Gearbox Rumbling
FlubbaBubba
PostPosted: 20:30 - 14 Mar 2017    Post subject: Gearbox Rumbling Reply with quote
Aprilia mx 125
The engine has just started whining/knocking. If you slip the clutch on pull of its bad but it only seems to be noisy when your on the throttle, its still there when you let of but its not to bad.
Cold start the noise is there and pulling the clutch in does nothing but the noise seems to get quieter as it warms up. If you rev it up in neutral its not to bad until you start riding it then it gets noisy.
All the gearbox, balance shaft and main bearings were replaced around 7000miles ago. Main bearings are koyo and the rest were skf.
The bike was also run with low gearbox oil for 3 weeks as one of the crank seals started to fail about a month ago. There was also a fair bit of swarf on the sump magnet.
Could it be a bearing on its way out?
Any help would be much appreciated, thanks.
Paulf
PostPosted: 20:48 - 14 Mar 2017    Post subject: Reply with quote
It sounds like it from what you say. Not heard the noise but if it is not there all the time it rules out the main and big end. Can you figure the likely candidate. If it purely a splash type gearbox they don't like low oil levels and can quickly go bad.
FlubbaBubba
PostPosted: 21:21 - 14 Mar 2017    Post subject: Reply with quote
Its a splash fed box which takes 600ml an 230ml was drained out when cold when it was low.
The noise seems to be there all the time but gets quieter when warm, it sounds more like a rumbling noise then knocking.
Im hoping its the balance shaft bearings and not the mains.
Thanks.
Paulf
PostPosted: 22:01 - 14 Mar 2017    Post subject: Reply with quote
Which bearing is the highest from the sump.would probably be the most likely candidate. Less oil to bathe in. But 230 mls seems low compared to 600 mls capacity probably accelerated wear caused by oil starvation. Good luck it looks like a gearbox rebuild.
Pete.
PostPosted: 22:44 - 14 Mar 2017    Post subject: Reply with quote
Failed crank seals & rumbling in neutral = main bearings.
a.k.a 'Geri'
Paulf
PostPosted: 23:49 - 14 Mar 2017    Post subject: Reply with quote
Sorry missed failed crank seal I concur with previous post could be connected. Has bearing fails it run eccentric and wears the seal out and then as it progresses as the balls or rollers become more worn it starts to rumble.
FlubbaBubba
PostPosted: 17:17 - 15 Mar 2017    Post subject: Reply with quote
Pulled the bottom end apart, there is no play in the crank on either side, and there is no play in the balance shaft or the gearbox shafts.
Got a second opinion on it and there saying its piston related as it gets worse under load a there seems to be a fair bit of vibration on the cylinder/head.
Paulf
PostPosted: 20:01 - 15 Mar 2017    Post subject: Reply with quote
Well in a way that's easier to sort.
The last post was made 9 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 57.03 Kb
