What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 242, 243, 244 ... 407, 408, 409  Next
PostPosted: 22:30 - 25 Mar 2017    Post subject: Reply with quote
Fisty wrote:
Rogerborg wrote:
[Surrenders Man Card]
Skirt wearing nancy.
Cock tease.
Islander
PostPosted: 23:03 - 25 Mar 2017    Post subject: Reply with quote
We decided to go for a ride out today but it was not to be.
The R850R is awaiting a set of Goodridge brake hoses so that's not available.
I've serviced the M750 so that's good to go. That's my OH sorted then.
Right-ho thought I, I'll take the Zephyr for novelty's sake. Rolled it out, primed the carbs, pressed the starter, dead. Battery shows 13v until a load is put on it so high resistance cell, dead battery. Oh well these things happen, make a mental note to get a new one.
Next, roll out the Hornet. Deactivate alarm, press starter, dead. Battery shows 9v. Arse. Add new battery for Hornet to shopping list.
Roll out the M900, turn key, press starter, turns over nicely - it's stood for a few months so it'll take a few turns to prime the carbs. Press starter again, OH points to copious amounts of fuel appearing on the crankcases, ask her to watch to see what's happening, press started and fuel is pissing out of one of the pump hoses - the inlet hose is split wide open. Shocked
So out of 5 bikes, 1 is operational. I could take this personally. Laughing
Plans scrapped, run into town to speak to friendly bike mechanic and come away with two shiny new motobatts. Zephyr and Hornet are now running nicely, the M900 is in the workshop awaiting my attention - I always keep a metre of each type of hose on the shelf so it should be a quick fix.
FML. Laughing
kramdra
PostPosted: 00:07 - 26 Mar 2017    Post subject: Reply with quote
Swapped tires. Rear PR4 has got near the limit in centre, but picked up a lot of deep cuts. Only 7800, was expecting 10! changed it early. The Front PR4 Im saving for next winter, it only been on 2 months and hardly worn, but excellent. Fitted a pair of Racetec's
Also bought a compressor, made it much quicker.
ThatDippyTwat
PostPosted: 08:39 - 26 Mar 2017    Post subject: Reply with quote
Rogerborg wrote:
Took the baffle out of the £15.20 chavzorst.
ASBO level get.
Rode like a cad for a full 30 seconds, then spent the rest of the journey to the shops trying to find the quietest throttle setting, mentally apologising to triggered pedestrians and dogs.
Got to shop, put the baffle back in.
I took it out of the chavzorst. Put it back in about a minute later. I leave for work at 5:30AM frequently, and I'd like to keep the level of "neighbours that want to kill me" about where it is.
Chain waxed, tensioned etc, for a nice run out through the Nant-y-Garth and Horseshoe passes today to go to a job. I might even take piccies.
fluxco
PostPosted: 14:08 - 26 Mar 2017    Post subject: Reply with quote
not strictly working on the bike, but I did a 3D print of a donut for my helmet
https://i150.photobucket.com/albums/s118/cheunky/Honda%20NC30/IMG_3255_zpsmh8w1kvj.jpg
https://i150.photobucket.com/albums/s118/cheunky/Honda%20NC30/IMG_3253_zps6f3tvhoe.jpg
NJD
PostPosted: 14:17 - 26 Mar 2017    Post subject: Reply with quote
fluxco wrote:
3D print
Can do one of Fisty's manhood so at least we get some delivery?
I've no idea what the bet he lost was.
fluxco
PostPosted: 14:46 - 26 Mar 2017    Post subject: Reply with quote
hows this for size?
https://i150.photobucket.com/albums/s118/cheunky/Honda%20NC30/IMG_3257_zpsajqvr0xo.jpg
NJD
PostPosted: 14:52 - 26 Mar 2017    Post subject: Reply with quote
fluxco wrote:
hows this for size?
No wonder he's camera shy.
Sod the size it's the arrangement I'm alarmed by.
Either he has one ball and, somehow, the dingaling growing out of it or you missed sex ed classes.
I'll leave you both to sword fight for the correct answer.
Johnnythefox
PostPosted: 15:28 - 26 Mar 2017    Post subject: Reply with quote
Bike wouldn't start, battery measured 13v, changed plugs, as quite fouled, bike starts, need to sort mixture as would indicate running rich.
thx1138
PostPosted: 15:57 - 26 Mar 2017    Post subject: Reply with quote
Rode Honda 50cc to church, wouldn't start afterwards. Pushed it to a friends house 2 streets away, and removed spark plug and cleaned plug and adjusted gap and replaced, after checking for spark and comparing with assorted 2nd hand plugs he had lying around and generally prodded and poked and fiddled it until it did start again.
Think I need to turn the fuel off when I stop, and make sure throttle is shut off when I switch engine off, and probably actually need a new spark plug.
waffles
PostPosted: 16:43 - 26 Mar 2017    Post subject: Reply with quote
Pulled both bikes out of the garage for a check over.
On the msx - fitted the brake hose adapters so the braided lines don't move around, refitted the headlight, fitted the little windscreen, adjusted the mirrors, decided I don't like the mirrors so might take them off completely, fired it up to check all connectors were plugged in properly.
