Quick one about carbs
MarkGoy
PostPosted: 23:15 - 13 Mar 2017    Post subject: Quick one about carbs Reply with quote
Does this look right? (petrol feed inlet)
model : GZ125 , year 2003, <10'000 miles.
Snod Blatter
PostPosted: 23:43 - 13 Mar 2017    Post subject: Reply with quote
Hard to tell from just a pic, but it does kinda look like it has been jabbed/"cleaned" with something pointy. Has anyone been in there before? Were the float bowl screws mashed?
If you put the float needle into its hole, does it seal? You can blow on the inlet where the pipe would fit to see if it works.
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
MarkGoy
PostPosted: 00:10 - 14 Mar 2017    Post subject: Reply with quote
No idea, im the 6th owner.
I've replaced the floats and needle so I don't know that either. I don't recall seeing anything out the ordinary with those.
I've made a video if you wouldn't mind looking, I don't think it does seal properly.
The carb leaks you see.
https://m.youtube.com/watch?v=wNoyJGIP4Dg
After 1:15
PostPosted: 00:14 - 14 Mar 2017    Post subject: Reply with quote
Often the needle comes with a new valve seat. In this case I suspect you need that bit as well
Katy
MarkGoy
PostPosted: 00:27 - 14 Mar 2017    Post subject: Reply with quote
Hi Katy,
Sorry to be thick but what is a needle seat normally made of?
I bought new needles for this carb and that's all I've got, does this model not have a seat? Do all carbs get seats?
jaffa90
Katy
I agree the needle seat is damage.
MarkGoy
PostPosted: 00:36 - 14 Mar 2017    Post subject: Reply with quote
Sorry, I'm inexperienced in this tiny bit.
Needle seat : that's the metal bit I'm asking about?
If so how do I replace it?
Just had a look on wemoto, don't seem to have that part?
PostPosted: 00:38 - 14 Mar 2017    Post subject: Reply with quote
The brown bit is the needle seat. Normally this is a brass insert, which can normally be removed. Not sure if that one can as I can't see anything to hold it in place ( which suggests it is an interference fit).
Do you have a parts list for the bike / carb?
Not sure on the exact model but on CMSNL it looks like the seat is supplied with a new needle. Part 14:-
https://www.cmsnl.com/suzuki-gz125c-2000-y-e01_model13790/partslist/FIG9.html#results
Katy
MarkGoy
PostPosted: 00:45 - 14 Mar 2017    Post subject: Reply with quote
Right, that metal bit where the needle sits is the needle seat, there are no missing parts.
Ok.
Parts list, I've seen it, don't know how to find right now..
jaffa90
PostPosted: 02:06 - 14 Mar 2017    Post subject: Reply with quote
Usually if the needle valve has a rubber tip then the seat is metal, also if the needle valve is all metal then the seat is rubber.
PostPosted: 07:24 - 14 Mar 2017    Post subject: Reply with quote
It's just a piece of brass with a hole in it, the cone of the needle seals in the hole. If the edge is damaged or burred then it won't seal.
Take it to an engineering shop and have them drill or ream it out a tiny bit. This will restore the sealing edge. If you were near me I would do it in a few minutes.
You'll need to re-set the float height afterwards but it'll be like new again.
MarkGoy
PostPosted: 10:51 - 14 Mar 2017    Post subject: Reply with quote
It's worth a shot before getting a new carb.
By re-set float levels do you mean to book settings, or changed to cope with a bigger inlet hole?
I'll take a look around, im close to Sheffield, im sure there's a few places about capable of it.
PostPosted: 13:44 - 14 Mar 2017    Post subject: Reply with quote
A bigger hole will raise the fuel level in the bowl. Mine you, so will a leaky float valve.
MarkGoy
PostPosted: 14:50 - 14 Mar 2017    Post subject: Reply with quote
Aah, right.
Would it not be better to get a new carb? If that thing can't be replaced and I have to muck about with the float levels?
PostPosted: 15:16 - 14 Mar 2017    Post subject: Reply with quote
MarkGoy wrote:
Aah, right.
Muck about? It's bending a tang, Laughing
MarkGoy
PostPosted: 15:31 - 14 Mar 2017    Post subject: Reply with quote
Is it literally just bending a tang? I don't have to change air/fuel or Jets or anything like that?
PostPosted: 17:50 - 14 Mar 2017    Post subject: Reply with quote
Literally just bending a tang. Thumbs Up
https://www.dansmc.com/carb8_9.jpg
MarkGoy
PostPosted: 17:56 - 14 Mar 2017    Post subject: Reply with quote
alright cool, thanks Smile
Petemate
PostPosted: 18:57 - 14 Mar 2017    Post subject: Reply with quote
Dunno about your carb OP, but mine has a seat which is pretty well impossible to remove, and is not shown on the parts list for my carb. Also the float in my carb is one piece plastic, with no adjustment of the float valve operating tang possible, unless one wants to experiment with a heat gun...
But then, my bike is after all 33 years old and I guess some younger machines are a bit more user-friendly!
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
The last post was made 9 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 100.7 Kb
