CB500S - Noises?
Falco
PostPosted: 23:21 - 11 Mar 2017    Post subject: CB500S - Noises? Reply with quote
So riding home today I noticed a couple of odd noises. Since the last 2 bikes were rockers rather than shims, I'm not sure what is normal (and what is not).
There is a sort of high pitched noise/slight clack? over the top of the revs. Hoping its just the sound of the engine.
Robby
Dirty Old Man
PostPosted: 12:35 - 12 Mar 2017    Post subject: Reply with quote
Sounds like a CB500 to me. I can't hear anything unusual in the video.
Usually extra metallic ticking noises can be traced back to:
- Leaking exhaust gaskets
- Valve clearances way too big.
- Clutch noise from unbalanced carbs
- Cam chain tensioner - but I'm just putting this in to please the CBR600 owners.
Valve clearances and carb balancing are part of routine maintenance, so I would do them - in that order - and then see how it sounds.
Falco
PostPosted: 16:58 - 14 Mar 2017    Post subject: Reply with quote
Thanks Robby.
-Exhaust gaskets are nice and tight.
-Valves clearances are being put off for a couple of weeks till I have a whole weekend to get it apart, check them and then put it back together again while waiting for new shims to arrive. I could be wrong, but don't valves usually close up with wear?
-Carb balancing is next on the list after valves.
Petemate
PostPosted: 19:00 - 14 Mar 2017    Post subject: Reply with quote
Camchain tensioner and/or guide?
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
Falco
PostPosted: 21:37 - 14 Mar 2017    Post subject: Reply with quote
You reckon? I've never had one of these engines before, but that was one of the things that I thought I could rule out? I'll have a look at the guide, tensioner and chain itself when I do the clearances.
RhynoCZ
PostPosted: 21:58 - 14 Mar 2017    Post subject: Reply with quote
Before you start taking things apart, reset the tensioner. This might fix your issues.
Falco
PostPosted: 22:52 - 14 Mar 2017    Post subject: Reply with quote
Cheers, that's good advice. The other bits can be done when I have the valve cover off, but cleaning and resetting can be done next weekend.
RhynoCZ
PostPosted: 23:10 - 14 Mar 2017    Post subject: Reply with quote
I'm not 100% sure, but I asume you've got there the generic Honda spring loaded self adjusting tensioner. There's a bolt on top of it, which is just a cover for the ''reset screw'' inside. You just turn the reset screw left and then let go = done, reseted.
This type (used pretty much on any Honda bike from the 90's onwards)
https://i.ebayimg.com/images/g/j~EAAOSw0e9UragW/s-l300.jpg
The silver bolt on the top of it is the cover for the reset screw inside.
The last post was made 9 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 56.66 Kb
