| rpsmith79 |
 rpsmith79 World Chat Champion
 Posted: 18:50 - 19 Feb 2017 Post subject: Honda CG 125 2004 - Charging Issues |
Completed my CBT yesterday, so decided to have a few trips round the block this afternoon on my CG to get in some practice, and after about 20mins riding, i coughed and spluttered to a halt, tried to restart a couple of times but then the battery was flat, so i proceeded to push it the remaining way home
After about 500 yards i was knackered, so thought i'd give it another try, and low and behold it fired up again, so i rode it the short distance home, only for it to die on my again, and this time the battery was totally flat, would even turn over
So, into the garage, stick the battery on charge for 10mins, and it fires up again fine, so all is good there, but when checking out the voltage, it was around 12.5V when the bike was off, and then 11.5-12.0V when running, so something is amis with the charging circuit, but i'm struggling to get much further as to whether it is regulator/rectifier or stator related
I have done the rectifier diode check, and that all seems good, then i did the stator resistance check, and that shows resistances within the tolerances of the Haynes manual, so i'm still non the wiser........
......... anyone got any ideas what to try next before i start playing parts darts and replacing parts willy nilly |
| neptune8 |
 neptune8 Nova Slayer
 Posted: 20:12 - 19 Feb 2017 Post subject: |
Use your multimeter to check the wiring between the alternator and the rectifier/ regulator for continuity. Also check that the connections at the end of those wires are clean and sound, a dose of WD40 would not hurt. Incidentally, the power for the spark plug does not come from the battery on CG, but from one of the alternator coils. Earlier CGs like mine , which have both kick and electric start, can be started with a flat battery, or no battery. So if the battery is flat, you should still be able to bump start it. So although it looks like you do have a charging problem, that should not IMO cause the engine to die. As yours is a later model [which model?] It could be different tpo mine, so check the wiring diagram. ____________________ Enjoy yourself, its later than you think |
| neptune8 |
| rpsmith79 |
 Posted: 20:29 - 19 Feb 2017 Post subject: |
| neptune8 wrote: | Use your multimeter to check the wiring between the alternator and the rectifier/ regulator for continuity. Also check that the connections at the end of those wires are clean and sound, a dose of WD40 would not hurt. Incidentally, the power for the spark plug does not come from the battery on CG, but from one of the alternator coils. Earlier CGs like mine , which have both kick and electric start, can be started with a flat battery, or no battery. So if the battery is flat, you should still be able to bump start it. So although it looks like you do have a charging problem, that should not IMO cause the engine to die. As yours is a later model [which model?] It could be different tpo mine, so check the wiring diagram. |
Cheers Neptune, i will try those things out tomorrow
It was odd though that after pushing the bike for a few hundred yards it did fire up again and ran for a good few mins till i got it home, then died again
Oh and mine is a CG125-4, no kick start, just electric
I'm ok with the mechanical side of things (already changed the head gasket and sorted a seized swingarm), but i'm not so good on electrics, and wouldn't even be sure what i would be looking for in the wiring diagram to know if it needs the battery or not to start |
| rpsmith79 |
| neptune8 |
| rpsmith79 |
 Posted: 21:08 - 19 Feb 2017 Post subject: |
Yeah that makes sense
Cheers Neptune  |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 00:44 - 20 Feb 2017 Post subject: |
You are chasing a red herring assuming this is a charging issue.
CG's have a self exited 'magneto' ignition, which is totally independent of the battery. As long as the engine is turning, it should make volts to make sparks for the engine.
The 'generator' has three windings on the stator; one powers nothing but the ignition; one provides unrectified, unregulated volts direct to the headlamp.... which when the lamps are 'off' is redirected to the regulator to help charge the battery; last provides volts direct to the regulator to charge battery.
Battery ONLY actually provides power to the indies, stop lamp and horn, and significantly on later models the starter motor....
Make sense so far?
SO.. start at the top... dont do diagnostics by random or voodoo!
Your bike conked out.
