BANDIT 6 VS ZXR 400
Riderz
PostPosted: 21:47 - 02 Feb 2017    Post subject: BANDIT 6 VS ZXR 400 Reply with quote
So ive had a bandit on an A2 license for a while now. I bought it with 45K mileage for £1200. I had an accident after my front brake seized at 50mph I have since had work done and its running fine. However I can never get it out my mind that it wont happen again as no matter what I do the front brake does not feel right...
I may be picking up a ZXR 400 tomorrow for 2499 with just 17k Mileage for 2k from a dealer I have bought 3 bikes from.
Going to trade in my smashed up bandit and get the ZXR for 2K.
Is the ZXR reliable etc? Its looks in excellent condition im checking it out tomorrow with a good bit of service history Smile
All comments appreciated but the bandit needs to go as I cannot enjoy riding it at all anymore and I dont mind seeing her go for 500 seeing as its not in great condition and has 52k on the clock...
Thanks
|CURRENT RIDE:MK1 GSF600N| PAST BIKES:Varadero 125/RS125 x2./XT400/KLR650/CBR 500R/. A2 LICENSE SUCKS
Alex A
PostPosted: 22:26 - 02 Feb 2017    Post subject: Reply with quote
Link?
Can you not get something better for £2.5k? Maybe a B1H?
Riderz
PostPosted: 22:35 - 02 Feb 2017    Post subject: Reply with quote
Alex A wrote:
Link?
That's how much they go for these days. Should definately hold value :
https://www.budgetbikesuk.co.uk/used/kawasaki/zxr400/zxr-400/swindon/wiltshire/20007058
redeem ouzzer
PostPosted: 22:41 - 02 Feb 2017    Post subject: Reply with quote
Is it a real SP? It's got a single seat unit but the paint job isn't quite right and it's got an MPH speedo (SP's were all J-spec but i guess the speedo could of been changed). Something doesn't sit quite right and i'd be asking more questions.
Be a REAL MAN!
Alex A
PostPosted: 22:42 - 02 Feb 2017    Post subject: Reply with quote
Check the MOT notes here: https://www.check-mot.service.gov.uk
It looks clean, but the frame is the wrong colour - so it's obviously been stripped right down (by somebody). Fairings may or may not be standard. I wouldn't place any premium on the mileage, since it's pretty much unverifiable (although not contradicted by MOT history).
You might be right. It could hold it's value. But it's not standard/original, which is usually what's important re. value.
But regardless of 'what they go for', could you not buy a better bike for £2.5k? A better sportsbike, assuming that's what you want.
redeem ouzzer
PostPosted: 22:46 - 02 Feb 2017    Post subject: Reply with quote
I missed the black frame Confused Assume it's it's been upside down on fire untill the dealer proves otherwise.
Be a REAL MAN!
Riderz
PostPosted: 22:51 - 02 Feb 2017    Post subject: Reply with quote
I'm on an A2 and I want a 4 cylinder sports bike. I checked the MOT and it doesn't look good. Maybe I'll just not bother then Sad
I can't keep the bandit anymore though with the constant fear of my front brakes seizing again....
Alex A
PostPosted: 22:59 - 02 Feb 2017    Post subject: Reply with quote
I wouldn't bother for that money.
Weak brakes. Damaged indicator. Wrong colour frame. Suspect fairings. Engine not running on 4 cylinders, which could be fixed already, it could be a cheap(ish) fix, or it could be an difficult and very expensive problem. But once you've bought it, it's your problem to get the dealer to sort it out. Easier not to buy it.
I don't know what A2 limits you to, but a 400 is probably the best sportsbike you could ride. If you want something that will hold it's money, even if it's a bit of a mess, then buy a Honda VFR400 NC30.
Riderz
PostPosted: 23:01 - 02 Feb 2017    Post subject: Reply with quote
I would buy a vfr or rvf but they are going for around 4/8 grand I really wanted a ZXR but the mot is worrying me. He said the carbs need cleaning and that they would do it before I come Sad never mentioned the other shit
Alex A
PostPosted: 23:07 - 02 Feb 2017    Post subject: Reply with quote
He might be right. The carbs could need cleaning.
Or the coils could be past it. Or the wiring could be shot. Or there could be physical wear to the engine (worn valves or rings).
You could end up in a cycle of it not being OK, then try something, then try something else, then something else etc. Not worth it.
PostPosted: 23:08 - 02 Feb 2017    Post subject: Reply with quote
Frame colour could well be original (the metallic maroon and the metallic blue ones had black frames), but the fairings have been played with. Top fairing looks like a GRP copy.
