what is this damn ticking..
Hahadumball
PostPosted: 21:28 - 16 Mar 2017    Post subject: what is this damn ticking.. Reply with quote
vtr had front cct failure..
got a new head bla bla
started it up it sounded fine.. then started to tick as the timing was out and bent valve on new head
head rebuilt put on
started up fine all good however it seems to be ticking...
i got head off, all valves good however 1 intake valve was sticking ever so slightly to 0.30mm gap before fully closed.
rode it for a week in the hope it frees itself up, still doing it so took the head off to find the valve is pretty much shut, my smallest feeler 0.002 wont even go in the gap it leaves but if you push it you get a little tap as it seats...
unless the valve sticking suddenly stopped and fixed itself as soon as id turned the ignition on and only left this little gap.. the sound hasnt changed so could it be something else?
bike ran fine, no real missfiring except from badly tuned carbs
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
jjdugen
PostPosted: 00:45 - 17 Mar 2017    Post subject: Reply with quote
Not sure where your at on this head, but if a valve has connected at some time you could well have a damaged valve guide. Sounds like it to me if the valve is sticking.
davethekwak
PostPosted: 09:01 - 17 Mar 2017    Post subject: Reply with quote
Wear in a small end bearing on con rod can also manifest itself in ticking. Big end tends to be a knock.
ZX6R G2 (1999) & ZX6R F2 (1996). I like ZX6!
PostPosted: 09:40 - 17 Mar 2017    Post subject: Reply with quote
The gap in the valve will be because it's bent.
owl
PostPosted: 10:53 - 17 Mar 2017    Post subject: Reply with quote
£500
Observation is the greatest source of wisdom.
Hahadumball
PostPosted: 11:52 - 17 Mar 2017    Post subject: Reply with quote
the gap was big now its not, surely it cant straighten itself in the guide
Minty
PostPosted: 12:01 - 17 Mar 2017    Post subject: Reply with quote
Bent = shorter end to end length. Hence gap now narrowed.
My fingers smell of your mum.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:50 - 17 Mar 2017    Post subject: Re: what is this damn ticking.. Reply with quote
This was what the exxon valdes was doing just before it dropped a valve.
Triumph Sprint ST 1050
Baggyman
PostPosted: 17:13 - 17 Mar 2017    Post subject: Reply with quote
If you have prosthetic hand, it may well be a crocodile.
Old fart
Baghira, modded GS1000 and the T150 I bought in 1978 when I was 21
Evil Hans
PostPosted: 17:43 - 17 Mar 2017    Post subject: Reply with quote
Or having failed to fatally run you over, your ex has put a bomb in it.
Baggyman
PostPosted: 18:29 - 17 Mar 2017    Post subject: Reply with quote
Its not you. Its Smee
Old fart
PostPosted: 18:36 - 17 Mar 2017    Post subject: Reply with quote
If the gap WAS big then the ticking was due to the 30 thou too much clearance on the follower. Either there was some debris under the lip of the valve from the last blow-up or the head has made contact and it was bent a little. I had a GS550 like it, you could just see the tiny bit of tilt in the valve head as it seated, the head was a little bent.
Carry on riding it if you feel confident. Hopefully it won't blow up, seize and spaz your remaining good leg.
Evil Hans
PostPosted: 19:10 - 17 Mar 2017    Post subject: Reply with quote
Nice Very Happy
Hahadumball
PostPosted: 20:56 - 17 Mar 2017    Post subject: Reply with quote
im happy to change the valve if need be, im just curious wtf this ticking is...
the gap was big
it made a sound
the gap is now minute
it makes the same sound
could it still be the same valve? surely the tone would change,
i must get this valve out and check
Baggyman
PostPosted: 00:04 - 18 Mar 2017    Post subject: Reply with quote
the gap was big
it made a sound
Do you have a copy of the William Topaz McGonagall book of mechanics?
Old fart
The last post was made 9 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 86.04 Kb
