Quiet helmets?
opistho
PostPosted: 07:56 - 10 Mar 2017    Post subject: Quiet helmets? Reply with quote
Hai,
I'm looking for a quiet helmet to help slow my hearing loss. I have a Schuberth C3 pro at the moment that my wife gave me, and it's incredibly uncomfortable, especially the choke chain chin strap. What other helmets can I go try on that are super quiet?
p.s. I wear earplugs every day
esullivan
PostPosted: 08:17 - 10 Mar 2017    Post subject: Reply with quote
My Shoei GT Air is pretty quiet, especially if you use the filter thingy (I forget what it is called) around the chin. The downside is that it isn't well ventilated. It's hot in the summer, unless I keep the visor open (negating the quietness) and the inside of the pinlock can mist-up a bit in the winter.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
PostPosted: 09:27 - 10 Mar 2017    Post subject: Reply with quote
Schuberth seem to be the bench mark for noise but if you don't find them comfortable you are probably swapping one problem for another.
The quietest helmet I have is the Shark Evoline which is a lovely helmet, well made but there is something about it I don't really get on with and can't put my finger on. I keep reverting to my tried and trusted HJC FS11 which has an air pump system.
Triumph Trophy Launch Edition
Analogkid
PostPosted: 09:34 - 10 Mar 2017    Post subject: Re: Quiet helmets? Reply with quote
opistho wrote:
Hai,
Do Schuberth offer different sized liners which may help with sizing?
I sooo wanted a C3 but the chin bar was too short and my chin kept hitting front, I settled on a Shoei Neotec with smaller cheek pads and couldn't be happier, pretty quiet too, decent ventilation and can always lift the front like your C3
skatefreak
PostPosted: 09:42 - 10 Mar 2017    Post subject: Reply with quote
Ear plugs?
Yes I know... not a helmet, but I find they cut out a ridiculous amount of noise so well worth considering if noise is a problem and you could also shop for something comfortable Smile
Analogkid
PostPosted: 09:43 - 10 Mar 2017    Post subject: Reply with quote
skatefreak wrote:
Ear plugs?
See the PS at bottom of o/p
opistho
PostPosted: 13:07 - 10 Mar 2017    Post subject: Re: Quiet helmets? Reply with quote
Unfortunately, it's just super round and my head is a bit more oval. The worst problem is actually the chin strap. It puts my throat in a vice grip because it's so far back.
Confusion
PostPosted: 13:08 - 10 Mar 2017    Post subject: Re: Quiet helmets? Reply with quote
The Shoei Qwest is a quiet helmet.
In that case, any standard sports/touring helmet should be
ok. This is my recent experience with the Scorpion 710:
https://homepage.eircom.net/~ei9gq/scorpion.html
Bandit 650SA, ZZ-R1100
Bloggsy
PostPosted: 13:30 - 10 Mar 2017    Post subject: Reply with quote
The thing round the chin is a chin curtain, I have a Shoei GT air and use earplugs and find it is quieter than my previous helmet which was a Shoei XR1100
If It Aint broke Don't Fix It
esullivan
PostPosted: 15:09 - 10 Mar 2017    Post subject: Reply with quote
Yes, my previous was an XR1100, as well. Absolutely fabulous ventilation, but loud as hell.
choogh
PostPosted: 19:43 - 10 Mar 2017    Post subject: Reply with quote
I also have a Schuberth helmet,and yes they do various liners sizes.. As a matter of interest is the OP putting his helmet on the right way round...because they are one if the most comfortable helmets available.
Just a thought..
Current Squadron:
R1200rt. Virago 535
Loro Sono tra noi.
Itchy
PostPosted: 20:01 - 10 Mar 2017    Post subject: Reply with quote
Buy better ear plugs or get some moulded ones.
BTTD
PostPosted: 20:21 - 10 Mar 2017    Post subject: Reply with quote
Confused I'm confused that your helmet is too noisy despite wearing earplugs.
What kind of earplugs are you wearing?
I have a Schuberth S2, it's not as quiet as the Arai it replaced. With foam ear plugs in either is fine for me.
owl
PostPosted: 21:11 - 10 Mar 2017    Post subject: Reply with quote
Shoei NXR, one of the quietest helmets I've used, believe it replaces the XR1100
Observation is the greatest source of wisdom.
CliveFa
PostPosted: 21:20 - 10 Mar 2017    Post subject: Reply with quote
I use a Schuberth C3 Pro and find it quiet enough not to need ear plugs for a couple of hours.
Longer days I have Ultimate custom plugs which work.
Chin strap not a problem for me.
When I had Shoei lids they were good but not so good as the C3.
Clive
ZX10R Black with some gold bling.
Kentol750
PostPosted: 23:08 - 10 Mar 2017    Post subject: Helmets Reply with quote
I find the shoei neotec noisy, well ventilated but noisy. As with most flip up helmets I've used.
Have an x spirit 2 which is not as quiet as my arai quantum st (even with the pro shield up, I find it quieter than the neotec.)
