Mig welder part identification help
andy_uk
PostPosted: 07:29 - 23 Feb 2017    Post subject: Mig welder part identification help Reply with quote
So, after a year of tripping over my broken mig welder, I decided to see what was wrong with it...
It appears to be the lead that goes from the +ve output of the rectifier to the torch connector has failed.
My question is...
What is it made of?
If you look at the pictures it seems to consist of a grey powder in a rubber sleeve.
Is it some form of thermal fuse? (or has the cable seriously oxidized!)
Could I just replace it with some 25mm cable?
PostPosted: 08:28 - 23 Feb 2017    Post subject: Reply with quote
I would just replace it with some decent comparable CSA copper cable.
Triumph Trophy Launch Edition
bugeye_bob
PostPosted: 08:38 - 23 Feb 2017    Post subject: Reply with quote
as said a 10 mm copper.
https://www.amazon.co.uk/Welding-Cable-Battery-Flexible-Welder/dp/B00E1GZRZC
and a couple of lugs.
A100man
PostPosted: 11:58 - 23 Feb 2017    Post subject: Reply with quote
During copper shortages wires/cables were sometimes made of aluminium - perhaps this is a case in point. As advised good thick copper cable will be fine.
andy_uk
PostPosted: 13:37 - 23 Feb 2017    Post subject: Reply with quote
So...copper cable it is then.
(Me being the typical tight yorkshireman may just use a short length of meter tail which I have in my bit box.)
Thanks for the help, 'tis appreciated.
natefz6
PostPosted: 14:46 - 23 Feb 2017    Post subject: Reply with quote
My first thought was aluminium, I used to deal with some shoddy aluminium cables in telecoms. If you so much as coughed near them after a few years in the duct it was enough to break them. Sad
"no I didn't steal it that's just the way I ride"
WD Forte
PostPosted: 14:51 - 23 Feb 2017    Post subject: Reply with quote
A meter tail should do nicely providing its crimped properly
I've used old jump leads for similar.
Good ones, not the cheap skipping rope things you get from poundshops
bikers smell of wee
The last post was made 9 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 51.05 Kb
