Best chain lube?
Chris45
PostPosted: 23:10 - 02 Mar 2017    Post subject: Best chain lube? Reply with quote
Need some opinions on what you think the best chain lube on the market is at the moment. Need it to stick to the chain and not splattered all over the rear wheel etc.
Cheers.
Chris
InverNessy
Pjay
PostPosted: 00:13 - 03 Mar 2017    Post subject: Reply with quote
Old engine oil.
jaffa90
PostPosted: 00:20 - 03 Mar 2017    Post subject: Reply with quote
Old gear oil. Razz
PostPosted: 02:27 - 03 Mar 2017    Post subject: Reply with quote
WD40 Razz Tut Tut
Northern Monkey
PostPosted: 06:55 - 03 Mar 2017    Post subject: Reply with quote
New engine oil
owl
PostPosted: 08:46 - 03 Mar 2017    Post subject: Reply with quote
Chain Lube!
chain lube and cleaning
Chain lube question
what do you all use to lube the chain...halford any good
List goes on ... try that thing that says search at the top, believe it or not someone has asked this question before.
Observation is the greatest source of wisdom.
weasley
PostPosted: 14:43 - 03 Mar 2017    Post subject: Reply with quote
Fazer. wrote:
Old engine oil is just as good but it's very messy.
...and possibly a little bit carcinogenic.
RhynoCZ
PostPosted: 16:01 - 03 Mar 2017    Post subject: Reply with quote
If you use engine/gear oil, most of it will end up on your jacket. Razz
Pjay
PostPosted: 16:23 - 03 Mar 2017    Post subject: Reply with quote
Putting it on your chain is hardly exposing you to dangers.
Old engine oil is fine if used sparingly, so as not to cause splatter.
Chris45
PostPosted: 16:41 - 03 Mar 2017    Post subject: Reply with quote
Which is exactly what I've been doing. However it would be great if there was a product which lubed the chain and didn't fling half the worlds oil output over the back wheel and tyre!!
Pjay
PostPosted: 16:43 - 03 Mar 2017    Post subject: Reply with quote
I put some on a rag and wipe the chain over with the rag. If it's splattering, you're using too much.
J4mes
PostPosted: 16:47 - 03 Mar 2017    Post subject: Reply with quote
I dribble a load on a car wash sponge ( the cheap shite ones that are 4 for £1 or whatever) and then you can regulate how much you put on the chain, as well as mop excess up.
Can't say I've ever flinged it up the back wheel, over my jacket, covered the moon in it or anything like that. Thumbs Up
Baggyman
PostPosted: 18:18 - 03 Mar 2017    Post subject: Reply with quote
Clearly a gap in the market but cannot decide whether to call it "Oilpal" or "Chainpal"
I have a £20ish Loobman on the way. Will report back when I have it installed and working -
now...."Loobpal". That would be a good name
Old fart
Baghira, modded GS1000 and the T150 I bought in 1978 when I was 21
zark
PostPosted: 22:49 - 03 Mar 2017    Post subject: Reply with quote
good luck with the loobman...
mine's a pain in the arse... shoulda just got a scottoiler
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
temeluchus
PostPosted: 22:57 - 03 Mar 2017    Post subject: Reply with quote
Never had an issue with them. The trick is to throw the dual feed head in the bin and have the hose drip onto the rollers.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:22 - 03 Mar 2017    Post subject: Reply with quote
Chainsaw oil.
Triumph Sprint ST 1050
Moo.
PostPosted: 23:54 - 03 Mar 2017    Post subject: Reply with quote
Nobby the Bastard wrote:
Chainsaw oil.
+1 cheap and its made to be super sticky Laughing
A2 Passed 18/6/10
Nobby the Bastard
Harley Gaydar
PostPosted: 02:37 - 04 Mar 2017    Post subject: Reply with quote
Chainsaw oil.
goes through a scotoiler reasonably as well
Petemate
PostPosted: 11:11 - 04 Mar 2017    Post subject: Reply with quote
Sounds good to me, especially the 'cheap' aspect! Also, if it is super sticky, I would hazard a guess that it wont spray up and around everywhere. Win-win.
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
kramdra
PostPosted: 11:42 - 04 Mar 2017    Post subject: Reply with quote
No, this is useful. The fling removes the dirt, keeps it clean. Use more. Tiny bit of oil does not reduce grip
Copycat73
PostPosted: 13:29 - 04 Mar 2017    Post subject: Reply with quote
nevertheless I clean any over spray , drips, contamination; or the like; off with a rag and petrol .. allowing to dry over nigh before use.
but please keep me updated as to how exactly that goes for you ...
caveat emptor
The last post was made 9 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.97 - MySQL Queries: 16 - Page Size: 132.84 Kb
