Spark plugs replace or not to replace?
natefz6
PostPosted: 23:31 - 06 Feb 2017    Post subject: Spark plugs replace or not to replace? Reply with quote
Hey y'all,
So after some encouragement and education from this fair site of ours I am starting to do more of my own maintenance. I have been working through the required elements for a 20,000km service on the FZ6. I am at 20,000miles but hey ho better late than never Smile
The one remaining thing I have to do from the list is to replace the spark plugs. I have not pulled one out yet to have a look but what should I be looking for? Should I just replace them anyway if I have pulled them out?
The bike idles fine and I don't get any misfires. It does very occasionally stall if I pull away quickly and then let off the throttle and pull the clutch but I just put that down to my poor riding Smile
Any advice on which plugs to go for? I have seen people recommend iridium ones, some saying they last longer other proclaiming it makes riding the bike silky smooth :/ . At £30 for 4 they are not going to break the bank!
Thanks again!
"no I didn't steal it that's just the way I ride"
BTTD
PostPosted: 23:36 - 06 Feb 2017    Post subject: Reply with quote
If the plugs are due changing per the service schedule then I would change them. I'm not convinced iridium are worth the extra, or at least I've never noticed any difference on the bikes I've owned.
PostPosted: 00:15 - 07 Feb 2017    Post subject: Reply with quote
They'll last longer, which may benefit you, or the next owner. The iridium plugs in my Nazi Tractor are scheduled for replacement every 24,000 miles. I thought that was extreme, but it's running fine at 19,000 and cars tend to go tens of thousands of miles without change - some technoplugs reckoning they're good for 120,000 miles. Shocked
Copious amounts of Plus-Gas, and don't go full Hulk on them. If you snap one then you're into an epic What Do? thread.
mentalboy
PostPosted: 00:58 - 07 Feb 2017    Post subject: Reply with quote
How many people, as in non-morons with correct tools, actually bust spark plugs on machines less than 30 years old? Not as criticism just curious.
I have never used any penetrating lubes nor broken a single plug on any car or motorbike, not even on really scabby old generators where the head has suffered major ally corrosion.
Not that using a penetrating oil is a bad idea, it is probably a useful habit to get into for any fastening that gets weathered.
Make mine a Corona.
Andy_Pagin
PostPosted: 01:07 - 07 Feb 2017    Post subject: Reply with quote
Having gone to the hassle of getting them out I'd change them, dunno about the FZ6 but they're a bugger to get to on the Fazer, and they tend to rust up badly on the outside, especially the inner two plugs.
nowhere.elysium
The Pork Lord
PostPosted: 08:21 - 07 Feb 2017    Post subject: Reply with quote
I've seen one shed its thread prior to now, but it's not exactly a common occurence.
PostPosted: 09:39 - 07 Feb 2017    Post subject: Reply with quote
I've never rekt one, but we know that engine (in combination with special owners) might be tricksy.
pompousporcup...
PostPosted: 10:31 - 07 Feb 2017    Post subject: Reply with quote
i've never 'needed' to change one yet i have put new ones in every 8-10k miles on the twin. For £6 it doesnt break the bank at all.
~£30 for 4 plugs is a lot of money really, considering for half that you could get 4 regular ngk plugs that would last. You could also buy 4 spare plugs (unlikely every to need 4 tbh) for if one does decide to play find the shit.
The main reason i check/change the plugs so often is to avoid the corrosion and risk of the plug seizing in the head (the twin i have has drain holes which block up easily leaving water sitting on the plug) i copper slip the threads every time they're out and have never had issues with stuck plugs.
PostPosted: 11:45 - 07 Feb 2017    Post subject: Reply with quote
My TDM specified, 18k for plug changes, the only time I left it for longer than that it developed a misfire at about 20k.
As they are a fucker to get to I do it whenever I'm in the area so to speak.
natefz6
PostPosted: 18:13 - 21 Feb 2017    Post subject: Reply with quote
Well, err that went well.
So at the weekend I thought I would get on with this. I unbolted the radiator to give me some room, pulled off the HT lead and used the removal tool from the tool kit to undo the 1st spark plug.
It was tight enough but was not a pain at all to remove Very Happy
But the plug was not the same as the ones I have received from amazon Confused
I was in a bit of a rush and it had started spitting with rain so I packed my stuff up and glumly made my way inside.
