Portable OS
fatjames
PostPosted: 11:47 - 09 Feb 2017    Post subject: Portable OS Reply with quote
Hey,
Can anyone recommend a portable OS that I can boot into using USB. Once in, I'd like to copy some files from the HDD onto a flash drive.
PostPosted: 12:29 - 09 Feb 2017    Post subject: Reply with quote
Puppy linux runs entirely in RAM on just about anything (right down to a 1st generation amstrad PC from the late 80's with no hard drive) and will mount most drives if asked to. Will also boot from a CD (or floppy!). It's my goto to rescue data off a fucked PC.
https://puppylinux.org/main/Overview%20and%20Getting%20Started.htm
Also knoppix.
https://knopper.net/knoppix/index-en.html
If you want more bells and whistles. Mint will also run as a live CD/USB.
https://www.linuxmint.com/
fatjames
PostPosted: 12:45 - 09 Feb 2017    Post subject: Reply with quote
Very super helpful. Thank you kindly.
M.C
PostPosted: 01:22 - 10 Feb 2017    Post subject: Reply with quote
Knoppix was always good although I admit I've not used it in a while. I've never tried it but can't you run Windows 8/8.1 from a USB?
Derivative
PostPosted: 02:24 - 10 Feb 2017    Post subject: Reply with quote
Basically any modern Linux distribution will boot from USB into a live environment (with an install button that would produce a permanent environment on the HDD should you wish).
Ubuntu, Debian, Fedora IIRC at least had this feature last I checked.
Nerdy bits: With a bit of hackery you can usually pass a --toram flag to the kernel which will allow you to remove the usb drive once it's booted (useful if you have e.g. 2 usb ports and want to copy from one flash drive to another)
kgm
PostPosted: 10:11 - 10 Feb 2017    Post subject: Reply with quote
Knoppix is still reasonably decent except it has fully fledged compiz with flying wobbly windows and shit enabled by default. Very annoying. The --toram flag works with knoppix too.
Loui5D
PostPosted: 11:34 - 10 Feb 2017    Post subject: Reply with quote
Tails is another you could use.
The last post was made 9 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.91 - MySQL Queries: 13 - Page Size: 50.44 Kb
