GSXR 600 K6 - Throttle Body Actuator Issue
TheArchitect
PostPosted: 11:50 - 10 Feb 2017    Post subject: GSXR 600 K6 - Throttle Body Actuator Issue Reply with quote
Rode home last night, no issues and no signs of anything about to go wrong.
This morning went to start as normal and it appeared to struggle to get going. Once started, it bogged and stuttered for about 15 seconds then cut out.
Tried again, but this time it'll only start with some gas and even then really struggled to stay ticking over and cut out. Tried one more time to the same result. There was a bit more smoke than normal from the exhaust but not plumes and no burning smell either.
Battery is fine and there's plenty fuel in the tank.
One thing happened yesterday though... Where bike was parked all day, there was a steady and relatively heavy stream of water falling onto the bike over the dash and tank.
So any ideas before I start coughing up for recovery and garage costs?
GSXR 600 K6 - Stolen
MT09 - Almost stolen
Quote Me Happy
PostPosted: 11:52 - 10 Feb 2017    Post subject: Reply with quote
I'd break out the WD40 and spray and hope for starters.
jaffa90
PostPosted: 13:21 - 10 Feb 2017    Post subject: Reply with quote
Did you open the fuel cap before the problem occured?
I`m thinking of water in the tank ,more so if it was holding water under the cap.
Did the ignition switch get wet or the kill switch?
TheArchitect
PostPosted: 13:26 - 10 Feb 2017    Post subject: Reply with quote
No, after second attempt I opened to check there was fuel in there. Sloshed it around and all was OK.
I would think yes for sure. The whole dash and tank was taking a steady stream of water for probably most of the day so I'd guess some of it went over/in the ignition switch.
techsnap
PostPosted: 14:02 - 10 Feb 2017    Post subject: Reply with quote
+1 on the WD40.
My bet would be on wet electrics.
Spray round the plugs, leads etc so the WD40 can drive out the wet.
TheArchitect
PostPosted: 14:35 - 10 Feb 2017    Post subject: Reply with quote
techsnap wrote:
+1 on the WD40.
So you're saying the symptoms describe an electrical issue?
To me it sounded very much mechanical as it almost sounded like fuel wasn't getting through. The first attempt to start it just about stayed running for about 15 seconds. Second attempt barely ticked over. Third attempt - nothing.
To me it seems like it started with what fuel was left in the system and then once that was gone, it had had it.
So in fact I agree it could be an electrical issue, but one with the fueling system perhaps?
Thoughts?
Quote Me Happy
PostPosted: 15:02 - 10 Feb 2017    Post subject: Reply with quote
Coils/HT leads/spark plugs, get some WD40 in those areas and report back.
TheArchitect
PostPosted: 15:34 - 10 Feb 2017    Post subject: Reply with quote
Righto Thumbs Up
Quote Me Happy
PostPosted: 15:36 - 10 Feb 2017    Post subject: Reply with quote
Also, how do you know the battery is fine?
TheArchitect
PostPosted: 15:38 - 10 Feb 2017    Post subject: Reply with quote
well, I say fine as it turned the engine without issues Confused
PostPosted: 21:13 - 10 Feb 2017    Post subject: Reply with quote
What colour was your smoke?
jaffa90
PostPosted: 23:22 - 10 Feb 2017    Post subject: Reply with quote
Are you thinking water in the tank like me?
TheArchitect
PostPosted: 00:32 - 11 Feb 2017    Post subject: Reply with quote
Dark greyish.
PostPosted: 08:23 - 11 Feb 2017    Post subject: Reply with quote
Dark greyish.
Hmm, may have struggled to start the second time as it was overfuelling/flooded?
I.e. Started on the enrichment map, chucked a load of fuel in....stalled. Restarted on the enrichment map, chucked even more fuel in so struggled to start. I'd be expecting to see more black smoke if it was very over fuelled.
PostPosted: 08:26 - 11 Feb 2017    Post subject: Reply with quote
In a word, no.
Well not necessarily.
I would say it's more likely to be water in the switchgear/electrics than the tank at this stage. The struggling to run was down to the electrics, then resulting in an over fuelling situation in the engine, hence the smoke when it finally got going. Just my Penny Coin Penny Coin
jaffa90
PostPosted: 11:29 - 11 Feb 2017    Post subject: Reply with quote
Sounds feesable at twopence worth.