I know what you mean about schuberth chin strap, sits quite far back.
The St is based on the rx7 helmet, but has a more oval shape to it. Meant to be better for road use over rx7 track focus.
Some bikes.
Shaft
PostPosted: 23:32 - 10 Mar 2017    Post subject: Reply with quote
Just a thought..
Only if they fit, I've never got on with Schuberth lids.
supZ
PostPosted: 00:59 - 11 Mar 2017    Post subject: Reply with quote
same. my gt air is very quiet. When I first got it I could nearly get away without using earplugs it cut out the wind noise so well. Nearly, but not quite Wink
Had an older XR1000 before that.
edit:
I know you said you wear earplugs but what ones? You're trying to eliminate the wind roar and some may not cover that frequency range.
E.g. I tried my earphones once. Completely cut out all noise, was totally isolated from the world but they didn't stop the wind roar at all.. might as well have not had them in. Plus the whole cut off from sound thing was very bad too.
My current style of earplugs enable me to chat at the traffic lights/petrol station etc.. with my helmet on but yet they stop the crucial wind roar. If you're trying to reduce any hearing damage, you need to make sure that's what you're getting from your earplugs.
these are the type i use: https://www.ebay.co.uk/itm/3M-EAR-UF-01-000-ULTRAFIT-EAR-PLUGS-CORDED-/151423154459?var=&hash=item234185f91b:m:mi_9pqlQr0q-9kO6YiHy20Q
foam ones were never good enough in my opinion
CBR954RR - Daily toy
CBR600RR - Trackbike
Northern Monkey
PostPosted: 07:00 - 11 Mar 2017    Post subject: Reply with quote
If you look at the noise attenuation of ear plugs, the expensive ones block about 25db and the cheap ones about 32db. The cheap ones are about 4 times more effective than the expensive ones. People who have paid lots of money for expensive mounded ones get angry when you point this out.
iooi
PostPosted: 07:05 - 11 Mar 2017    Post subject: Re: Quiet helmets? Reply with quote
opistho wrote:
Hai,
Serious lack of info here..... Rolling Eyes
While you can get quiet helmets. even the best are effected by many things....
So which bike, does it have a screen, what exhaust do you have.
Clearly if you are wearing ear plugs, then they are no good. If you are after a quieter helmet.
Itchy
PostPosted: 08:28 - 11 Mar 2017    Post subject: Reply with quote
Yes sometimes this is true.
There is also considerable variation even if both have NRR of 32/33.
For instance the Howard Leight non tapered orange ones where you can see the foam bubbles reduce sound by only a little and I use them to play piano.
There are some smooth green tapered ones with fin ends which reduce sound a bit more.
While there are some smooth bell shaped orange ones that I find are the best I use these for riding.
I think the difference for me personally is how snug the fit is. The first ones mentioned are super loose and can be knocked out by putting on your helmet. The second ones you can feel them protrude in your ear while the last orange ones feel huge initially.
supZ
PostPosted: 11:36 - 15 Mar 2017    Post subject: Reply with quote
Don't know why they'd get angry; it's pretty irrelevant.
You don't need the highest db levels; in fact it can actually hinder you if you block out everything as you won't hear cars around you, horns etc..
It's not straight volume you're trying to block out as a biker. It's certain frequency ranges. I.e. the damaging wind roar.
You don't have to glue your ears shut just to protect your hearing whilst riding; you can have earplugs that still allow you to talk pretty normally to others but whilst riding they cut out that specific damaging frequency range.
As long as your earplugs are doing that then it's fine.
Aka Matt
PostPosted: 11:39 - 16 Mar 2017    Post subject: Reply with quote
Contrary to the experience of others here, I've had my GT Air for a couple of years now and find it has more going against it than the Qwest it replaced, which I am rather disappointed with to be honest. I find I experience more wind noise than I did with the Qwest it replaced and the ventilation is relatively poor in comparison to the Qwest too. Riding out in medium to high 20 degree heat just makes the lid stuffy and rather unpleasant to be within.
If you're looking for quiet though, you won't do much better than Schuberth as others have mentioned.
Current bike(s): 2016 Tuono 1100 Factory, 1998 Hornet 600
Previous: 1998 YZF600R Thundercat, 2001 Bandit 600, 2002 GSX-R 600 K2, 2011 Tuono R, 2013 Z1000SX
Hawkeye1250FA
PostPosted: 11:47 - 16 Mar 2017    Post subject: Reply with quote
Slight tangent...
Has anyone used the neck wind repellent things for flip front helmets (If they even do one)?
NutsyUk
PostPosted: 12:49 - 16 Mar 2017    Post subject: Reply with quote
My helmet is amazing but for one thing... the only thing that creates noise is the slider switch for the inner shades.
Ive not got my helmet with me so i cant even remember what brand it is... I mentioned it here before in some thread.
But yeah quiet apart from the switch that causes all teh noise :p
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
The last post was made 8 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 132.84 Kb
