post subject: Reply with quote
...not saying I'm necessarily going to put a GPZ caliper on it, I want to know the distance between the swingarm so I can decide whether to use the same wheel, spacers, holder etc, or do I need to make my own. Nothing stopping me finding a better twin piston caliper...
PostPosted: 19:04 - 29 Jan 2017    Post subject: Reply with quote
Maybe you could fit the rear plate, and weld in a locating spot for it.
If you fit the rear disk then the caliper will need regular strips and rebuilds.
I can try and measure things up quickly
Katy
redeem ouzzer
Whoever decided that discs were suitable for a rear brake makes Hitler look like Mother Theresa. Why you would want one out of choice god only knows...
Be a REAL MAN!
PostPosted: 19:08 - 29 Jan 2017    Post subject: Reply with quote
Or you could fix your drum properly. They work well when they are serviceable and require minimal maintainance. Ought to work well enough to lock the rear wheel at will.
Be a lot less time and hassle and work out around the same price.
Azoth
PostPosted: 19:18 - 29 Jan 2017    Post subject: Reply with quote
What you're considering would require a fair bit of expertise in rat bike bodgery. How soon do you want or need to ride the bike? The best option is surely to buy another wheel and fit it in under 5 minutes. If the replacement wheel has a tyre attached to it, then that's some additional tyre mileage as an added bonus. Even if it doesn't, a replacement wheel is the fastest and easiest option.
Safety in numbers
PostPosted: 19:42 - 29 Jan 2017    Post subject: Reply with quote
Couple of photos to give you the basic dimensions:-
https://www.alfa-pages.co.uk/TempPicture/DSC_0173.JPG
https://www.alfa-pages.co.uk/TempPicture/DSC_0174.JPG
Katy
Kal
PostPosted: 19:45 - 29 Jan 2017    Post subject: Reply with quote
Kickstart wrote:
Katy
You realise I am now searching eBay for a nos swinging arm?
Kal...
PostPosted: 19:46 - 29 Jan 2017    Post subject: Reply with quote
Kal wrote:
Kickstart wrote:
Katy
In for a penny.....
Katy
Kal
PostPosted: 20:02 - 29 Jan 2017    Post subject: Reply with quote
The more parts I am sourcing the longer he is sat on your driveway.
At what point do I need to pay rent?
Kal...
PostPosted: 20:03 - 29 Jan 2017    Post subject: Reply with quote
Must get it fixed soon. We may pop in and kidnap you and the parts you have waiting
Katy
pompousporcup...
PostPosted: 06:56 - 30 Jan 2017    Post subject: Reply with quote
Fix your drum.
This. I contemplated the swap as well as i wanted twin discs up front and a rear disc to match. Turns out the drum is better both in its ability to help stop the bike but also that they don't seize up(compared to exposed discs/calipers) and seemingly last forever without adjustment Thumbs Up
SilverWings
PostPosted: 11:26 - 30 Jan 2017    Post subject: Reply with quote
Thankyou Katy, very helpful :3
The last post was made 9 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 129.37 Kb