Robby
Dirty Old Man
PostPosted: 12:37 - 11 Feb 2017    Post subject: Reply with quote
Water in the fuel doesn't seem to be as much of an issue with newer injected bikes. I assume they're better sealed, and the emissions control bits make it harder for water to get in - particularly if the tank breather is going through a carbon filter.
Also with injectors you don't have a float bowl to gradually fill with water, just a fuel rail with a return back to the tank. The fuel is kept moving a lot more, so water can't settle in many places.
Fuel pump is a possibility, along with ignition electrics. Do as Joe said first and spray WD40 over anything that looks electrical. If that doesn't sort it, check the fuel pump output.
TheArchitect
PostPosted: 18:44 - 11 Feb 2017    Post subject: Reply with quote
Quick update:
Sprayed WD40 everywhere last night. In all the little crevices and anywhere there was a button or switch. Left it overnight to soak in and do its thing.
Tried to start the bike this morning and similar to yesterday it just about starts very hesitantly and only stays ticking over with some throttle. Lots of cloudy smoke. I was worried about keeping it running too long in case it causes bigger or longer lasting issues. As soon as I come off the throttle it dies.
Have arranged for bike to be recovered on Monday morning to my usual garage for their inspection and report. Have filed a report with building management at work as it's looking like the water leaking onto the bike is the cause of what ever the issue is.
Bummer really as the weather was looking decent next week.
Quote Me Happy
PostPosted: 19:02 - 11 Feb 2017    Post subject: Reply with quote
Apart from the rough running there's no knocking sounds or anything like that? Oil level etc all OK?
I'd be tempted to get on it and ride it, let the engine get hot and it might clear the water from wherever it's managed to get into. How recessed are the plugs on these bikes?
PostPosted: 19:44 - 11 Feb 2017    Post subject: Reply with quote
has it had some fresh fuel? Or have you drained bottom half of the tank(IIRC the water should settle on the bottom of the tank as it's more dense than the fuel).
TheArchitect
PostPosted: 22:05 - 11 Feb 2017    Post subject: Reply with quote
No knocking sounds that I could hear but I wasn't listening out for it either. Certainly nothing obvious.
Recently had oil and filter change and levels are good.
I'm averse to ride it just in case I cause more issues or damage something that's more expensive to replace. Have arranged recovery so will just leave it to the garage to diagnose.
TheArchitect
PostPosted: 22:06 - 11 Feb 2017    Post subject: Reply with quote
No. Not ridden it since yesterday morning when the problem first surfaced.
PostPosted: 08:22 - 12 Feb 2017    Post subject: Reply with quote
Could something have been knocked loose when you tipped off of it a couple of weeks back? (Or was that someone else?)
TheArchitect
PostPosted: 16:27 - 13 Feb 2017    Post subject: Reply with quote
UPDATE:
Just got call from garage. Problem has noting to do with the water after all.
Something about the throttle body and a butterfly valve being stuck open causing over-fueling. Apparently it's a common issue for the bike and is purely coincidence that it occurred when it did. It's been "reset" now and is running fine.
Couldn't get too much info over phone as at work, will pick it up tomorrow and get more detailed info on the issue, the possible cause and the fix.
thanks all for the feedback and info, much appreciated as always Thumbs Up
TheArchitect
PostPosted: 13:06 - 15 Feb 2017    Post subject: Reply with quote
I've updated the title of this thread to be more specific based on what I know now.
So the "fix" didn't work and again this morning I had the same issue - bike wouldn't start, then when it did it was very boggy and would cut out of not kept with throttle.
Very annoying, especially first thing in the morning when you're already running late for work. So I thought f-it and gave it some long hard revs before riding off. It seemed to get better as the bike warmed up but there were a lot of backfires.
The issue as I know it: Throttle body actuator (servo) is the culprit. It's not opening and closing the butterfly valves as it should which is causing the over fueling. I'm guessing the valves are stuck open.
The issue is probably the teeth on the servo arm or pinion are worn out.
I can't find anyone that sells the actuator on it's own, they only sell the whole throttle body unit which costs over £100 in most cases.
Does anyone know of a workaround or a more feasible solution to this issue?
The last post was made 9 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.74 - MySQL Queries: 13 - Page Size: 128.92 Kb
