Transmission noise on Honda S Wing .
Radiomax10
PostPosted: 21:47 - 11 Feb 2017    Post subject: Transmission noise on Honda S Wing . Reply with quote
I bought the scooter new in 2009 . It has now covered 8000 miles . Always serviced well and is in mint condition . From day one I was worried by a noise that seems to come from the transmission . It is worse when I accelerate hard from a low speed . Once I reach about 38 mph it gets better and when doing 45-50 or above it is fairly quiet . When cruising at a constant speed it is not really there . On overun it is very quiet . Hard to describe the noise . It is low pitched and almost sounds like the belt hitting the case in a fast rythmic way . It is at its worst when riding on a hot day . I have done a few motorway trips at 60 mph . It sounds really loud after going fast and then riding in traffic . I notice that the belt case gets pretty hot under these conditions . I took the bike back to the dealer after the first week . He rode it and said it was normal for this model and not a problem . However as time has gone on , it seems to have got louder . The engine is very quiet and runs perfectly . Top speed and power is fine . I can still get 65 mph + on the flat with no vibration .Acceleration is just as it ever was . I removed the belt cover and found very little dust inside . The belt looks perfect and I can see no contact marks on the case . There is no play on the crank / front pulley and none on the clutch bearing either . The belt is not loose and there is no evidence of cracks or fraying . Maybe I worry for nothing but this noise spoils my enjoyment of an otherwise superb and totally reliable bike . Any comments would be VERY welcome .
davebike
PostPosted: 12:08 - 13 Feb 2017    Post subject: Reply with quote
Done a fair bit on silver wings Sadly the transmission /clutch is the weak point
I suspect worn or damaged transmission rollers or pull away clutch
It is transmission strip down time be careful silver wing belt rollers and clutches are very expensive !
Dave
NC750Xdct + others at work !
[email protected]
cb1rocket
PostPosted: 18:27 - 14 Feb 2017    Post subject: Reply with quote
I belive he is referring to the S wing 125. Not the 600 silver wing.
The bearings on the rear clutch assembly is probably shot. I have dealt with 5 s-wings and they all make a racket from the transmission. Is fixable and like you says go away after speeding up as the axle and bearings run at the same speed so no bearing movement.
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
Radiomax10
PostPosted: 21:56 - 15 Feb 2017    Post subject: Yes , it's a 125 . Reply with quote
Yes , the bike is an S wing 125 cc .
Strange though that the noise was there even from new . I have removed the case and there seems to be no play on the clutch drum . If the bearings were worn , would I feel it by trying to move the whole unit . Would I feel vibration from a worn bearing ?
Thanks for comments .
cb1rocket
PostPosted: 16:49 - 20 Feb 2017    Post subject: Reply with quote
you would hear it if you spun the clutch once the bell housing is off.
Vibrations is possible but usually from a slack/worn belt
The last post was made 9 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 43.98 Kb
