Speedo accuracy and calibration.
neptune8
PostPosted: 21:51 - 08 Feb 2017    Post subject: Speedo accuracy and calibration. Reply with quote
I know that most speedos exagerate the speed of the vehicle. In other words, the speed shown on the dial is greater than the actual speed of the vehicle. I am a bit odd, I know, but I try to stick to speed limits all the time. I passed through a village recently, which has a 30 limit. It also has a radar device that shows your speed. I know that the speedo on my CG125 is not accurate, and By comparing speeds with my daughters car, I worked out that when my speedo reads about 33, My speed will be a true 30. So I rode through said village at an indicated 33, and the radar said 27! My question is, does anyone know a cheap easy way to calibrate a speedo?
Enjoy yourself, its later than you think
Commuter_Tim
PostPosted: 21:57 - 08 Feb 2017    Post subject: Reply with quote
If you mean these dealios...
https://l7.alamy.com/zooms/f25226a0fd044b74877be847a9b23d30/traffic-speed-warning-indicator-by-the-road-with-a-car-exceeding-the-dnxby4.jpg
It is my understanding they are not required to be all that accurate. (awaits being corrected by Rog etc)
I can assert the one near me sure as shit hasn't been accurate since they installed it 6 years ago.
Also "Enter" Key Bro, learn to love it.
I ride a Bandit 600... badly.
BumpingUglys
PostPosted: 21:59 - 08 Feb 2017    Post subject: Reply with quote
Those light up signs will be about as accurate as your speedo and/or your daughter's car i.e. not particularly.
I think the usual way to gauge actual speed without specialist kit is to use some kind of GPS. Though I imagine there's a certain degree of fallibility in a lot of those.
Ducati M695
Billy Balthorpe
PostPosted: 22:00 - 08 Feb 2017    Post subject: Re: Speedo accuracy and calibration. Reply with quote
Get a GPS?
M.O.B. Successfully taking the piss since 2014.
Kentol750
PostPosted: 22:00 - 08 Feb 2017    Post subject: Little speed monitors. Reply with quote
These don't always catch a bike very well, (small frontal area). I've gone through at 17mph on bandit 600 showing 30, 29 on fazer 600. On a test a pupil saw 18 flash up (on sv650) and then 29 as examiner went through on deuville/nc700. Luckily he didn't ping it up to 40 and fail!
Some bikes.
Billy Balthorpe
PostPosted: 22:12 - 08 Feb 2017    Post subject: Re: Little speed monitors. Reply with quote
Surely an examiner couldn't fail someone on the evidence of one of these things? Especially if he went through doing the same speed and it read less than the limit?
Kentol750
PostPosted: 22:58 - 08 Feb 2017    Post subject: No. Reply with quote
If he'd not seen the 29 flash up he said he would've thought the gradient and throttle off had slowed him more than he thought....bit of test nerves....we'd been there a few times on our training! ( had a fail a few years back missed 30 sign and it flashed 37 in red!)
Some bikes.
andyscooter
PostPosted: 23:58 - 08 Feb 2017    Post subject: Reply with quote
I've made one flash at 99 more then once on a 125
ThatDippyTwat
PostPosted: 07:37 - 09 Feb 2017    Post subject: Reply with quote
There's on one my commute into work. It freak out I'm doing more than 30, but it still does that if I'm under 20, no matter car or bike.
If you're speedo says you are just under, then it won't be a problem, and you won't hold anyone up that's not hoofing it.
PostPosted: 09:55 - 09 Feb 2017    Post subject: Re: Speedo accuracy and calibration. Reply with quote
By comparing your inaccurate speedo with your daughters inaccurate speedo, all you've done is compounded the inaccuracy which makes it impossible to come to any type of meaningful conclusion.
A cheap and easy way to "calibrate" your speedo is to go past that sign which tells you your speed at 20mph, 30mph, 40mph, 50mph, 60mph and 70mph noting the reading each time. But for this to be useful we're assuming that the sign is giving an accurate reading and I wouldn't want to bet on that.
If you've got a GPS on your phone then you can do the above and you'll get accurate readings from the GPS.
But the most accurate option is to make use of a local community speed watch. Go flying past them at different speeds and they've got a police calibrated speed gun thingy which gives the most accurate reading you're going to get. You get a print out of your achievements and everything which they send to you in the post. Do it enough times and the tone of their letters change and suddenly they're going on about how local traffic police are looking out for your vehicle. And at that point the best thing for you to do is to sell the vehicle locally. Laughing Thumbs Up
yen_powell
PostPosted: 10:27 - 09 Feb 2017    Post subject: Reply with quote
I've put those types of illuminating digital signs up and the manufacturer asked me what I wanted it to display at 30mph (they are adjustable). I said 32 so it would always over read.
I wouldn't take one of those as being correct at all.
XT1200Z and a DR350 in bits
ZebraDriver
PostPosted: 19:37 - 09 Feb 2017    Post subject: Reply with quote
Try finding a government calibration site. They can be recognised by a yellow box mounted on a pole. Once you find one go past it as fast as you can, it will flash twice to acknowledge your participation in the scheme, remember to note your speedo reading at the second flash. Your speedo calibration certificate will arrive in the post a few days later.
Please be aware that the charge levied for using the system is quite high (the charge will be advised along with your calibration certificate)
They do operate a reward points scheme as well, if you collect enough points you get a pushbike
talkToTheHat
PostPosted: 20:55 - 09 Feb 2017    Post subject: Reply with quote
Just compare to a GPS speedo app on your phone or use a tomtom. Your speedo is likely at least 10% optimistic. This means you can have 90 on the clocks, feel like the fastest badass on the motorway and probably not make the threashold for a gubmint issue calibration certificate.
Bandit. does. everything.
The last post was made 9 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 78.06 Kb
