help me! javascipt/css lightbox
duhawkz
PostPosted: 00:31 - 16 Feb 2017    Post subject: help me! javascipt/css lightbox Reply with quote
trying to make an image gallery and have the images pop up in a light box when you click on them
you add images to an unordered list, like so
Code:
<div id="thumbnails">
    <ul class="aClass">
        <li><div class="thumbnail-div"><a href="the full size image" title="title"><img class="portrait" src="the thumb"></a></div></li>
        <li><div class="thumbnail-div"><a href="the full size image2" title="title"><img class="portrait" src="the thumb2"></a></div></li>
    </ul>
</div>
the above code, works and all is good in the world if the line items are hard coded.
however however i am not using static content, i'm pulling the image info from an api so i have some code to handle the request to the api and as part of that a function that parses the response and display the images.
something like this
Code:
function display_images(response) {
   for (var i = 0; i < response.data.length; i++){
               // do some stuff here to extract the required info from response
      $('.aClass').append('<li><div class="thumbnail-div"><a href="' + picture + '" title="' + name +'"><img class="' + orientation + '" src="'+ thumb +'"></a></div></li>'');
    <ul class="aClass">
    </ul>
</div>
this works ok and the images display on the gallery page as expected, but the lightbox doesn't work, the thumbnail just becomes an link to fullsize image.
if i console log the html from the above .append() and manually add it to the ul, the lightbox work perfectly.
so i know a the lightbox works and the html I'm appending is correct
help it's doing my head in
Evil Hans
PostPosted: 11:01 - 16 Feb 2017    Post subject: Reply with quote
Can't see anything wrong with that. When I'm back at my desk later might fire up the PC and try it.
Are you seeing any JavaScript errors? If you've got an error somewhere else in your code it might just be that it's stopping the lightbox code from running.
Triumph Sprint ST 1050. And it's Red.
duhawkz
PostPosted: 11:11 - 16 Feb 2017    Post subject: Reply with quote
Further googling tells me its an ordering issues
https://stackoverflow.com/questions/6658752/click-event-doesnt-work-on-dynamically-generated-elements
The dynamically add bit aren't the until the to code that generates them runs
So you need to do something like
Code:
$('#thumbnails').on ('click', 'li', function(){
          $(this).lightBox ()
To register them but i can't get it to work with that either
I forgot to mention that i'm not seeing any errors in the console either so everything appears to be executing correctly
ScaredyCat
PostPosted: 15:01 - 16 Feb 2017    Post subject: Reply with quote
If you're creating the elements dynamically then you'll need to trigger the
Code:
          $(this).lightBox ()
after their creation. If you have that code ^^ at the foot of your page and are expecting it to work it wont because you haven't appended the elements until after the page has loaded and whatever triggering event has happened. I.E.
You'd have
Code:
1. Load page
2. Execute "$('#thumbnails').on ('clic.."
3. Some thing took place returning image uris
4. Execute display_images, appending li and div
What you need is
Code:
1. Load page
2. Some thing took place returning image uris
3. Execute display_images, appending li and div
4. Execute "$('#thumbnails').on ('clic.."
Depending on what you're actually doing on your page. It's going to depend largely on what is going on because if it's a one off event then just stick the "$('#thumbnails').on ('clic.." in display_images after all the work is done.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
duhawkz
PostPosted: 15:52 - 16 Feb 2017    Post subject: Reply with quote
That what i thought was happening, but I'm pretty sure i tried the above last night
I'll have another go when i get home.
duhawkz
PostPosted: 22:52 - 16 Feb 2017    Post subject: Reply with quote
Code:
   $('.clearfix').html("")
                 // do some stuff
      $('.clearfix').append('<li><div class="thumbnail-div"><a href="' + picture + '" title="' + name +'"><img class="' + orientation + '" src="'+ thumb +'"></a></div></li>');
       // moved the on click inside the display_images function after the for loop
   $('#thumbnails').on('click', 'li', function (){
          lightBox();
moving the .on() binding inside display images doesn't work either
duhawkz
PostPosted: 02:11 - 17 Feb 2017    Post subject: Reply with quote
Code:
                 // do some stuff
   $(function() {
       $('#thumbnails a').lightBox();
fixed it, this ^ was the secret sauce
The last post was made 9 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 57.85 Kb
