Oil Change Gone Wrong
Fin
PostPosted: 21:57 - 08 Mar 2017    Post subject: Oil Change Gone Wrong Reply with quote
So it all went wrong on the 22nd of October when I thought I'd change the oil filter and oil on my XJ600. You may have seen my thread about what happened, the sump bolt threaded.
https://i.imgur.com/V5GVtVy.png
Devastated I came here for advice and it was a fairly simple process to buy a new sump and gasket for about £20.
A week or so later I put the gasket and new sump on, when doing this the gasket must have torn as it didn't seal properly and leaked properly.
Not needing to use the bike and needing to spend some time on the exhaust I left it, the gasket being more than a new sump I thought I'd try some gasket sealant from a tube.
If you've ever take off the sump of an xj600 you'll know there is an awkward bolt by the side stand which you can access with a ball joint hex key. Not being able to find mine I used my dads... Big mistake.
https://i.imgur.com/eV8IReF.png 07.01.17
Okay my fault for doing it up so tight but I used the same key to tighten it with and put in anti-seize (copper grease).
I had a quick tinker to try and get the end out the bolt but couldn't so left it a while.
On the 21st Jan I had a better go at getting the head out but was pretty stuck for ideas as access is so hard.
https://i.imgur.com/NRzcdDB.png
I tried to use a tiny cobalt drill bit on the end of an air rotary tool but the hex key was too hard. I then consulted facebook which were pretty clueless.
Skip to the 2nd of March, (day before my big bike test) I wanted to get it sorted so I had another crack. Hitting it lots with a centre punch trying to to make a dent I could drill into or tap it loose and use a magnet.
https://i.imgur.com/1LDF2gl.png
I then removed the side stand switch and used an angle grinder to cut a bit out the way, the switch doesn't need that much steel and It'll give me better access.
I didn't get it out and ended up enjoying my day off and doing stuff to my car.
Skip to last night where I managed to drill into it a bit with a bigger drill bit and a proper drill however the head seemed to have become one with the bolt.
Before I drilled any further and removed the softer bolt steel I thought I'd see if I can stick a bolt in and weld it or get someone else too if I cant.
https://i.imgur.com/QdlOSKW.jpg
'tack' welded in place I was ready to give welding the bolt in a go, would be difficult for me with my arc welder and 0 skill but I don't have much choice.
I have a look around for the best access and this is where I notice the big shit.
https://i.imgur.com/ht2aZXl.png
Only gone and cracked my engine hammering the shit out of it...
https://i.imgur.com/pALdylg.png
Anyone else managed to fuck up an oil change more than me?
Also what shall I do about the crack and bolt, I haven't tried welding the bolt yet. Expect I'll try and weld the engine back together although I imagine I'd have to get a different welder or at least rod.
Bozzy
PostPosted: 22:30 - 08 Mar 2017    Post subject: Reply with quote
Oh dear, sorry to hear that fella.
Didn't bodyguard cock his bike up trying to do something simple? I'll try to find the thread if it makes you feel any better.
2004 SV650S >>> 2009 Street Triple R
PostPosted: 22:43 - 08 Mar 2017    Post subject: Reply with quote
I have to admit I've never seen anyone go from stripped sump plug to cracked engine cases in so few steps.
And you managed to break one of the only two tools you'd need!
RhynoCZ
PostPosted: 22:52 - 08 Mar 2017    Post subject: Reply with quote
Exactly, it is actually very impressive. Not many people would be capable of it, but OP pulled this of like a pro. Thumbs Up
Commuter_Tim
PostPosted: 23:21 - 08 Mar 2017    Post subject: Reply with quote
Curious how it's always the magnetic sump bolts in these threads. Thinking
Commiserations.
I ride a Bandit 600... badly.
PostPosted: 23:32 - 08 Mar 2017    Post subject: Reply with quote
Arcane is that you.
Tbag
PostPosted: 00:01 - 09 Mar 2017    Post subject: Reply with quote
What the hell is that Allen key made of?? chocolate Laughing
Baggyman
PostPosted: 00:05 - 09 Mar 2017    Post subject: Reply with quote
Ball head allens are not designed for final tightening or initial untightening, just for rapid "no load" screwing - the narrow bit is an obvious weak point. May just about be Ok with a snap-on but never with cheaper stuff
A bit late now but if you have limited clearance, you are much better cutting down a standard allen so it is short enough to gain access.
Looking forwards, you are going to have to remove and strip the engine. Worry about the problem allen when it is on the bench.
Options:
1. May be able to get a specialist to weld it
2. new cases
3. another engine from the breakers
Also, get the plug thread in the sump helicoiled
Also, is that welder current flowing through the ally engine? Lucky you did not get a silver puddle on your garage floor
Old fart
Baghira, modded GS1000 and the T150 I bought in 1978 when I was 21
DRZ4Hunned
PostPosted: 00:34 - 09 Mar 2017    Post subject: Reply with quote
This forum never ceases to amaze me Laughing
DRZ400-SM
FZS600
PostPosted: 07:30 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
The bolt I would remove in moments. The crack is another matter. You can't arc weld engine alloy and you can't weld it with anything else in the bike. At the very least, it's an engine out job, drain oil, turn it upside-down, degrease and tig weld. That's if there's access. If there isn't it's either a full strip down or find another engine.
