peugeot speedfight 2 100cc none starter
davea76
PostPosted: 17:40 - 07 Mar 2017    Post subject: peugeot speedfight 2 100cc none starter Reply with quote
my son has come home with a speedfight 2 that wont start, it has a spark and if i squirt fuel straight down the carb opening (airbox off) and turn it over with a drill on the crank it will run for a few seconds, im not knowledged up on newer bikes with all the electronics so would you say i am looking at a carb issue or is there possibly another underlying electical problem
thanks in advance dave
mudcow007
PostPosted: 17:50 - 07 Mar 2017    Post subject: Reply with quote
Why you using a drill to start it - whast up with the kick/ starter motor?
Battery voltage?
Fuel blockage/ fuel pump issue?
davea76
PostPosted: 17:59 - 07 Mar 2017    Post subject: Reply with quote
starter is not working, drill makes it easier, not sure on battery voltage, do these have a fuel pump ?
davea76
PostPosted: 18:10 - 07 Mar 2017    Post subject: Reply with quote
update battery voltage is 12.7v
Baggyman
PostPosted: 18:50 - 07 Mar 2017    Post subject: Reply with quote
usual problem solving -
Do you have a spark?
Do you have compression?
Do you have fuel getting through?
then follow up from there
Old fart
Baghira, modded GS1000 and the T150 I bought in 1978 when I was 21
davea76
PostPosted: 21:12 - 07 Mar 2017    Post subject: Reply with quote
yes spark is there, compression is there and appears to be fuel there but nothing unless i physically squirt fuel through the carb, thats why im wondering if theres some other electrical component stopping the thing bursting into life
Baggyman
PostPosted: 21:34 - 07 Mar 2017    Post subject: Reply with quote
so that looks like fuel then.
Is it coming out of the tap? pull the fuel line off the carb to check it is getting through - check tap on/off working
Check there is fuel in the float bowl. Check the float, check the carb fuel valve. Check the needle or jets haven't fallen out
If all that looks ok, drain the fuel and put some fresh in
Old fart
davea76
PostPosted: 22:37 - 07 Mar 2017    Post subject: Reply with quote
ok thanks, definitely fuel getting to the carb, will pull the carb out and give it a good fettle, just wasnt sure if there was some electric trickery on these to stop the fuel
jaffa90
PostPosted: 23:12 - 07 Mar 2017    Post subject: Reply with quote
""""" just wasnt sure if there was some electric trickery on these to stop the fuel"""""
It could have an electric choke.
MahatmaAndhi
PostPosted: 23:29 - 07 Mar 2017    Post subject: Reply with quote
Have you checked the starter button itself? Sometimes dirt/other road nasties get inside which causes it not to connect.
2008 Aprilia Sportcity 250
davea76
PostPosted: 00:05 - 08 Mar 2017    Post subject: Reply with quote
Yeah put 12v straight to the starter and nothing, think its screwed
andys675
PostPosted: 01:06 - 09 Mar 2017    Post subject: Reply with quote
check the timing, if the electrics get wet on these things the cdi can get spiked and they fire at the wrong point, you can also spike it reversing the battery terminals or using a non resistor spark plug
The last post was made 9 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.30 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 68.8 Kb