With self exited ignition, if the engine was running.. then it should keep running... and if you had a problem with the battery or the generator, your headlamp might get dim, your horn might not work, your indicators might not flash... BUT the engine shouldn't conk out.
SO! There is one problem. WHY did it conk out?
Fact it started in the first place, implies there's the ingredients for life, but, in use 'something' went missing.... then after some time... came back all of its own accord, when it re-started.
Oh-Kay... well, I could take a pretty wild stab in the dark and suggest your tappets are probably wildly out of adjustment, and when warm, the clearances opened or closed up enough that the valves were either not opening or staying closed.... BUT, that is bordering on voodoo by ESP.... so do the job properly, and diagnose by logic!
First up; pull the battery, check the electrolyte level, and put it on a trickle charge. Better still, eliminate 'dumm' questions, order a new one and put that on trickle charge.
Whilst that's charging, do a FULL and proper service on the engine. Change the oil. replace the spark plug, and adjust the tappet clearances.
Find another 12v battery... one from a car, preferably not still attached to a car, or if so, certainly not with its engine running... and put the CG's battery terminals on jump leads off it, so you have an excess of amps to spin up the starter motor, and NOT deepcycle the bike battery before its given a chance.
Remember, CG's ignition is self exited, on start up, battery isn't providing electric for sparks; battery is just providing electric to spin the starter, hence the crank, hence the magneto, and THAT is making the electric for the sparks... SO if the engine doesn't get spin up quickly enough, you don't get the volts to make sparks... if so.... this MAY be a battery problem... may be a magneto problem, BUT could also be a starter motor problem...
Starter motor's draw big amps... nominal rating of a CG battery will be around 6Ah... which means it can accept or deliver 6A for one hour... if 'good'... starter motor will draw something more like 60A, which is why its powered on its own thick cable direct from the battery, switched by a solenoid... battery 'can' deliver that many amps, briefly, for maybe 1/10th of an hour, 6min... in theory...
In practice, that rate of discharge will make the battery 'boil' the electrolyte, and it's volts will drop, in maybe 2-3 min... leave it to cool and the electrolyte will 'settle' and you'll get volts back, and might be able to start again, and get another minute or so from it... BUT, this is 'Deep-Cycle-Discharge' and repetitively discharging the battery that heavily that often, WILL kill the electrolyte....
Little bikes have little battery's, and marginal charging systems... and the CG suffers from not being designed to be an electric start motorcycle, back in 1976, it has been 'adapted' to make it e-start...
NOW, fresh off CBT... first; I doubt very much you have been thrashing the thing very hard, and I would suspect, from comment you are not a fresh-faced teen ager, but an existing car driver... in which case very very likely car driver habbits have added to new rider ones, and you have been loath to let the motor 'scream' to your ears and have been using low revs and short shifting, using higher gears, and low revs, in your brief ride, which wont see the crank hence magneto turning too fast for very long and best able to provide the volts to charge the battery... which, will have been pretty well depleated by 'first start'.. and more so, I suspect from lack of practice in starting procedure.... especially so if you are a car driver used to fuel injected cars that start on the key, and have not had to fathom a manually operated choke... which is a bit wampy on the CG.. THEN following 'advice' in the class-room, and the safety schpiel over 'conspicuity', I'll lay odds on you riding with the headlamp 'on' all the while.... so the battery will only be gettiung charge from that one winding, and not given the 'spare' from the headlamp.
Hint: If it aint dark... dont use the headlamp! for conspicuity, if you want to light up the headlamp bowl, use the side-light only, on this bike.
However... it IS a common niggle; learners dont give the bike best chance for the battery to charge, from starting clumsiness, through riding inconfidence, and using headlamp as Day-Time-Running-Light, and often lots of clumsy clutch control and 'stalls' and re-starts, hammering the battery on the e-start....
Bike batteries, dont last.. they are small, and the amps starters suck is much bigger in relation to their capacity than on a car; they tend in regular use to only have a 'life' of around two years, rather than four... but, this sort of learner use, and repetitive deep-discharge on the e-start, marginal charging and riding less conducive to giving it best chance of ever being fully charged, and then likely periods of 'lay up', they can be dead a lot sooner... and on a budget bike like teh CG bought on the legend they are 'cheap' and 'indestructable' they are likely NOT to get new ones very often.