My guess is a blue or maroon one which someone has replaced the bodywork on.
Katy
redeem ouzzer
PostPosted: 23:10 - 02 Feb 2017    Post subject: Reply with quote
Rebuild B6 calipers. Job jobbed.
Wait for something decent to come up to replace it.
Be a REAL MAN!
Riderz
PostPosted: 23:11 - 02 Feb 2017    Post subject: Reply with quote
Any suggestions then lol? Any other decent 400z that aren't more than 2K.
I hope they give me back my 100 pound holding deposit
Alex A
PostPosted: 23:12 - 02 Feb 2017    Post subject: Reply with quote
Wouldn't the fork bottoms be black too?
Bozzy
PostPosted: 23:15 - 02 Feb 2017    Post subject: Reply with quote
Aside from the questions regarding condition/authenticity, could this bike even be ridden legally on a2? What sort of power do they make?
2004 SV650S >>> 2009 Street Triple R
redeem ouzzer
PostPosted: 23:17 - 02 Feb 2017    Post subject: Reply with quote
Nice spot.
Be a REAL MAN!
PostPosted: 23:24 - 02 Feb 2017    Post subject: Reply with quote
Possibly, but far easier to paint the fork bottoms than the full frame. The silver on them doesn't look quite right so possible (could have had the forks replated and rebuilt), but the repainted calipers might be giving an illusion.
Katy
woo
PostPosted: 23:41 - 02 Feb 2017    Post subject: Reply with quote
chain looks a bit slack too
i know your restricted and all but i got my GSXR 1000 K1 with 18k miles for £1951 off ebay in novemeber 2016
theres deals out there you just gotta be patient and look real hard
Elen sila lummen omentielvo!
Tdibs
PostPosted: 05:48 - 03 Feb 2017    Post subject: Re: BANDIT 6 VS ZXR 400 Reply with quote
hmmmmmmmm
Anyway I would save the money for A and get a cheap 'restricted' a2 bike for now.
PostPosted: 09:22 - 03 Feb 2017    Post subject: Reply with quote
That's how much dealers are asking for them these days. How long have they not sold that one for? The last starry eyed A2er who linked to one hadn't spotted that it had been up for sale at the same price since 2015.
Are you a dealer? Can you afford to sit on it for years?
Good luck getting half of that for it as a private seller, even if it were running.
Holdawayt
PostPosted: 09:45 - 03 Feb 2017    Post subject: Reply with quote
If I were you I'd either rebuild the front brake caliper (£20 odd quid for a rebuild kit and a few hours to fit), or I'd buy a set of calipers, discs and a new master cylinder (basically strip the brakes off a breaking bike) and fit them so you know it's all been changed. At least then you have peace of mind.
I wouldn't bother spending any more money on a new bike.
Riderz
PostPosted: 09:50 - 03 Feb 2017    Post subject: Reply with quote
Im sorry but I beg to differ if you check the market on these bikes there is no reason why it wouldn't sell for 2K I should lose like a maximum of 1/200 ?
Only issue being since I checked MOT it failed very badly....
I really don't want another bike that I Have to put all my money into as most the bikes I've had have all gone wrong apart from my hondas
Riderz
PostPosted: 09:53 - 03 Feb 2017    Post subject: Reply with quote
The shop rebuilt them for me and I still feel they are not right. I have since replaced the master cylinder and has had no effect.
The brake binds with like 1 small touch on the lever and I still Have my front brake light disconnected as it stays on if I use the front brake.
No matter what I do I have issues with the brakes and I couldn't bare to have another accident I was very lucky the last few times
andyscooter
PostPosted: 09:57 - 03 Feb 2017    Post subject: Reply with quote
I really don't want another bike that I Have to put all my money into as most the bikes I've had have all gone wrong apart from my hondas[/quote]
so you thought buying a 22 year old bike that was normally ragged would solve the reliability problem Shocked Shocked
Riderz
PostPosted: 10:08 - 03 Feb 2017    Post subject: Reply with quote
so you thought buying a 22 year old bike that was normally ragged would solve the reliability problem Shocked Shocked[/quote]
I just want something I enjoy riding but the fucking EU laws mean that any sport motorcycle that you can ride on A2 is the same price as a super bikes or sometimes more... it's low mileage at 17k but i just don't know what to do the bandit has to go though regardless.
There are literally no decent bikes that I can buy on this retarded license
The last post was made 9 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 133.37 Kb