PostPosted: 07:43 - 09 Mar 2017    Post subject: Reply with quote
There's a big lesson here for people doing their home maintenance:
First and foremost - don't over-tighten stuff. People seem to think a sump plug will fall out because it's under the engine and holding all that oil in so they give it a couple of extra shoves to be sure. IT WON'T - it's no different to any other bolt in the engine, once tightened it stays tightened.
M6 sump bolts - 7 foot pounds same as any other. Even the weakest person can achieve that with a normal spanner and 2 fingers.
Sump plugs - fit a new damn crush washer. Every time. You can't flatten a sealing washer that's already flat.
Stripped sump plugs - get a sump plug repair kit off eBay for £20 and fit an over-sized plug. Contrary to what people think you won't fill your engine with swarf, it's perfectly safe to do it in the bike, it takes just minutes and you'll be on your way with a brand new plug and washer fitted in literally minutes.
BTTD
PostPosted: 08:21 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
How would you get it out?
Baggyman
PostPosted: 08:49 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
a bit of heat and a pointy instrument at an angle to lever it out.
If it is really stuck due to leaving a load of road shit in there and jamming the key in, drill a 1mm hole at an angle using a "v" of the allen as a drill guide, pointy thing, lever out.
Patience with the drill is a must as these cheap allens are probably surface hardened.
Sorry to say it but economically the bike may well be a write off. What was it worth before?
Don't poke it with a £50 arc welder. It will not end well
Old fart
PostPosted: 09:03 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
It's Pete... Anything is possible.
PostPosted: 09:24 - 09 Mar 2017    Post subject: Reply with quote
I'd definitely take the bike straight to Pete after you've bought it.
PostPosted: 09:42 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
Any number of ways, the first thing with tight socket caps is to give it a crack with a light hammer then go again with the allen key, usually works. A good socketed allen key set is a valuable tool to have for bikes.
If it's truly seized in then it all depends on access.
The main point is if something goes is stuck stop and think about it instead of reaching for a big hammer. If you snap the proper tool designed for turning a bolt then just hitting it is hardly likely to end well.
dydey90
PostPosted: 11:42 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
Even a bad one will do the job nine times out of ten.
I got a set like this from Ebay and it's dug me out of the shit a few times at work. I think mine says Toolzone on the box and was slightly different, as it was a set of hex bits and a 1/2" square drive adapter.
If not, drill a hole as close to the centre as you can get it and use something like this on it. I'm sure they were cheaper when I bought them, so maybe shop around a bit. Don't buy the type that looks like a drill bit with a reverse thread. They're shite, made of an aluminium-cocoa alloy and they're generally a lot bigger than you wished they were.
Baggyman
PostPosted: 12:34 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
Good tools but not for tight spaces. Sometimes you just have to make something.
Old fart
BTTD
PostPosted: 12:46 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
Cheers for that, I was more wondering how easy it is now that he's got the end of the ball hex key snapped off and jammed in there and can't seem to drill it, and can't get anything else onto it.
OP does seem rather ham fisted -
1. over tightening sump and then
2. cracking the engine case with a hammer.
Thinking about it, how easy is it to warp a sump if you over tighten the bolts in a non-crisscross pattern resulting in an oil leak?
PostPosted: 13:33 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
Oh right, to remove the ball end I would grind a small flat on the end of my tig welder tungsten then touch it down on the ball end on low amps. The ball will fuse to the electrode and then it will pop out.
You could probably do exactly the same with a stick welder rod.
Baggyman
PostPosted: 14:23 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
Risky.
Where do you put the earth?
Probably just as much chance of welding the ball to the allen. The spark will not care which gap it jumps across and you definitely do not want an aluminium "fuse" in that circuit.
Many years ago, I saw someone welding a frame. He put the earth onto a fork yoke and managed to weld up the head races
It should come out easily enough. It is not as though he hammered it in there....Oh hang on a minute.... Shocked
Old fart
skatefreak
PostPosted: 16:15 - 09 Mar 2017    Post subject: Reply with quote
I am suitably impressed Thumbs Up
Don't suppose you could change some bulbs on my bike?
nowhere.elysium
The Pork Lord
PostPosted: 16:41 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
Baggyman wrote:
Risky.
Pete knows what he's doing.
PostPosted: 16:42 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
QFT. If Pete does it, its probably fine. Laughing I'd trust his words than most in the workshop.
Baggyman
PostPosted: 16:51 - 09 Mar 2017    Post subject: Re: Oil Change Gone Wrong Reply with quote
Fair enough -no offence Pete (and its not you doing it Very Happy )
Old fart
The last post was made 9 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 137.32 Kb
