Qualcast Suffolk Punch - Cylinder cut Lawn Mower
binge
Emo Kiddy
PostPosted: 15:49 - 12 Mar 2017    Post subject: Qualcast Suffolk Punch - Cylinder cut Lawn Mower Reply with quote
Totally off topic, but I thought id share it with you.
Long story short, Me and the Mrs moved into our house in Jan.
Didn't really put any thought into the garden as it was cold, snowey, etc.
But now it's warming up, the lawn needs cutting.
Thing is, it's 100ft+ of pure grass. Laughing
Fuck having a plug in mower.
So, I jumped on Ebay, and picked up a non-runner, Suffolk Punch Mower for £27.00
Collected it, had a little look at it, turns out the carb was totally clogged up.
Cleaned it out, got it ticking over, but as soon as it was revved up, or a load was put on the engine (Engaged the roller or blades), it would just stall.
I gave up on the carb in the end, and decided to put a Pit bike carb on it. As the original carb had some poxy self-revving system, which increased the revs if they dropped too low.
Problem is, it was a bit too snappy, and I think it kept flooding.
Took a bit of modifying to get the pit bike carb on. But it runs on point now. Very Happy
I'd like to tart it up a bit more, but for now, it cuts the grass, and it does it bloody well too.
Need some practice on my lines now, as it mows like a football pitch.
From stock, my 'mods' are:
Ally MTB Levers (Originals had weird safety catches on which were a pain to use)
Silicone HT Lead and cap
NGK Plug
MTB Foam grips
Pit bike carb (19mm)
K&N Style air filter
Removed Pull start, and fire it up with the De-walt and a 19mm socket
https://scontent-lhr3-1.xx.fbcdn.net/v/t1.0-9/17264102_442745019409862_9129178598244953102_n.jpg?oh=f4c2af0f5a5c6435f381658fb2fbdf91&oe=59254DF6
https://scontent-lhr3-1.xx.fbcdn.net/v/t1.0-9/17264877_442745422743155_5791219494024433938_n.jpg?oh=a00705b5645df4c52a2733afe517aab5&oe=59732AE3
https://scontent-lhr3-1.xx.fbcdn.net/v/t1.0-9/17203141_442745236076507_5256172050724539174_n.jpg?oh=7987366c1a73447ba50d2f39c626de13&oe=5961D042
Fisty
PostPosted: 15:53 - 12 Mar 2017    Post subject: Reply with quote
Needs a turbo.
Fatter and faster than Fret
PostPosted: 17:49 - 12 Mar 2017    Post subject: Reply with quote
Needs more slash-cut drag pipe.
And matt black paint with flames on the grass-box.
PostPosted: 20:20 - 12 Mar 2017    Post subject: Reply with quote
https://www.blmra.co.uk/
Must happen.
PostPosted: 20:30 - 12 Mar 2017    Post subject: Reply with quote
Get it on a dyno....Let's see those graphs.
Pretty sure you can get a carbon collector on eByGum.
pepperami
PostPosted: 20:48 - 12 Mar 2017    Post subject: Reply with quote
Hmmm? Sub-frame looks twisted Thinking
recman
PostPosted: 21:36 - 12 Mar 2017    Post subject: Reply with quote
It really must be fitted with a twist throttle. Thumbs Up
andyscooter
PostPosted: 22:04 - 12 Mar 2017    Post subject: Reply with quote
Pimp my mower Laughing
I might join in
trevoriv
PostPosted: 22:18 - 12 Mar 2017    Post subject: Reply with quote
Must happen.
"grass roots motor sport"
trevoriv
PostPosted: 22:22 - 12 Mar 2017    Post subject: Reply with quote
I don't suppose you fancy tinkering with my Honda HRX426? It's a proper shed.
stevo as b4
PostPosted: 02:15 - 13 Mar 2017    Post subject: Reply with quote
Excellent behaviour! Thumbs Up
I do agree though that a set of MX renthals and a quick action twist grip throttle would be so appropriate too!
I like the thought of a vertical stack exhaust too with a rain cap on it to finish off the engine pimping too!
In my sick mind I can see it painted in gauloises colours with a big yellow 46 on the fuel tank too. Laughing
Actually it reminds me of the Atco hover mower I rebuilt 10years ago, and did another clueless twat Stevo tune on.
At least with a pit bike carb there's no butterfly to file down and knife edge, to the point where it's such a poor fit you get a 2000rpm idle. Also it's at least the second two stroke engine I've totally fucked up by deciding to skim a massive amount off the head/block face. It nearly broke the recoil with the compression after that, and I'm too scared to run it again as I since found out the engine runs a flimsy aluminium con rod, and I might have ripped the governor mechanism off too.
trevor saxe-coburg-gotha
PostPosted: 05:21 - 13 Mar 2017    Post subject: Reply with quote
Is there a Bol d'Or for mowers?
UnknownStuntm...
PostPosted: 09:15 - 13 Mar 2017    Post subject: Reply with quote
Get it lowered too.
PostPosted: 09:55 - 13 Mar 2017    Post subject: Reply with quote
If you're cutting rye grass, don't forget to wear your Grainpal.
iooi
PostPosted: 10:04 - 13 Mar 2017    Post subject: Re: Qualcast Suffolk Punch - Cylinder cut Lawn Mower Reply with quote
Trailer with seat on Thumbs Up
binge
Emo Kiddy
PostPosted: 18:39 - 13 Mar 2017    Post subject: Reply with quote
Regarding lowering it.
It's actually got an adjustable ride height already, for cut length. Laughing
And as for a trailer with a seat on.
I've already thought about making some sort of buggy-board to stand on.
I'll look like i'm mowing my lawn on a fucking segway. Laughing
PostPosted: 18:57 - 13 Mar 2017    Post subject: Reply with quote
^^^Universal joints. Wink Unless your lawn is level then a simple pivot will do.
Andy_Pagin
PostPosted: 19:26 - 13 Mar 2017    Post subject: Reply with quote
Chrome up the bare metal and bootstrap housing, shiny paint job and BCF stickers.
UnknownStuntm...
PostPosted: 20:08 - 13 Mar 2017    Post subject: Reply with quote
#thatwasthejoke
But it's got the plastic collector. I don't think I'm in any way a purist, but really they need a rusty, dented to buggery effort up front that clanks and rattles over every bump. Bonus points if it comes off on its own when it's full. Protip: bending the tangs in a bit helps locate the collector during the pitstop.
Andy_Pagin
PostPosted: 22:50 - 13 Mar 2017    Post subject: Reply with quote
I'd go for a custom Birmabright allow collector.
The last post was made 9 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 109.28 Kb
