Anyone know anything about Diesel engines?
baldy
PostPosted: 17:48 - 08 Mar 2017    Post subject: Anyone know anything about Diesel engines? Reply with quote
I'm after some help with a recent purchase the wife made. She bought a Mercedes ml270 2.7 CDC with 110k on it.
Everything was fine for a few weeks but has now developed an annoying problem which seems to be getting worse. It starts fine and revs up perfect while stood but when moving if you go past 1/3 throttle it throws out lots of whitish grey smoke. It seems to surge under load which is accompanied by a rattling from the engine. It has lost a bit of power as well. It only does this while driving so I am ruling out major engine problems.
There are no error codes logged on the ECU.
Any thoughts appreciated.
One day i will rule the world, just not today.
arry
PostPosted: 17:57 - 08 Mar 2017    Post subject: Reply with quote
Not the classic oil leak down the manifold from turbo, knackering the swirl actuator is it?
Really common on the 3 litre they stuck in the Jeep.
Tankie
PostPosted: 18:06 - 08 Mar 2017    Post subject: Reply with quote
Check all the fluid levels, could be burning oil via the turbo
WD Forte
PostPosted: 18:08 - 08 Mar 2017    Post subject: Reply with quote
leaky injector?
bikers smell of wee
baldy
It doesn't seem to be using oil at all. Normally leaky turbos make them smoke all the time don't they? Ive checked for boost leaks as well. All seems good.
I hate modern diesels.
Tankie
PostPosted: 18:09 - 08 Mar 2017    Post subject: Reply with quote
WD Forte wrote:
leaky injector?
That would give black smoke
baldy
PostPosted: 18:10 - 08 Mar 2017    Post subject: Reply with quote
WD Forte wrote:
leaky injector?
Starts perfect every time with no smoke. Not a hint of black smoke under acceleration. Just a huge cloud of grey/white.
No coolant loss either.
Tankie
Have you checked the coolant level?
arry
It's not the oil going through the turbo and through the combustion chamber, it's a weeping of oil from the turbo intake manifold that pools and runs down onto the swirl actuator, causing all sorts of funny fuelling / running / power issues.
baldy
PostPosted: 18:12 - 08 Mar 2017    Post subject: Reply with quote
Would I get a boost leak first?
arry
PostPosted: 18:17 - 08 Mar 2017    Post subject: Reply with quote
No. It just weeps oil - the weeping isn't so much the issue, it's the swirl motor that gets coated and goes tits up as a result that is.
https://www.justanswer.com/jeep/6nyqa-jeep-grand-cherokee-limited-hi-08-grand-cherokee.html
I'm in the know on this as a friend of mine had a Cherokee that was a real problem child, with the 3.0 litre CRD engine. Ended up with a quote from Jeep for £4000 to change the turbo and manifold assembly - so we used a resistor pack to fool the swirl motor and he got shot of it whilst the going was good.
As I say, not sure if the 2.7 lump is any different, or any better.
baldy
PostPosted: 18:19 - 08 Mar 2017    Post subject: Reply with quote
I know of the issues with the swirl flap motor but everything seems fine. There's no weeping from under the manifold. I'm eventually going to do the egr and swirl delete. Generally faults with the motor would show a fault code.
arry
PostPosted: 18:23 - 08 Mar 2017    Post subject: Reply with quote
His one didn't. Well it didn't at first anyway, it did later on once it'd had gone totally berserk.
May not be, just a heads up as it's definitely common on an engine of the same family Smile
baldy
PostPosted: 18:26 - 08 Mar 2017    Post subject: Reply with quote
I leaning towards a faulty injector. I need to do a leak off test but some bugger has nicked my test kit. I've never had symptoms like this though from injector failure.
nowhere.elysium
The Pork Lord
PostPosted: 18:30 - 08 Mar 2017    Post subject: Reply with quote
DPF cycle going nuts?
baldy
PostPosted: 18:33 - 08 Mar 2017    Post subject: Reply with quote
Doesn't have a dpf
nowhere.elysium
The Pork Lord
PostPosted: 18:37 - 08 Mar 2017    Post subject: Reply with quote
baldy wrote:
Doesn't have a dpf
Fair enough. I just wanted to sound like I had a clue, really Laughing
baldy
PostPosted: 18:39 - 08 Mar 2017    Post subject: Reply with quote
I've googled the hell out of this and can't find anyone with the same symptoms. Nothing seems to be broken yet it won't work properly.
PostPosted: 18:43 - 08 Mar 2017    Post subject: Reply with quote
Do swirl and EGR delete.
If problems rectify, then hey presto.
If not, check both injector and possibly the seals, unsure if related but the 2.4 and 2.5 engines had seals that went shit and you heard a decent amount of rattling.
Failing that, removes the wheels and leave it on its side on the path.
baldy
PostPosted: 18:50 - 08 Mar 2017    Post subject: Reply with quote
It only rattles under hard acceleration over 2.5k. Injector seals are good.
chrisst2
PostPosted: 17:44 - 09 Mar 2017    Post subject: Reply with quote
Have you checked the turbo inter-cooler hoses?
Sounds to me like one of the hoses has a leak/split or is collapsing , white smoke and drop in power is classic sign of that sometimes accompanied by a rattle.
If not then check the injectors are actually seated and tight, although I believe if it was an injector problem you would have black/blue smoke.
Motorhate
PostPosted: 22:10 - 09 Mar 2017    Post subject: Reply with quote
Possible injection timing. The white smoke is too much fuel being delivered that isn't getting burned up.
If not then maybe a crack in your exhaust manifold.
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
Hong Kong Phooey
PostPosted: 23:43 - 09 Mar 2017    Post subject: Reply with quote
Sounds like oil leak past turbo seals, pull intercooler hose and check for oil and check for play in chra. Should be none up/down, tiny bit in out isn't terminal.
Other worthwhile free checks to do are check condition of vac hoses and breather systems and one way valves.
chrisst2
PostPosted: 00:21 - 10 Mar 2017    Post subject: Reply with quote
still think you should check hoses 1st, white smoke is rarely anything to do with oil leaks or injectors, usually un-burnt fuel , hoses are a classic sign of that, takes a few minutes to take the hoses off and check.
Northern Monkey
PostPosted: 07:42 - 10 Mar 2017    Post subject: Reply with quote
I'd be checking the rubber hoses from the turbo to the I tercooler the. Intercooler to I let manifold.
I've had cars where the maf sensor is after the turbo, so thinks loads of air is going to the engine. Loads leaks out perished hoses so the engine overfuels. Happens most when the boost is high.
The last post was made 9 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.73 - MySQL Queries: 13 - Page Size: 124.68 Kb
