Newbie Helmet Advice
rpsmith79
PostPosted: 12:55 - 11 Mar 2017    Post subject: Newbie Helmet Advice Reply with quote
Right then, i'm after some advice/recommendations on how best to test helmets for fit, specifically for long oval heads
Having only recently passed my CBT i had one of the trainers helmets on during the day, and didn't have any major issues with it, however on now using my own helmet for anything longer than about an hour i get quite a bit of discomfort across my forehead, it was only yesterday i discovered this having worn it during my CBT plus course (at a different training centre, and i didn't make note of the make/model of helmet i originally wore)
So, what is the best way to tell if a helmet will give you grief over a longer period, i have been told when trying on helmets in shops to wear them for a decent period of time, but i can't realistically sit in a shop for an hour wearing one of their helmets
So are there any recommended helmets for those with longer heads, diameter wise i am 61-62mm, so i know that equates in most cases to XL, but very few helmets seem to mention what head shape they suit
And yes, i know it's difficult to recommend me anything based purely on the above, i'm more after advice on how to know if said helmet will be comfortable over longer periods of time
JP7
PostPosted: 14:16 - 11 Mar 2017    Post subject: Reply with quote
I have the same head shape, I had an Arai Viper GT for years before replacing it with a Shoei NXR which also fitted perfectly. The current form of the Viper GT is the Quantum ST Pro, which I believe has just been discontinued in favour of the QV Pro. So you might get a deal on a Quantum ST Pro which is designed specifically for the "long oval".
I've also just bought a Shark Spartan, which will be perfect once I have some slightly thicker cheek pads fitted. And I tried on the Shoei GT-Air which also fitted really well. So there's a few things for you to try on.
For me, Nolan/X-Lite, AGV, most HJC were pretty much a no-go, but try them anyway and see how you get on.
If you're trying on helmets in a shop, the best way to check for correct front to back fit will be to see if you can get an index finger between your forehead and the lining. Wear it for a few minutes in the shop and see if there are any pressure marks on your forehead when you take it off.
Hope that helps!
rpsmith79
PostPosted: 15:01 - 11 Mar 2017    Post subject: Reply with quote
Cheers JP, certainly some food for thought, and some makes to try out
NJD
PostPosted: 15:09 - 11 Mar 2017    Post subject: Reply with quote
Common sense and experience apply when trying on lids. It's a pain in the arse to be honest and out of all the gear the thing I buy the least because walking out the shop with one thinking it's right for you takes seconds but returning it is a whole different ball game and one I hope not to ever need repeat.
People say, common internet advice, try the helmet on for twenty minutes or so but in truth you should be able to tell straight away if it's for you or not. The only real way you'll know is, as you've found out, riding around in it. The two lids I purchased having only worn for sub ten minutes, probably less, turned out alright. I've a third, a Shark Skwal, but I don't use that because pants imo.
If it gives you pain as soon as you put it on it's not going to get any better. Advice is the helmet needs to bed in but there's a difference between snug fit and pain. I've only experienced pain in one Arai lid while trying on because "yes mate I'd totally spend that amount of money on a lid gis a try of a behind the counter lid."
Look at what's within budget and suitable to your head shape, draw up a short list and go shopping. I found Revzilla videos helpful when wanting to see what's what without leaving the house.
Do keep in mind to get a helmet that suits the seating position of your bike. So don't buy a sports lid if you're on an upright bike and so on.
chickenstrip
PostPosted: 15:18 - 11 Mar 2017    Post subject: Reply with quote
Confused
I ride upright bikes. I use HJC RPHA10s currently. I found they reduce head-buffeting so much (for me Wink ), it solved much of the noise and fatigue problems I used to get with cheaper lids. I had the HJC IS17 before that, which is supposed to be a 'touring' lid. It's heavier than the RPHAs, and I got significantly more buffeting, plus I got a jet of air straight into my eyes, no matter what I did to try to alleviate it.
NJD
PostPosted: 16:05 - 11 Mar 2017    Post subject: Reply with quote
chickenstrip wrote:
Confused
Why the confused face, my reasoning for that comment is really quite simple. Sports lids are designed with a more aggressive downwards angle to them as if tucked into the tank and regular upright helmets sit accordingly.
HJC IS 17 is a cheap entry level helmet with, I'd say, the AGV K3 SV as the sports alternative. I tried on the IS 17 and didn't like it and chose the RPHA ST instead.
HJC isn't all that anyway given the pinlock fogs up, as did on my first one. Shark are pants, or the Skwal at least. I don't think I've found the "one" in helmets brands just yet. Probably won't given I'm not willing to spend silly money on one.
chickenstrip
PostPosted: 16:31 - 11 Mar 2017    Post subject: Reply with quote
What does it matter if they work for you?
Plus, I have never seen anywhere any kind of statement that says "this helmet is for sports bike/upright bike use only". Have you?
They were good enough for Lorenzo. Not that it really bothers me if I get along with it. I won't pay Arai and Shoei money anymore.
You'd dismiss a helmet on the basis of a pinlock fogging? I never use one myself, and besides, there are other ways to reduce fogging. Also, chances are you could buy another of the exact same model and not get the same problem. Or replace the visor or insert and not get the problem. With the IS17, I'm not the only person to have had the air-in-the-eyes problem though, and I never found a fix for it.
NJD
PostPosted: 16:45 - 11 Mar 2017    Post subject: Reply with quote
Well it didn't hence why we have a difference in opinion.
I wouldn't expect to.
Naturally, use as you wish but my advice is my advice.
O rly? (OGR's post bottom of page).