Of course after some googling today, I now realise that all I should have done was removed the terminal and they would have matched Rolling Eyes
https://d3nevzfk7ii3be.cloudfront.net/igi/FXSQMJGIwLMvNpls.medium
The old ones were looking pretty similar to this
https://www.sportbikes.net/forums/attachments/fz6-fz6r-mods/70206d1137630542-ngk-cr9eix-iridium-spark-plugs-old-spark-plugs.jpg
Very Happy Very Happy Live and learn! Very Happy Very Happy
PostPosted: 18:15 - 21 Feb 2017    Post subject: Reply with quote
You aren't the first and won't be the last Laughing
natefz6
PostPosted: 21:01 - 04 Mar 2017    Post subject: Reply with quote
Well the sun was out today and I had the two minnie me's so it was as good a time as any for them to clean the bike and me to give this another go.
All the plugs came out easily, I had read that it was a bit of a bitch to get the 1 and 2 plugs out but actually with my girly hands and a few additions to the ratchet it was pretty easy.
https://i.imgur.com/kR2hTrW.jpg
Obligatory old and new
https://i.imgur.com/e5eqZRL.jpg
PostPosted: 23:01 - 04 Mar 2017    Post subject: Reply with quote
How's it running with the technoplugs?
My lizard brain is looking at those twin-spark plugs and thinking: but that's 2x the spark! And bigger sparks! And exposed to the cylinder!
natefz6
PostPosted: 23:33 - 04 Mar 2017    Post subject: Reply with quote
TBH with limited testing I have not noticed any difference but have not been out on a big run yet. I will update when I do.
Pigeon
PostPosted: 23:42 - 04 Mar 2017    Post subject: Reply with quote
I use Iridium plugs because I'm a capitalist pig. Except in this example, where the original plugs are twin prong and the iridium single.
Read a few posts from Striple owners who had problems going from twin regular to single Iridium. Maybe only internet hearsay, but enough to not bother even trying.
Fizzer Thou
PostPosted: 11:17 - 05 Mar 2017    Post subject: Reply with quote
The plugs that you have removed are a specific type that last longer due to the twin electrodes.It is only the centre electrode that has worn.Colour looks good so the air/fuel ratio is nominal.The Iridium ones that you have bought might make the throttle response better,as this is what I found when I installed them in my R1 and my KTM Enduro race bike.
This chart is helpful for indentifying engine problems
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/PlugChopExamples_zpstltk64da.jpg
Always have a 'Plan B'
PostPosted: 11:38 - 05 Mar 2017    Post subject: Reply with quote
Afraid you will only get one spark at a time. The spark will just jump the easiest gap, although with wear that might change and it will then jump the other gap.
While it might be facing the cylinder, when the plug fires the piston it pretty close to the top of travel, hence any gain would be from having as much of the open area to the spark being open to the side. Although honestly I suspect the difference either way is pretty much non existent.
Katy
Matt B
PostPosted: 11:53 - 05 Mar 2017    Post subject: Reply with quote
Yup, you need two plugs in there to get a twin spark.
PostPosted: 12:12 - 05 Mar 2017    Post subject: Reply with quote
Don't you oppress my belief system.
https://i.imgur.com/cGiXbRq.png
Fizzer Thou
PostPosted: 14:51 - 05 Mar 2017    Post subject: Reply with quote
Hence the reason for indexing the plugs so that the open side does not hide flame travel across the top of the piston crown and combustion chamber.
When ND first bought out their 'U' groove plugs,they marketed the plug on the idea that the spark would cause a ball of fire within the groove and that you would get a fatter spark,cleaner emissions and better fuel consumption.The reality was that it was the same as a standard plug but more expensive.
natefz6
PostPosted: 19:51 - 05 Mar 2017    Post subject: Reply with quote
All the posts in Fz forums I read said it made it either "not noticeably better but should last longer" or that "it ran smother on iridium". I didn't see any negative posts so figured not to worry about going two to one sparky bit Smile .
Time will tell Smile
Pigeon
PostPosted: 23:56 - 05 Mar 2017    Post subject: Reply with quote
Post back if it goes good, bad or neither Thumbs Up
I put Iridium plugs in all my bikes (125, 250, 645) except my 675.
Opted for Iridium because I was attracted to the idea of less chance of fowling in between changes and that the 15k mile change interval would be a doddle, ie the plug should be in very good nick.
I was also tempted by the idea it put less load on the electrics. I have NO idea if there is any truth to that though.
natefz6
PostPosted: 14:47 - 08 Mar 2017    Post subject: Reply with quote
Hi All,
200 miles down and not much to report. It did feel like there was a slight improvement in throttle response and the bike is running nice and smooth. I cant compare that to what it would have been like with new normal plugs as I did not test that, I think the old plugs were 20,000 miles old Smile.
Although to be honest sometimes the bike feels like it rides better after I have cleaned it so it could all be placebo Smile.
Its a job that needed doing that's been done and now will not need to be done until after I have moved on to a new bike I would have thought. And its certainly a job I would do myself again.
The last post was made 9 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 129.51 Kb
