When should I change my piston?
thx1138
PostPosted: 14:35 - 30 Jan 2017    Post subject: When should I change my piston? Reply with quote
My Beta accumulated running time is now 70 hours.
Manual says change piston at 60 hours.
But, I doubt very much like I ride my Beta anything like the people that wrote the manual had in mind, I green lane it, and sometimes I tip-toe round pay and play courses, refuse obstacles, occasionally pull a feeble wheelie or do an ickle "jump"
and ride it on the road a lot more than most I should imagine.
It sounds and rides the same as it ever did.
PostPosted: 14:54 - 30 Jan 2017    Post subject: Reply with quote
Double it if you aren't giving it beans.
stevo as b4
PostPosted: 19:31 - 30 Jan 2017    Post subject: Reply with quote
A 300cc two stroke won't eat pistons very quickly even a tuned snarling enduro lump. The X-trainer is closer to a trials bike engines state of tune isn't it?
As a guide the Italian kids who ride KTM 125 supermoto's on the street which are competition spec MX/enduro motors, they usually change the piston at 3000-5000miles. I don't know how many hours that equates to but it'll be more I expect than the manufacturers service interval.
Id be looking at maybe 150hours or 8-10'000miles as an approximate safe guess I would say.
PostPosted: 20:09 - 30 Jan 2017    Post subject: Reply with quote
How much is a piston and rings? I might be tempted to strip it down to have a look. Although I would very much doubt it is necessary yet.
Katy
PS - think for the 300cc KTM 2 strokes the top end kit with new piston, rings and gaskets is about £125
Bloggsy
PostPosted: 14:22 - 31 Jan 2017    Post subject: Reply with quote
If the bike is running ok, then leave well alone
Remember If It Aint Broke Don't Fix It.
If It Aint broke Don't Fix It
PostPosted: 14:33 - 31 Jan 2017    Post subject: Reply with quote
You could periodically log the compression and change it when compression starts to drop.
I'd be more concerned about the small ends than the piston. Worn rings/bore are just going to lead to a loss of compression and gradual loss in performance. When a small end lets go, chaos can ensue.
PostPosted: 17:35 - 31 Jan 2017    Post subject: Reply with quote
mpd72 wrote:
Not the best advice for a stroker. It will eventually break if you don't keep on top of preventative maintenance.
Indeed; not great advice for most vehicles frankly - but does explain why so many have issues and why 4 stroke 125s became popular over 2 strokes!
Old Git Racing
PostPosted: 19:12 - 31 Jan 2017    Post subject: Reply with quote
It's a comp bike built to closer tolerances than a road bike. You might not notice a drop off in performance but you will notice the difference if you rebuild it. Its the other bits that wear too. Do nothing at your peril.
My TZ needed new pistons every 300 miles by 250 you could feel the difference. Only ran it over mileage once and it ate a ring.
OGR
PostPosted: 20:54 - 31 Jan 2017    Post subject: Reply with quote
Leave it too long and a ring wear, snaps and trashes the barrel.
Katy
stevo as b4
PostPosted: 21:18 - 31 Jan 2017    Post subject: Reply with quote
I did exactly this at 18600miles on a KMX 200 once. Fairly certain the engine had been apart before though, but can't say if it was the original piston? I'm guessing it was though as the old head gasket had been re-fitted with a plastering of silicone sealant.
No matter what the stroker is I'd never personally go more than 10'000miles on a top end, probably 7-8000miles max on a performance engine like an RGV, if the crap power valves don't take the motor out first that is? Laughing
The last post was made 9 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 75.73 Kb