And how much bad weather do you ride in? I'd never looked back after using one for the first time, a pinlock.
2x models HJC RPHA ST and both equally as crap. Work around it, second one was cheap enough to laugh it of and any use I get out of it. Crap model is crap.
chickenstrip
PostPosted: 17:12 - 11 Mar 2017    Post subject: Reply with quote
Can't comment on that model, never used them. I did consider them, but with the addition of the sun visor, the shell shape changed and the weight went up, so can't compare to the RPHA10. But my own experience of the RPHA10 generally has been a very positive one, and I suppose it might be what you refer to as a sports helmet, given that it was used by Lorenzo and other track riders of note.
I'll give you the points on the pinlock (aren't I generous Laughing ). But the pinlock issue is a red herring from my main point anyway: Don't use a sports lid for an upright bike? You are the first person, in over 30 years of biking, that I have ever heard that one from.
SuperMike
PostPosted: 19:23 - 11 Mar 2017    Post subject: Reply with quote
I have a similar size nugget - 63 here. The box helmets fitted me the best but are cheap. Having said that, they still have to meet the minimum safety standards.
I tried an HJC in the shop for 30 mins and it was ok. The bloke said it would loosen up in a few weeks. It didn't. That was £220 down the drain.
Went to another shop and got the hard sell on a 65cm Schuberth. £400 worth. Yes it fitted but just felt weird and I didn't like the full front flip up element.
Tried on an Arai and fitted like a dream - 61cm max head size (XL) apparently, so 2cms smaller than mine. It is an Axcess 2. £250 worth, but it has been great for two years now.
I think the best advice is to not listen to what the sales advisors tell you. I got sold an absolute kipper by the first bloke - no doubt the HJC is a great helmet but it just didn't fit. Young lad who loved his one but unfortunately not for me.
The Arai by all accounts shouldn't have fitted but it did. The box helmet they had in the store was probably the most comfortable feeling and I fitted a 58cm one of those. Go figure.
In my experience, don't listen to the it should be tight in the shop. Ok, you don't want it spinning round on your head, but the HJC for me was really tight. I thought at the time this can't be right, but had no knowledge. Go to a shop that stocks as many brands as possible and try the lot on - don't accept what they think you should have because Barry the work experience guy has always had an HJC and it is brilliant init.
The other thing that people say is don't spend a fortune on your first one. The problem with this advice is my Arai Axcess was the cheapest Arai in the range an that started at £250. I think it is just one of those rights of passage as a motorcyclist. I know that Arai fits me, but I had to waste some money to find out.
rpsmith79
PostPosted: 20:16 - 11 Mar 2017    Post subject: Reply with quote
Cheers guys, all good advice
Kentol750
PostPosted: 23:40 - 11 Mar 2017    Post subject: Reply with quote
I know your problem, have worn many makes (and models) over the years. Shark, a large (rsf,rsr2) is fine. Shoei and arai, I have xl. Nolan don't sit low enough, but my xlite 551 enduro is ok(if a bit noisy on mway)yet same company. Agv tend to sit high too, and push against forehead.
Some bikes.
talkToTheHat
PostPosted: 01:18 - 12 Mar 2017    Post subject: Reply with quote
I have a slightly more oval head shape and helmet fitting is a pain.
You should be able to just fit your thumb between forehead and helmet if you press on the back of the lid hard with your other hand. If you can't you're gonna get headaches on hot days. Do the lid up and try to roll it off forwards. If this is remotely possible then it is too big or otherwise an improper fit. Shake your head like a dog sheading water, helmet should return to same position. Helmet should only sit in one position, if it rotates up and down then try a smaller size or a different model.
Check the helmet is right when you are sat in the position you would be on your bike, some helmets suck sat upright and are made to be ridden tucked in, others are really rubbish tucked in, either due to a low eyeport or low top of a pinlock. I'm probably going to take the pinlock out of my K3 and keep it for summer use as I have to keep my neck at an awkward angle on the motorway or otherwise at high speed. Check you can do lifesavers without catching your jacket. (Similarly be aware of this when buying jackets with speed humps and external shouder armour.
There are comfy chairs in my local J&S, the staff do not seem to object to me sitting in a helmet for half an hour reading a book.
Pinlock inserts rule. Pinlock MAX is what you want, they go right to the edge of your visor and don't fall out in a breeze. Original/classic pinlock inserts are better than nothing but aren't as good. The last thing you want is a steamed visor to worry about, particularly taking your test and pinlocks just dont steam up. With a pinlock you can just shut the visor and not open it again until you get off the bike.
Not all helmets from the same manufacturer are the same shape.
With HJC, IS17 Medium is painful, Large is wobbily, FG15 in Medium fit amazingly well (had one), now discontinued. RPHA ST Large fits quite well (have one).
AGVs I find a bit odd as there is quite a large area around the ears where there is no padding. K3SV fits ok (have one), K5 doesn't. Note with cheaper AGVs that they are agressively styled but ride quite upright. I find myself looking through the top edge of the pinlock of my K3SV if im at all tucked in.
Sharks tend to fit oval heads, but beware: the speed R is a great lid (broke one in a fight) with a really tough visor but the lower rear spoiler can catch on bulky jackets (rst tractech evo textile hates flappy bits on the bottom of helmets) and the Autoseal visor on the Skwal (had one, got refund) is prone to both breaking at the prongs when opening the visor on a hot day (happened to me on tour, spend several days with visor duct-taped shut), vibrating and pumping in water (yep, mine did that) and even flying open at high speed (neck injuries are not fun)
Bandit. does. everything.
The last post was made 8 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 91.5 Kb