So.. good chance your battery is a dodo... but, whether it is or not, or if you get a new one... you DONT use it to do diagnostics, deep-discharging it on the e-start to spin the motor over to test sparks or compression, or you are as like to reduce whatever life it has before you start... HENCE doing the diagnostics off jump leads from a car battery....
BUT... car alternators deliver perhaps 17.5v regulated... IF the car the battery belongs to is running... bikes generator delivers unregulated volts, that are regulated at aprox 13.5v.... slap jump leads off a car on to a bike battery, and the 17.5v the alternator delivers, will get regulated by the bikes regulator... which is NOT designed to ever see that many volts, very often, or for that long, and it CAN fry them.. quickly... SO, you dont jump off a car with the engine running....
BUT car battery should a) be fully charged! b) have excess amps to power starter for diagnostics, c) do it without such risk of deep-discharge damage d) do it for longer without going flat and having to be recharged!
Hint: if doing lots of diagnostics; charge car battery by running car engine periodically BUT, remove jump leads from bike before starting car!
This, though is advice behind suggestion to get a new battery; they are a service spare, and it is likely the bike will need one, sooner or later, it is likely the battery is well past its prime, and if also likely that effing about trying to fault find will kill it if it isn;t already on the critical list.
Oh-Kay.. so tappets adjusted, spark-plug replaced, and a 'good' power supply for the starter motor.... spin it up, spark plug out the hole, metal of plug given a good earth, either rested on an engine fit, better (safer!) if held in the croc clip of another jump lead, the other end clipped to known good earth on the frame, or battery.... and look for healthy spark across the gap.
While plugs out... and motor spinning... check compression... if you have a compression tester, this is useful, but make sure that the throttle is wide open, and engine can actually suck in something to compress. If not, same deal on the throttle; but rule of thumb is if you can hold your thumb over the spark plug hole... you probably don't have enough compression!
If you have a healthy spark; and cant keep a thumb over the hole; have adjusted tappets and changed the oil... you are probably good to go.... fit battery and 'go'...
Any faults or problems you have after... are at least base lined... BUT good chance you wont have any.
IF with the motor serviced and you have trouble re-starting.... remember.. BEFORE diving in to blame the bike, and pulling electrics to bits or tearing carburettors apart..... LEARNERNESS... if you are using DTRL's, if you are doing lots of starts and few miles, and aren't letting the engine breath, short shifting, using gears not revs on the road... you WONT be giving it a chance to charge..... so start there again!
On topic of short shifting... DONT DO IT... just dont. just because you have five gears doesn't mean you have to.
That little motor only makes about 10bhp on a good day, and that only at 10,000rpm! under 3K you are probably shifting at you likely have less power than a moped! enough to do 30mph, even in top gear... BUT, you are denying yourself 'throttle response' in the process, and making the engine labour. you are not saving fuel or wear and tear.. power is torque times revs, IF you need 3bhp to go 30mph, you need 3bhp.. if you dont use the revs to get it, you have to use more throttle to get more torque, so you are putting just as much 'strain' on the engine, and using just as much fuel.. and its an 'ecconomy' 125 ffs, its not like it's drinking the go juice at a rate that has opec Sheiks wringing thier hands with glee to start with! Use the revs NOT the gears, give it a chance to charge the battery; give your-self a chance to change speed, on the throttle and have that throttle response to do so, AND save so many oportunities to muff stuff up having to make so many gear changes so often.... you WILL ride more smoothly NOT changing up, demanding you have to change back down again!
And dont go chasing re-herrings when you have a problem.. and remember.. whilst its an old learner bike, and they do tend to suffer... there's as much chance you are doing as much wrong as the bike at the moment!
And 'this' is a non problem... in which you are as to blame as the bike, and theres absolutely NOTHING wrong with your reg/rect, or your magneto... there may... BUT, there's definitely not enough to say so from the symptoms, and an awful lot to suggest you look elsewhere first.
