| rpsmith79 |
 rpsmith79 World Chat Champion
 Posted: 18:59 - 21 Feb 2017 Post subject: Valve Clearance Issues - Honda CG 125 |
Following on from my recent topic on what i thought was electrical issues with my bike, i have followed the advice given by Teflon Mike (yes i really did read through all hos posts ) and i seem to be having issues setting the valve clearances
Let me elaborate
I got the rocker off, turned the engine to TDC, loosened off the locknut and adjusted the clearances, they were quite a way out it seemed as i had to turn them out quite some way
After that i turned the engine over again 1 full turn, and the clearances were now massive (a good few mm each), so turned the engine 1 full turn again and they were back to the proper clearance (0.08mm), 1 full turn again and they are massive
What is going on.......................... HELP PLEASE |
| Baggyman |
 Baggyman Crazy Courier
| rpsmith79 |
| Teflon-Mike |
 Posted: 19:53 - 21 Feb 2017 Post subject: |
Without the book, you would check the tappets on the rock.. that is with the piston at TDC on the compression stroke, when both valves aught be completely closed.
Book instructions to use timing marks will be more scientifically finding same point in the combustion cycle.
One full crank rev will take you from TDC on compression, to TDC between exhaust and induction, when both valves will be open.. exhaust about to close, inlet having started to open, and you'll have pressure on the valve stems from the cam, and you 'aught' have no clearance gap on either.
Four 'strokes' to a combustion cycle.... piston strokes; one up, one down per rev, two revs per cycle, four strokes.
Cam shaft is driven at half crank speed so it revolves once to complete one combustion cycle, for two crank revs, four strokes.
Make sense?
Have you re-checked cylinder head stud torques, post replacement and 'first run'? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| rpsmith79 |
| neptune8 |
 neptune8 Nova Slayer
| Baggyman |
| rpsmith79 |
 Posted: 21:18 - 21 Feb 2017 Post subject: |
Cheers everyone, like they say, every day is a school day  |
| Robby |
 Robby Dirty Old Man
| rpsmith79 |
The last post was made 9 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
