KX 250 supermoto
Bojje
PostPosted: 13:26 - 08 Feb 2017    Post subject: KX 250 supermoto Reply with quote
Hello all,
I'm in the process of building a KX 250 supermoto (2 stroke).
I was wondering how a 320 mm disc with stock caliper and an offset bracket would work on track? I've heard people experience fading on bigger bikes with standard offroad calipers so I was thinking that a light 2 stroke might not have the same problem.
Anyone with experience?
dangerousdave
PostPosted: 22:22 - 02 Apr 2017    Post subject: Reply with quote
if you aren't suffering brake fade with your current set up and riding, then you won't suffer it with a larger disk. the larger disk may give the calliper a slightly easier time overall, as it will shed heat faster than a smaller disk.
I found the KX callipers were much better than those fitted to trail bikes at the time.
I am running a larger disk setup on my kmx200 with an uprated calliper and master cylinder, as the original setup was quite weak IMO. It is a great improvement in every way.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
The last post was made 9 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 31.52 Kb
