CBF600 2004 ABS light flashing
colink98
PostPosted: 11:13 - 31 Jan 2017    Post subject: CBF600 2004 ABS light flashing Reply with quote
Hello All.
I have an issue with a flashing ABS light.
im 99% sure its die to water in the system somewhere.
it only happens when it rains and after a dry day or two it goes away.
i had a look and didn't see anything obvious.
i looked under the seat where the controller for the ABS is and it didn't look wet or damp.
it was simple to trace the cable from the rear ABS sensor to the controller.
but the front ABS cable goes under the tank and i cant see where it comes out.
any pointers prior to giving half a day to remove the tank ?
Cheers
C.
PCX125 (stolen) - CBF600 (current)
Ride it like you stole it.
ride sensible and not like an idiot and you wont get 6 points in one week.
Paulf
PostPosted: 19:40 - 31 Jan 2017    Post subject: Reply with quote
You could try doc short link in the dlc port and see any codes stored if it is a modern bike. Type honda dlc reset on YouTube. If you short out the dlc in flashes up the mil codes that's causing the light to flash.
colink98
PostPosted: 11:54 - 02 Feb 2017    Post subject: Reply with quote
i have found some info relating to the shorting out of the DLC and reading the MIL code.
it says to watch the MIL for flashing light ?
thick moment.
Whats MIL ?
colink98
PostPosted: 11:57 - 02 Feb 2017    Post subject: Reply with quote
ignore me....Just read
This procedure will also show ABS codes, if any, on so-equipped models. PCM codes will blink on the MIL while ABS codes will blink on the ABS light.
Paulf
PostPosted: 23:18 - 02 Feb 2017    Post subject: Reply with quote
Not sure but mil is maintence indicator light but DTC is diagnostic trouble codes according to Honda workshop manual.
colink98
PostPosted: 14:05 - 04 Feb 2017    Post subject: Reply with quote
spent some time working on the bike today.
there were 5 error codes in all and they all led to a faulty modulator unit.
as per the workshop manual i reset the errors and took the bike for a ride.
as of yet the error light has not come back on...
so fingers crossed.
just in case i did take a look on the eBay and it is awash with ABS units from various CBFs and CBRs....
they all look the same...
what are the chances these will be the same part ?
Cheers
C.
The last post was made 9 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 47.09 Kb
