Drill recommendations
duhawkz
PostPosted: 22:08 - 19 Mar 2017    Post subject: Drill recommendations Reply with quote
My today my black and decker drill bit the dust. It was only a cheap thing and i was using with a 50mm core bit to make hole for a waste pipe.
Anyhow that's the third cheap drill I've killed, so I'm looking to replace it with something built to last.
I'm looking for a corded drill, mainly used for general masonry/woodwork sometimes general metalwork too.
budget maybe about 100 quid
PostPosted: 22:23 - 19 Mar 2017    Post subject: Reply with quote
Get two.
Get an SDS for masonry.
Get a normal, variable speed one for metalwork.
NEVER use the second one in hammer mode.
Go to the shop and pick one that has the least sideways play on the chuck. Good luck with that because most of them are shite. Even the "good" ones.
BTTD
PostPosted: 22:32 - 19 Mar 2017    Post subject: Re: Drill recommendations Reply with quote
Not sure if it can be done.
I was looking for something with a proper two speed gearbox - the variable speed drill I have has utterly crap torque at low speeds - but they seem to be harder to find.
I like the look of this, bit above the budget though.
https://www.powertoolworld.co.uk/bosch-gbm-13-2-re-professional-2-speed-impact-rotary-drill
kramdra
PostPosted: 22:38 - 19 Mar 2017    Post subject: Reply with quote
stinkwheel wrote:
Get two.
They are easily improved by removing the hammer selector and shimming the ball bearing end of the shaft. The plain bearing is shit even when new but can be disassbled and replaced.
robs321
PostPosted: 09:44 - 20 Mar 2017    Post subject: Reply with quote
Buy an SDS and a chuck adapter!
Baggyman
PostPosted: 10:14 - 20 Mar 2017    Post subject: Reply with quote
Agree with the SDS for masonry Buy a cheap one from Aldi/Lidle - 2 year guarantee. Knacker it, money back
Buy two if you cannot be without one
I have an Aldi SDS which has lasted 10 years so far and still going strong with pretty regular usage - my house has solid walls and the drill has not missed a beat - including using big core drills for waste and extractor vents
You can also use it "hammer only" so with chisel bits - that is really handy
Old fart
Baghira, modded GS1000 and the T150 I bought in 1978 when I was 21
The last post was made 9 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 48.51 Kb
