Tyre Combinations
Liono
PostPosted: 21:40 - 03 Mar 2005    Post subject: Tyre Combinations Reply with quote
My rear tyre is on its way out, so I need a replacement fairly soon. Now, I've been told not to mix tyres, but to what extent does this apply? I have a set of Bridgestone BT020s on at the moment, but was wondering if a BT010 would go on the back OK? Is mixing tyres just one of those things you shouldn't really do, or will very bad things happen if I do it? The reason I ask is that I've seen a cheap 010, and the budget is my main concern at the moment!
mattsmith95
PostPosted: 23:12 - 03 Mar 2005    Post subject: Reply with quote
Who told you?? whoever it was is talking bollocks.
PostPosted: 23:18 - 03 Mar 2005    Post subject: Reply with quote
For best results do not mix tyres, but generally they will be OK.
A lot of people mix the BT010 and the BT020, but normally with the 010 on the front (it is a stickier tyre, and you would rather loose the back than the front).
mattsmith95
PostPosted: 23:26 - 03 Mar 2005    Post subject: Reply with quote
Bottom line is that it's recommended to use the same brand and types on both front and rear. There is nothing wrong with mixing, it's down to your personal taste.
Scooby
Scrappy Doo
PostPosted: 23:59 - 03 Mar 2005    Post subject: Reply with quote
Stick with designated pairs if you can. Like Keith says though you want a slightly stickier front than rear if it comes to it though, not the other way round. There are some tried and tested combinations that work, i.e. 010 F and 020 R, but unless it's a tried and tested combination by many bikers I wouldn't like to be the one that is the guinea pig. Get a pair of 014's on it Very Happy
PostPosted: 00:17 - 04 Mar 2005    Post subject: Reply with quote
To be honest I have mixed tyres loads of times. Never really had a problem. Only one I have had an issue with is the combination on my RS125 at the moment with a Michelin on the front and a Dunlop Sportmax on the back and that does not feel right. Used mixes of Dunlop, Avon and Michelin on the FZ750. The Bandit had an Avon front and Bridgestone rear for a while (worked well to be honest). The FZR had a pair of totally unmatched Bridgestones on it when I bought it, and got used around Silverstone like that.
pete-dotphp
PostPosted: 02:24 - 05 Mar 2005    Post subject: Reply with quote
Personally I find the idea that mismatching your tyres will have adverse affects as overrated. I've been running a Michelin Battleax front with Bridgestone BT45 rear on my GS for the last 10,000 miles with no bother. New tyres that haven't been broken in, incorrect tyre pressures or badly worn rubber will have much worse affects on your handling. As long as the sizes and intended useage are the same as spec, you should be fine.
Of course, I am assuming you haven't completely mismatched your tyres, like fitting a tyre 2 sizes too big on the front and a Cheng-Shin from a CG125 on the back Wink
Edit: the 010 is more of a sports tyre so might be a false economy, if you're concerned with budget a 020 might be a better idea as you'll probably get more miles out of it.
PsychoHippy
Jammy Git
PostPosted: 03:26 - 05 Mar 2005    Post subject: Reply with quote
Don't Bridgestone make the Battleax tyres? I'm fairly sure they do.
So you are saying that you have ridden 10000miles with Bridgestone front and back with no problems. Can't say I'm surprised really Wink
I spend all my money on bikes and beer, the rest I simply waste!
strag
PostPosted: 03:51 - 05 Mar 2005    Post subject: Reply with quote
I had the 010/020 combi on my bike, did a track day etc, and know loads of people that do. No problems.
carbon bling
pete-dotphp
PostPosted: 12:31 - 05 Mar 2005    Post subject: Reply with quote
So you are saying that you have ridden 10000miles with Bridgestone front and back with no problems. Can't say I'm surprised really :wink:
Heh, that would explain it...
scottiel
PostPosted: 13:58 - 05 Mar 2005    Post subject: Reply with quote
What type of bike do you have. if you have sports bike i would keep a matchin pair on, but if you have to mix the 010 would be better on the front as it is stickier. Very Happy
Liono
PostPosted: 16:12 - 05 Mar 2005    Post subject: Reply with quote
Cheers for the advice, my main concern was budget. Well, actually, my main concern was my girlfriend telling me off for spending even more money on my bike! I've actually decided to spend a little extra and get an 020 for the rear again rather than the 010, as I've found them to be a bit cheaper than I thought they were going to be anyway.
Dr Nick
PostPosted: 16:39 - 05 Mar 2005    Post subject: Reply with quote
Im BT010 front and D207 rear, had to sign a disclaimer thing at the tyre place Laughing and he told me about 50 times that it would messup handling. The 010 front is newish and i didnt want another shitty bridgestone that would last 1000~ miles Thumbs Down , feel a lot more confident on the 207's too.
is that it
PostPosted: 16:46 - 05 Mar 2005    Post subject: Reply with quote
Do you have someone sneak in at night and attack your tyres with a sander? Just had to replace a BT010 on the FZR (due to a couple of nails). That had done about 3000 miles and was less than half worn, with commuting use.
Villers
PostPosted: 19:13 - 06 Mar 2005    Post subject: Reply with quote
My BT014 is on its way out after the winter commuting. It went on in october\november and has done about 3000 miles. Im prepared to put up with that for the level of grip it gives and the confidence it inspires. A mixed pair of 010's and 020's doesnt sound so bad. Its prob when theres a noticeable difference in the level of grip bewteen front and back that I would worry. As well as two tyres that warm up at differing rates.
The last post was made 21 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 87.28 Kb
