| natefz6 |
 natefz6 Brolly Dolly
 Posted: 12:14 - 30 Jan 2017 Post subject: How f$%ked is this sprocket? |
Hi all,
I attempted to get some man points at the weekend by changing the oil and oil filter on the fz6. It all seemed to go pretty well and without much drama although getting the old oil filter off was a bit tough. I ended up just using a large plumbers wrench rather than the tool I bought for the job as even the smallest chain oil filter removal tool was too big.
I have been thinking for a while that it might be time for a new chain and sprocket. The ones on it were there when I bought the bike and I have done 15,000 miles since then. I know nothing about how sprockets should or should not look so thought I would get a picture and ask for some advice before I plumb up the cash.
I
https://i.imgur.com/T0pBTYg.jpg
Cheers ____________________ "no I didn't steal it that's just the way I ride" |
| tom_e |
 tom_e Brolly Dolly
 Posted: 12:40 - 30 Jan 2017 Post subject: |
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 12:45 - 30 Jan 2017 Post subject: |
I don`t like the tooth above nos 5, have you a pic face on so we can see if any are hooked.
Upon another look it looks like that sprocket has been turned over or the bike goes backwards.
| Ste |
 Ste Not Work Safe
 Posted: 12:47 - 30 Jan 2017 Post subject: |
Order a replacement chain and sprockets right now.  |
| skatefreak |
 Posted: 13:05 - 30 Jan 2017 Post subject: |
Clearly starting to hook but defiantly a good several months left in that at the very least  |
| P.addy |
 P.addy Red Rocket
| NJD |
 NJD World Chat Champion
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
 Posted: 13:41 - 30 Jan 2017 Post subject: |
I'd run it until the sprocket become a bit more 'hooked', although I have had a chain snap on me before, but that's when I didn't inspect the sprocket and it was so bad it was actually missing a tooth  ____________________ DRZ400-SM
FZS600 |
| Holdawayt |
 Holdawayt Trackday Trickster
| iansoady |
 iansoady Borekit Bruiser
| skatefreak |
| tom_e |
 tom_e Brolly Dolly
| natefz6 |
 Posted: 14:38 - 30 Jan 2017 Post subject: |
I took one more slightly more face on.
With regard to the filter, I did it up just hand tight. The old one was about 2" deep in crap and was not budging. At one point I was going to try sticking a screwdriver through it to get more leverage but eventually it budged, even if it was a bit mangled by then.
https://i.imgur.com/nqgNHXq.jpg
I have watched a few youtube videos on changing chains and sprockets and while it doesn't look that hard I don't want to be half way through and find I can't undo a bolt or something. If my bike is off the road it adds 1.5hours to my day in commuting. I might just call up the garage (FWR) and have them do it. Its £40 to fit and £99 for parts looking at their website. I could get the same make parts on ebay for £90, I would then need to get the chain splitter and spend a couple of hours in the cold doing it. I'm not sure its worth while
Thanks for the opinions I thought it did need doing, but its good to know its not in a "it's going to kill you" state  ____________________ "no I didn't steal it that's just the way I ride" |
| Polarbear |
 Polarbear Super Spammer
| Ste |
 Ste Not Work Safe
| thx1138 |
 thx1138 World Chat Champion
 Posted: 14:52 - 30 Jan 2017 Post subject: |
| TheInternet |
 TheInternet Borekit Bruiser
| skatefreak |
 Posted: 15:13 - 30 Jan 2017 Post subject: |
Unless the chain is beyond its serviceable limit then I see nothing wrong with that sprocket and yes, it's well worn that's obvious...
Of course it's not in perfect condition but the only consequence at this stage (unless OP is trying to set record lap times on a circuit) is that it will wear the chain faster however that is immaterial as it will be replaced with the sprocket when either comes to their limits .
Its recommended that all 3 (front, rear & chain) are replaced as a set. Only replacing one or two of the above will result in the worn component wearing the newer components out a lot faster... |
 Posted: 15:30 - 30 Jan 2017 Post subject: |
If you are tight you could buy a pair of sprockets and keep the chain for a bit longer (given 75% of the cost of a replacement chain and sprockets is just the chain), but probably not worthwhile unless the chain is in very good condition. Yes doing this will mean the new sprockets would wear more quickly, but they are cheap comparatively.
Not that front sprockets are normally a far harder steel than rear sprockets. They turn about 3 times as fast and have the load over about 1/3 of the number of teeth, so the harder steel aims to even the wear out. Some aftermarket front sprockets are not treated like this though.
As to really wrecked:-
https://www.alfa-pages.co.uk/TempPicture/cols_sprocket.jpg
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| skatefreak |
 Posted: 15:34 - 30 Jan 2017 Post subject: |
Okay, now I'm impressed  |
| colink98 |
 colink98 Could Be A Chat Bot
 Posted: 16:24 - 30 Jan 2017 Post subject: |
Too much powwwwaaaaaaaaarrrrrrrrrrrrrr is what happened there. ____________________ PCX125 (stolen) - CBF600 (current)
Ride it like you stole it.
ride sensible and not like an idiot and you wont get 6 points in one week. |
| Ste |
 Ste Not Work Safe
| natefz6 |
The last post was made 9 years, 236 days ago. Instead of replying here, would creating a new thread be more useful? |
