Author |
chris-red |
Back to top |
chris-red |
Back to top |
pepperami |
pepperami Super Spammer
Back to top |
chris-red |
Back to top |
stinkwheel |
Posted: 12:42 - 20 Feb 2017 Post subject: |
pepperami wrote: | Just looked at the video of the indicators.
They seemed a bit quick?, just a thought. |
I watched it too. 102 flashes/min. Should be between 60 and 120fpm for the MOT so all gravy.
I really like that plumbing olive bodge.
Now. Next thing to do is find a way to prevent the pin rotating in the lugs and wearing your olives, you really want it so the stand has to pivot on the (greased) pin.
Not sure how the pin's retained. If it's a split pin, use a bit of stiff wire (bicycle spoke is great) instead and twist/hook the long end round something. The lugs the stand return spring hooks over are usually good. If it's circlips, might even be worth drilling the pin and lockwiring it.
Did it on my enfield, they're really prone to the same problem. I did the spoke trick on mine and while I've just had to replace the stand, it's because it started to buckle, the holes in the frame are still nicely circular.
https://i48.photobucket.com/albums/f216/stinkwheel/distributor/Image001.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
chris-red |
Posted: 13:08 - 20 Feb 2017 Post subject: |
stinkwheel wrote: | pepperami wrote: | Just looked at the video of the indicators.
https://i48.photobucket.com/albums/f216/stinkwheel/distributor/Image001.jpg |
Good should cheers ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
Back to top |
pepperami |
Back to top |
chris-red |
Back to top |
chris-red |
Back to top |
pepperami |
Posted: 15:39 - 26 Feb 2017 Post subject: |
Are you running it on pre-mix or separate via the oil pump?
Could there be a leak to do with this?
Still a cool thread ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Back to top |
redeem ouzzer |
redeem ouzzer World Chat Champion
Back to top |
chris-red |
Back to top |
ride_to_die |
ride_to_die Crazy Courier
Posted: 12:46 - 28 Feb 2017 Post subject: |
Project coming along nicely ____________________ I'm not here for a long time, I'm here for a good time. |
Back to top |
chris-red |
Posted: 19:18 - 09 Apr 2017 Post subject: |
Had a bit more time to fiddle Yesterday I'm adjusting to working on a patio, I bought this for £30 on eBay and I'm chuffed with it it does make things easier.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_094546_zpsa5skfr4d.jpg
I was hoping to get the thing finished but was thwarted by a sprocket carrier bearing that was knackered.
I need the rear wheel in to put the new chain on to tighten the front sprocket to put the side engine casing together. I could get round it but I couldn't be arsed buggering about I'm not in a rush so I'll wait new bearing has been ordered anyway.
The rear brake was pretty dirty and had some corrosion on the drum so that might be why it was a bit grabby it got a thorough clean.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_094554_zpsbkjwkmkb.jpg
The sprocket carrier was equally as filthy.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_094602_zpsu5t2pmqr.jpg
I also got to use my house warning present from my dad for the first time...
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_095405_zpsd8kghx4n.jpg
Not the spindle, it was fucker to get out, it wasn't far off seizing it was bone dry.
The rim cleaned up well, and you can see several marks of a quality tyre
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_101107_zpshgcpilub.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_100335_zps2el1ooqg.jpg
I got to use my* new very expensive professional caliper for the first time to measure the bearing.
*I found it when we moved, I asked my missus about it she said I "My dad got it from work for me to borrow when I was doing my dissertation(on teeth)" Do you want it? I asked, "Nah you can have it" I looked it up they are like £120 new.
I always wondered now my dad ended up with so money high end tools considering he is tight as a ducks arse, I guess you just acquire them, I got this and I was given a Fluke meter That is about £300 worth recently!
I have some more photos and a video but I'm using my phone to watch the GP ATM I'll upload them later ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
Back to top |
stinkwheel |
Back to top |
chris-red |
Posted: 23:20 - 09 Apr 2017 Post subject: |
stinkwheel wrote: | chris-red wrote: |
Also I didn't mention or photograph. After the last stint the join in the exhaust was wobbly, without any real effort I managed to pull the front section off. I need to remove the castle nut from the back section, but it is seized solid. I took to my dad's to use the vice but long short should I haven't done it yet.I hope to do it during the week. |
Lots of heat directly on the castle nut. If it doesn't loosen it, you might get some flame-organ action anyway. |
I forgot to mention i had a good go at this a week or 2 back, plenty of plusgas and heat it didn't budge the best thing i could find to turn it was a file it is about 18" long and about 1/4 thick. I put it between the crenallations of the nut and put a decent amount of force through it. It didn't budge and I could feel the file starting to flex so I gave up. The plan was to cut the nut off i had a replacement from the job lot of spares I bought. I think I paid £20 for the lot and the nut is £20 new so it paid for itself! I ordered so 1mm cutting discs for the grinder to do the job but hadn't had a chance to get back to it untill Tuesday.
Long story short, my mate had to drop a ladder he borrowed from my dad (it was actually his blow torch i borrowed too) I said I was going anyway so he came with. I told him what I was gonna do and he asked if I was sure it wouldn't undo. Smugly I said "Be my guest", he is half the size of me so no chance it would budge. He put it in the vice picked up the same file as I had and tried to undo it... With minimal effort it slid off! It's a weird feeling being simultaneously annoyed and happy! I can only assume the plus gas had had more time to work. It's all back together now with fresh gaskets and plenty of copper grease.
I have a spare exhaust that is ratty I'm going to practice on it with my welder to see if I can use it to sort some of the holes. The one on the bike isn't bad but it has 5-6 holes that will need to be addressed. Exhausts for these in reasonable nick are rare. Unless you go for a spanny, but they cost about what it is worth, also the bike is for my missus who has never ridden before the last thing she needs is a sharp power band. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
Back to top |
chris-red |
Posted: 15:51 - 10 Apr 2017 Post subject: |
https://www.youtube.com/watch?v=E5M0_xtHVHA
I R TUNING MASTA
The audio quality makes it sound ropey but it is smooth as silk.
The idle is back to a sensible 1200 now. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
Back to top |
The last post was made 7 years, 56 days ago. Instead of replying here, would creating a new thread be more useful? |