DONT do diagnostics by random or vooddoo! Get the book and follow the logic, and base line 'problems' from the top eliminating variables starting with the simple... and remember, simplest, at the moment is probably the user  ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| rpsmith79 |
 Posted: 08:17 - 20 Feb 2017 Post subject: |
Cheers Tef, all good info
On the subject of running with the headlight on, unfortunately i have no choice over that matter AFAIK it can't be turned off, i only have a dipped/full beam switch. Saying that, i have replaced the old incandescent bulb with a more modern halogen bulb, so this could be having a bigger draw on the battery
When you say tappets, i assume that is the same as valve clearances, but yes i will give that a try too, again it would make some sense as i guess my time pushing the bike would have allowed the engine to cool and valve clearances relaxed, hence why it started and ran again briefly
And yes, you are correct, long time car driver (20 years) so have been short sifting and using lower revs
So are you saying that the stator/magneto will not actually charge the battery until over about 4000 rpm, as stated above, the battery on its own was reading 12.5V, and when running (on idle) was only around 11.5V, do i need to build the revs up to 4000rpm to see if that alters the voltage?
| rpsmith79 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 10:54 - 20 Feb 2017 Post subject: |
| rpsmith79 wrote: | Oh, and for reference, here is the wiring diagram for my bike | Old eyes.. looks like its got a battery independent self exited ignition, CDI & coil energised & fired by seperate coil and trigger in the mag.
does look like it has a 3phase genny, with the lamps powered off regulated battery supply rather than AC direct though.
| rpsmith79 wrote: | On the subject of running with the headlight on, unfortunately i have no choice over that matter AFAIK it can't be turned off, i only have a dipped/full beam switch. |
that's a bugga.. some did have hard wired headlamps.... easy enough to add a switch though....
| rpsmith79 wrote: | Saying that, i have replaced the old incandescent bulb with a more modern halogen bulb, so this could be having a bigger draw on the battery |
Err... yeah.. and quite a big one of its hard wired....
Its probably also NOT doing very much of very much use for you, other than robbing amps... brighter light doesn't mean 'better' light.
And old track lore; before looking for more than standard, make sure you have all you should AS standard.
Good chance that more lumins being chucked out by modern, higher wattage bulb are merely compensating for a cruddy old reflector not chucking all it should through the lens, and that, old yellowed and etched, is not letting all it should out to the road.
Long hard experience trying to get better lamps, its not about how many watts you got, its about getting them going where's most useful. Headlamp lens, headlamp reflector, keeping them clean and adjusting to point them in the right direction is far more useful than big watt bulbs.
Tendency, and another car habbit is also likely to be you try 'over driving' the lamps, and are peering into the gloom at the edge of the beam, trying to see into the dark beyond.... and riding to that vanishing point....
Back off, slow down if needs, BUT pull your gaze BACK to that bit of road where the lamp IS actually lighting up tarmac! you know the bright bit you are 'over looking'.....
Add more watts, you could have Webly stadium's flood lights on the front and you would STILL be peering into teh gloom beyond what they are lighting up!
And used to two, large, well spaced, and powerful car lamps.... yup... a single diddy little motorbike lamp with barely half the watts WILL seem to lack light!
Step onto a big bike, with a single lamp, or even a pair of close spaced ones, the same 'apparent' lack of lighting will be your perception.. BUT it is your perception that is the problem... more than the bikes inherent lack of lumins.
| rpsmith79 wrote: | When you say tappets, i assume that is the same as valve clearances, but yes i will give that a try too |
Yup
| rpsmith79 wrote: | So are you saying that the stator/magneto will not actually charge the battery until over about 4000 rpm, as stated above, the battery on its own was reading 12.5V, and when running (on idle) was only around 11.5V, do i need to build the revs up to 4000rpm to see if that alters the voltage? |
Not entirely... BIKE CONKED OUT.... bike restarted... SO it had electric for sparks when it was running before it concked out... it had electric for sparks after it conked out and restarted.....
