| solemnwarning |
 solemnwarning Borekit Bruiser
 Posted: 21:03 - 05 Mar 2017 Post subject: Just broke a chain... me, the tool or the rivet? |
I just tried fitting a new DID VX 520 chain with a hollow rivet master link, using one of these tools.
There weren't any instructions included, but it seemed simple enough that I just guessed at it: I used the plate with two holes in it to press the side plate on to the proper thickness, then put the convex anvil in one side of the tool to brace the rivet and started winding the ball-bearing-faced tool into the hollow end of the rivet.
The rivets initially measured 5.18mm diameter, the ones pressed at the factory were 5.5mm, by 5.3mm the hollow rivet had seemingly gone a bit sideways - the mushroomed section shearing away from the tube around most of its diameter. I was able to remove this rivet by putting one of the extractor pins down the middle; it sheared off what was left easily. The end of the rivet that came out had clearly broken off sideways, only around part of its diameter.
I had another go with the other side of the link once it was out, the tool was able to expand it to 5.5mm with no drama (no side plate etc fitted).
Did I screw this up, is the tool iffy or did I get a defective rivet?
Got no way to get to work now, very tempted to try and get a split link when I call around in the morning.
Thanks
EDIT: One more thing... do I specifically need another DID VX 520 master link, or should any O/X ring 520 pitch link be fine? |
| Commuter_Tim |
 Commuter_Tim World Chat Champion
| jaffa90 |
 jaffa90 World Chat Champion
| Commuter_Tim |
| sickpup |
 sickpup Old Timer
| jaffa90 |
| temeluchus |
| P.addy |
 P.addy Red Rocket
| temeluchus |
| bamt |
 bamt World Chat Champion
 Posted: 07:40 - 06 Mar 2017 Post subject: |
I bought that exact kit (from Amazon) and had to return it as it was so badly machined that the parts didn't fit together! I'm sure a properly made one would have been fine, I could have filed it down, but didn't think I should have to do that on a premium priced tool so sent it back and bought an Afam instead. https://www.amazon.co.uk//dp/B0119L91VW
It doesn't attempt to break links, but does a good job of joining them. It was recommended by a few people on here and other forums, rather than being a random purchase. The rivets measured perfectly with my caliper. |
| Matt B |
 Matt B World Chat Champion
| jaffa90 |
| P.addy |
 P.addy Red Rocket
 Posted: 12:01 - 06 Mar 2017 Post subject: |
Car, you fucking autistic tramp My car idles at 800 too, lovely little diesel. Since when was my Triple a car. Just to add some fuel for your ever burning retard flame, I hired a bike last week, Varadero 125, for science, I dropped idle to 1k, it sat there knocking and flickering the lights until I fed it some sympathy and put it back to 1300.
| sickpup |
 sickpup Old Timer
| techathy |
 techathy Traffic Copper
The last post was made 9 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