On the gixer - removed pillion pegs and seat to refit the solo hump, removed the satnav cradle, gave it a bit of a clean over. Tried to fire it up but the battery was so dead the fuel pump wouldn't prime so I left it on trickle charge for a bit.
Both need tyre pressures checked and chain lubed. But I will do that during the week.
DRZ4Hunned
PostPosted: 17:09 - 26 Mar 2017    Post subject: Reply with quote
Changed clutch cable on DRZ, much lighter pull now but what a ball ache of a job!
DRZ400-SM
FZS600
PostPosted: 17:30 - 26 Mar 2017    Post subject: Reply with quote
De-"fluxed" the Enfield with vinegar and tin foil. Now I smell of chips and paranoia.
grr666
PostPosted: 17:34 - 26 Mar 2017    Post subject: Reply with quote
Thrashed the absolute fuck out of it.
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
B0ndy
PostPosted: 18:47 - 26 Mar 2017    Post subject: Reply with quote
Try turning it round the other way Rolling Eyes
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H
PostPosted: 18:51 - 26 Mar 2017    Post subject: Reply with quote
Folding mirror (£3 from an autojumble) and a bicycle speedo for t'Enfield.
https://3.bp.blogspot.com/-mM3ylBZYHAA/WNfpS0EeenI/AAAAAAAAAdM/kBfjjKKtEPMl3auWGfxX7pWRmlEKpwADwCK4B/s1600/IMG_0649-770949.JPG
https://2.bp.blogspot.com/-hwi4r96IE9A/WNfpSg165kI/AAAAAAAAAdE/WhA_JlcyINUSms1bicX57pnPP3-xgX00QCK4B/s1600/IMG_0650-770420.JPG
https://3.bp.blogspot.com/-OchFvuPRYfA/WNfpSqnjLaI/AAAAAAAAAc8/F8YpbXs9r1MiI5CKT4evqfq0tCc9O3EywCK4B/s1600/IMG_0651-769674.JPG
fluxco
PostPosted: 19:11 - 26 Mar 2017    Post subject: Reply with quote
Repaired a broken tab on the rear fairing with more 3D printed parts
https://i150.photobucket.com/albums/s118/cheunky/Honda%20NC30/IMG_3259_zpsl3yo0hrw.jpg
https://i150.photobucket.com/albums/s118/cheunky/Honda%20NC30/IMG_3260_zpsxzv7uior.jpg
https://i150.photobucket.com/albums/s118/cheunky/Honda%20NC30/IMG_3261_zpscuohxuux.jpg
https://i150.photobucket.com/albums/s118/cheunky/Honda%20NC30/IMG_3272_zps0zfdjz1a.jpg
Falco
PostPosted: 19:56 - 26 Mar 2017    Post subject: Reply with quote
Cleaned and adjusted chain. Checked oil level, took apart rear indicator and reseated the lens which was partially knocked out when I dropped the bike on that horrible foggy night last week. Nothing exciting.
I tell you what, mathematically, I'm having it
PostPosted: 22:45 - 26 Mar 2017    Post subject: Reply with quote
How are you finding that? I had a vaguely similar set a while back, but they were so vibey that they went into the Box of Pretend I Never Bought It.
Matt B
PostPosted: 09:10 - 27 Mar 2017    Post subject: Reply with quote
Vinegar a necessity or a performance improvement? I thought the tinfoil thing worked with just a bit of water. Have you noticed a difference between malt, cider, balsmic etc?
PostPosted: 09:37 - 27 Mar 2017    Post subject: Reply with quote
It's to reduce (SCIENCE, BITCHES) the oxidation. Any exposed red oxide turns black pretty much instantaneously.
I only use Morrisons very best prole-budget generic brownish malt, then give it a good rinse down afterwards.
PostPosted: 12:09 - 27 Mar 2017    Post subject: Reply with quote
Happy at three quid Smile I now no longer have to do Linda Blair impressions when joining dual carriageways, and it gives me a few more precious inches width in the garage. As with all of my previous Enfields, the vibes mean that you can't tell what type of car is behind you, but you can tell whether there is one or not, and how quickly it is approaching.
recman
PostPosted: 19:44 - 27 Mar 2017    Post subject: Reply with quote
During a spirited ride to properly test the front brakes, I stopped to see if there was any binding.
Discs were easily touchable so all was well, however the rear disc was like touching a bloody iron*.
So I gave the caliper a good wiggle and set off home.
A good all round scrub, liberal application of copper grease and fresh fluid has it sorted.
*not the Graham Norton type.
asta1
PostPosted: 20:49 - 27 Mar 2017    Post subject: Reply with quote
Yesterday the bike got cleaned, clutch free play adjusted and the coolant topped up. I also cleaned my stupid chain again.
Today I commuted to work and back. Bike is dirty, but it was warm, sunny and I had an excellent time filtering through 6 miles of stopped traffic (M42 was closed for a bit) grinning smugly at frustrated car-ists and chuckling to myself the whole way. Fun times.
CBT Acquired: 09/07/2015
A2 Licence Passed: 12/02/16
Current Bike: Yamaha MT-07 bought 02/07/16
The last post was made 7 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 243 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 0.22 - MySQL Queries: 15 - Page Size: 135.26 Kb
