Rocker box gasket.
neptune8
PostPosted: 17:20 - 11 Mar 2017    Post subject: Rocker box gasket. Reply with quote
I have had my second hand CG 125 for about nine months. When I bought it, I adjusted the valve clearances. On replacing the cover, I had a slight oil leak from the rocker box. I went to my local bike workshop to buy a new gasket, taking the cover with me. They did not have a gasket on stock, so they kindly covered the old gasket in a sealant called Yambond. The valves need checking again, so I need to order a new gasket. I am assuming a new gasket will be leak free[ it is like a big rubber O ring]. Am I likely to have to use a gasket sealant, and if so, what is the best brand. Hope it will not be needed, as Of course I will need to check the valves again in the future.
Enjoy yourself, its later than you think
spottedtango
PostPosted: 17:27 - 11 Mar 2017    Post subject: Reply with quote
It's better to use a slight smear of sealant for peace of mind.
Hylomar Blue is good it doesn't cure fully and isn't like the naff typical red silicone sealant
The last post was made 9 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 31.29 Kb
