| Tigerlea |
 Tigerlea Nitrous Nuisance
 Posted: 13:23 - 02 Mar 2017 Post subject: Bent rear brake pedal |
A couple months ago I took my not-so-new but new-to-me bike into a 'proper' Ducati dealership to have it looked at, as it turns out the previous owner didn't much care for it and it needed a full service. A few hundred pounds later and it rides so much better, but a few things had been pointed out to me that I couldn't justify paying for at the time.
One of these things is the rear brake pedal being bent. It's basically at a 90 degree angle upward. I'm still able to use it, and honestly hadn't even realised it was wrong (how unobservant ) until it was pointed out.
Short of replacing the pedal ('cuz, monies) is there a way to bend it back into position? I'm worried doing so will weaken the metal. Do I need to bite the bullet and buy a replacement?
After sitting on a bike without a bent peg I realised how much safer it'd be to have a proper brake pedal where it belongs  |
| Islander |
 Islander World Chat Champion
| chris-red |
| kgm |
 kgm World Chat Champion
| chris-red |
| stinkwheel |
| Daz1245 |
 Daz1245 Renault 5 Driver
| Nobby the Bastard |
| iansoady |
 iansoady Borekit Bruiser
| tom_e |
 tom_e Brolly Dolly
| chris-red |
| chris-red |
| tom_e |
 tom_e Brolly Dolly
 Posted: 12:32 - 03 Mar 2017 Post subject: |
Missed that bit, I'm blaming the 2 hours sleep I got last night and a lack of coffee. |
| Tigerlea |
 Posted: 13:49 - 03 Mar 2017 Post subject: |
I'll have a look when I get home whether a magnet sticks or not – I believe it's alloy but would be good to know for sure.
I had been contemplating replacing both brake and gear shift pedals with aftermarket parts, but I'm finding it surprisingly difficult to find bits
Thanks for the advice. I found a diagram of someone who replaced all the brake bits that left me feeling intimidated. Seeing as I've never done anything mechanical on a motorbike I'm debating whether it's a good idea to let this be my first thing.. |
| Fizzer Thou |
 Posted: 14:59 - 03 Mar 2017 Post subject: |
| stinkwheel |
 Posted: 15:37 - 03 Mar 2017 Post subject: |
If it is alloy, just replace it. It's tricksy stuff once it's been bent because metallurgy.
It CAN be straightened but it needs a huge amount of heat to make it pliastic (but not too much, a tad too much and you have a puddle) and also needs to be stress relieved after. There is a high risk it'll break in use unless this was done very well. I've done handlebar brake/clutch levers but not a rear brake lever. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mkjackary |
 mkjackary Nitrous Nuisance
| Tigerlea |
| Islander |
| tom_e |
 tom_e Brolly Dolly
| Tigerlea |
| BumpingUglys |
 BumpingUglys Trackday Trickster
 Posted: 19:43 - 06 Mar 2017 Post subject: |
A decent second hand lever will probably run you £20-30 on eBay.
It's a pretty simple job that'll take a half hour at a very careful pace. The hardest bit is getting the spring bedded correctly. It can be a bit fiddly so you'll probably want to remove the entire hanger first.
Caveat: I've done this on the 695, not the 696, but they look very similar.
Diagram:
https://i275.photobucket.com/albums/jj318/tk3445/M696_09_F_4_6_00_29_1_1.jpg ____________________ Ducati M695 |
| Pete. |
 Pete. Super Spammer
 Posted: 21:43 - 06 Mar 2017 Post subject: |
You have to be very careful bending ally as Stinky said. Also, I would usually bend it cold then if it snaps or starts to tear change it for another. The different alloys have huge variances in ductility and even moderate heat can alter the metallurgical properties significantly.
I have taken a piece of nice ally that turns well in the lathe, welded it then found that it can no longer be machined without looking like it's been worried by a dog with metal teeth. ____________________ a.k.a 'Geri'
The last post was made 9 years, 84 days ago. Instead of replying here, would creating a new thread be more useful? |
