Suzuki Bandit 650s in-tank fuel filter
steve_
PostPosted: 13:19 - 25 Feb 2017    Post subject: Suzuki Bandit 650s in-tank fuel filter Reply with quote
Hello.
I have no power after about 6k revs and I'm struggling to get over 70mph.
After lots of forum search i found posts and videos saying that there is an in-tank fuel filter (like a tea bag) that needs cleaning and that should solve the problem.
I've just taken my tank off expecting to see a fuel pump and filter, and I don't have one!
Also I was expecting to find the primary fuel filter under the fuel tank but there isn't one there! I was expecting it to be connected to the pipe with the pink dots. That pipe runs into the carb.
I've attached some pics.
Thank you for any help.
Steve
jaffa90
PostPosted: 13:35 - 25 Feb 2017    Post subject: Reply with quote
If it`s F.I. then it needs a pump to pressurize the system.
Have you any pump noises when switching on or does it have carbs?
steve_
PostPosted: 13:44 - 25 Feb 2017    Post subject: Reply with quote
Hi Jaffa.
It has 4 carbs.
steve_
PostPosted: 15:10 - 25 Feb 2017    Post subject: Reply with quote
I've just got hold of a manual, I'm definitely missing a main fuel filter!
Should I clean my carbs ASAP? Could this have done any damage?
Thanks.
jaffa90
PostPosted: 15:54 - 25 Feb 2017    Post subject: Reply with quote
The filter should be at the top of the tap inside the tank, you may have a vacuum pipe attached to the tap as well as the fuel pipe.
The vacuum lets the fuel pee out when the engine is running.
Have you got a good fuel flow if you suck the vacuum pipe and holding the fuel pipe?
You may have a PRI position for the tap, this bypasses the diaphragm vacuum part tap opening.
The last post was made 9 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 42.15 Kb
