Desperate help needed
Jog_on_smudge
PostPosted: 08:16 - 31 Jan 2017    Post subject: Desperate help needed Reply with quote
Hi everyone, I'm new to the forum and you've got some great reviews so I'm hoping that someone can shed some light on my problem.
I bought my son a Yamaha jog RR to get backwards and forwards to college. The bike ran great but then started to get harder to start.
Then one morning it wouldn't start at all on the button or on the kick start.
I then cleaned the carb, air filter and put a new electric choke and spark plug in it.
It then ran great, started on the button for 2 days then this morning he went out and it wouldn't start again.
I'm now totally scratching my head as I don't understand why.
If anyone can throw some light on the problem I would be very great full.
Thanks Steve
Always smile - it may never happen or it probably already has!
arry
PostPosted: 09:20 - 31 Jan 2017    Post subject: Reply with quote
Describe what's happening when it fails to start. I'm assuming it's turning over but not catching, in which case have you checked that there's a spark?
Jog_on_smudge
PostPosted: 10:15 - 31 Jan 2017    Post subject: Reply with quote
Hi thanks for your input.
Yeh it just turns over but doesn't start.
It's got good fuel to the plug, a good spark and clean air.
mitch99
Whenever this has happened to any bike i've had, it's been valve clearances tightening up.
Jog_on_smudge
PostPosted: 10:16 - 31 Jan 2017    Post subject: Reply with quote
It's only s moped, no valve adjustment.
PostPosted: 10:43 - 31 Jan 2017    Post subject: Reply with quote
Specifically, it's a 2 stroke 50. You can infer that from the fact that help is "desperately" needed, although for some reason it's NOT CAPITALISED.
I realise that isn't helpful, but we're got nothing to go on. You've already done the right things and checked the right things.
It's not sparking strongly enough, or at the right time; the fuel-air mixture is off; or compression is coming and going. We can suggest a bunch of random causes, but it's going to come down to you testing each one to rule them out.
Jog_on_smudge
PostPosted: 11:03 - 31 Jan 2017    Post subject: Reply with quote
Thanks for the comment.
It's desperate because I'm only home at the weekends due to work and the bike is needed to get my son to college so in my case iv ran out of tests and desperately trying to get a bigger audience of knowledge.
Can the cylinder compression come and go?
I would have thought that if the rings were worn or the bore was US it would always make no compression.
It's got a great spark and yesterday started on the button first time but this morning nothing on the button or by kicking it.
Thanks everyone for your comments and help.
jaffa90
PostPosted: 11:07 - 31 Jan 2017    Post subject: Reply with quote
Did you find anything in the carb and what colour was the spark plug?
Jog_on_smudge
PostPosted: 11:30 - 31 Jan 2017    Post subject: Reply with quote
No rubbish in the carb and the plug looked a little black but nothing to worry about.
Suntan Sid
PostPosted: 11:36 - 31 Jan 2017    Post subject: Reply with quote
Probably needs a de-coke, cylinder head, piston and more importantly the exhaust!
jaffa90
PostPosted: 11:45 - 31 Jan 2017    Post subject: Reply with quote
That leaves the choke then, can you spray easy start spray or carb cleaner into the inlet manifold (air filter removed) and if it starts / runs a little then it sounds like the choke plunger is stuck.
Jog_on_smudge
PostPosted: 12:34 - 31 Jan 2017    Post subject: Reply with quote
Thanks for all the comments, I have put a new choke on it however when I tested the voltage I wasn't getting any.
Under the seat there is a module of some sort that is in series to the choke. Does anyone know what this module does?
jaffa90
PostPosted: 12:54 - 31 Jan 2017    Post subject: Reply with quote
Module? Pass on that, any pics?
Jog_on_smudge
PostPosted: 13:24 - 31 Jan 2017    Post subject: Reply with quote
Sorry not until the weekend. It is in line from the wiring loom through the module to the choke.
Evil Hans
PostPosted: 13:27 - 31 Jan 2017    Post subject: Reply with quote
Check the continuity between the (black?) earth wire coming out of the choke and earth to make sure it's earthing properly. Then try connecting a 12v supply to the auto choke and see if that helps?
jaffa90
PostPosted: 13:35 - 31 Jan 2017    Post subject: Reply with quote
Voltage could be there when the engine is running and not just when the ignition switch is on.
Back to my second post really.
Jog_on_smudge
PostPosted: 13:43 - 31 Jan 2017    Post subject: Reply with quote
Yeh I thought that but if it's for the choke then surely you would need power for the choke? Or does the needle retract?
I feel it's got to be something to do with the choke also.
jaffa90
PostPosted: 15:32 - 31 Jan 2017    Post subject: Reply with quote
The auto choke (fuel enrichment really) plunger is retracted when the engine is cold and no power to it and is pushed back out with power to block the passage (choke off) all the time the engine is running.
Jog_on_smudge
PostPosted: 17:40 - 31 Jan 2017    Post subject: Reply with quote
But why would it start one day then not the next?
Analogkid
PostPosted: 00:25 - 01 Feb 2017    Post subject: Reply with quote
Have you checked the battery?
Or could it be a dry joint or a faulty new choke?
Andy_Pagin
PostPosted: 11:57 - 01 Feb 2017    Post subject: Reply with quote
Since no-ones' asked the obvious question, has the bike been 'de-restricted' or otherwise mucked about with by previous owners?
andyscooter
PostPosted: 13:15 - 01 Feb 2017    Post subject: Reply with quote
Simple thing what's the battery like
A lot of starting probs are caused by a shit battery
Not sure if jog has an immobiliser but if battery is dead it won't immobilise
Copycat73
PostPosted: 20:05 - 01 Feb 2017    Post subject: Reply with quote
spark plug workin itself loose..
choke / mixture fouling plug ...
caveat emptor
The last post was made 9 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.17 - MySQL Queries: 13 - Page Size: 121.92 Kb