Blaming electrics & charging is just random.... WHY did it conk out?
Eliminate variables. ANYTHING could have caused it to conk out, from an your 'new' headgasket being fitted wrong, or breaking down under load, or needing as they do, to be retorqued after first runin, to retension them where use will have made them 'settle' as bolts and bits expand and contract. Could be the carburettor adjustment, mixture, out, and or the idle speed, effectively dropping out as motor gets warm. Could be the ignition coil breaking down when hot; the spark plug getting wispered by burning oil. could be the cylinder or piston rings are worn out and you are loosing compression under load and more when hot; could be... could be.. could be a dozen or more things from the simple or stupid, through to the dire and expensive.... BUT because, as you aught to expect... starter slows and stops working trying to get it restarted.... and goes flat.... you have dived straight in with presumption that it must be because the battery isn't being charged!?!?! WHY?
Battery WAS charged.... it started the first time.... once started, even if its a battery fed ignition... crikey I can ride from Leicester to Leeds on a battery that's not being charged, with the juice the ignition sucks!! {You can ask me how i know that, if you must!!!!!}
You say you tested the geny and you are getting 11.5v on the terminals at idle... yup, it will go up with revs... and yup that does sound a little low, so is the idle set too low?
BUT, what state was the battery in when you tested it? If you had just started the engine, then that will have walloped a load of charge from it, and the terminal voltage would probably be dropped by the resistance the battery is putting on it whilst trying to such charge back in.... which with hard wired headlamp its probably not got best chance to do.... BUT you have volts... genny is chucking out charge... and enough to power sparks, as engine is still running... WHY would you presume that there 'must' be a problem here? and not blame the battery, or look for anything else that could cause the bike to conk out?
THAT is what I am saying... you have latched, randomly onto one possible cause of the problem, that quite likely just ISN'T....
If battery is knackered and not taking all the charge it should... then you will likely get low terminal voltage on it, as all the cells wont be pulling thier weight... it does not mean that the genny isn't making them volts.... or that the genny isn't making charge, or that its not making enough charge, or that the regulator is somehow robbing you of charge... its one link in the system and of the usual suspects the battery itself is the most likely, not the reg/regs, despite Hondas poor reputation on them {ask me again about Leister to leeds!!!!} or the generator.
LOOK at the facts;
1/ you had a bikes engine 'conk out'... consider that and ALL the possible reasons that might happen
2/ you had a flat battery... consider that and ALL the reasons that might happen...
Dont put the two and two together and make five, worse, decide that because the answers five, that there has to be a Jackson brother involved!!!!
Its not logical captain!
And its leading you into a mire of fault NON finding... voodoo diagnostics!
Work on the known.. make known the unknown, and when you have eliminated the impossible, all that is left is the answer, no matter how improbable....
Tappets, & oil change, new plug, preferably 'new' battery, check sparks on 'safe' supply to spin up motor.... check compression... recheck cylinder head torque (I missed that one earlier), and start from a known base line and DONT DO VOODOO.. don't guess, test, without making leaps of two plus two must make a Jackson brother, because that happens to be all you can see at the time! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| rpsmith79 |
| rpsmith79 |
| rpsmith79 |
| jaffa90 |
 jaffa90 World Chat Champion
| rpsmith79 |
 Posted: 19:06 - 22 Feb 2017 Post subject: |
Well i don't know if it's solved the original issue of the bike cutting out, but after replacing the reg/rec with a 2nd hand one off of eBay, my charging problems are no more
Now i get a healthy 13.5-14.0V when the engine is running
Just need to wait till the weekend (too dark to ride it when i get in from work) to see if i have solved the original issue
Fingers crossed
Saying that, looking again at the wiring diagram, all the power from the stator goes into the reg/rec, then to the coil, so if the reg/rec was at fault, it would surely have implications on keeping the engine running
Oh, and thanks everyone for your help, learnt quite a bit already from this forum, cheers |
| neptune8 |
The last post was made 9 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 2.25 - MySQL Queries: 13 - Page Size: 117.32 Kb
