Moped Stuck on Full Revs
Sam_brycee
PostPosted: 17:35 - 30 Mar 2017    Post subject: Moped Stuck on Full Revs Reply with quote
When I start my Peugeot Speedfight 2 the throttle is on full and I have to cut the engine to stop it.the back wheel spins at full speed and only stops with the break. The throttle cable seems okay but I really am stuck here. Any help would be much appreciated.
Quote Me Happy
PostPosted: 17:36 - 30 Mar 2017    Post subject: Reply with quote
Air leak on the intake?
jaffa90
PostPosted: 17:39 - 30 Mar 2017    Post subject: Reply with quote
""""The throttle cable seems okay"""""
Could it be the choke on full?
TbirdX
PostPosted: 17:55 - 30 Mar 2017    Post subject: Reply with quote
Aren't all peds supposed to be ridden like that?
Jump on and impress the girlies, 1 hand wheelies for extra points.
VFR800X - TTR250
Sam_brycee
PostPosted: 18:05 - 30 Mar 2017    Post subject: Reply with quote
The bike has an auto choke.
Sam_brycee
PostPosted: 18:06 - 30 Mar 2017    Post subject: Reply with quote
I'm 16 and a novice with Bikes/peds. Could you explain a bit better in terms that I would understand? Ahaha
Sam_brycee
Only if it worked like that ahah.
Baggyman
PostPosted: 18:30 - 30 Mar 2017    Post subject: Re: Moped Stuck on Full Revs Reply with quote
Sam_brycee wrote:
The throttle cable seems okay.
can you post photos of both ends please. Could just be the outer not seated
When you twist the throttle, does it feel right and return properly?
Photos at the carb end with the twist grip not twisted then twisted
Old fart
Baghira, modded GS1000 and the T150 I bought in 1978 when I was 21
Billy Balthorpe
PostPosted: 18:47 - 30 Mar 2017    Post subject: Reply with quote
It couldn't have always been like this, what did you do to it between it running ok and running flat out? Have you had the throttle slide out of the carb and not put it back in the right way round?
M.O.B. Successfully taking the piss since 2014.
RhynoCZ
PostPosted: 18:51 - 30 Mar 2017    Post subject: Reply with quote
Yes,
Moped = A motorized bicycle that has pedals in addition to a low-powered gasoline engine designed for low-speed operation.
Scooter = A light motorcycle with small wheels and an enclosed engine.
When you twist the throttle and release it with the engine OFF, can you hear the click sound?
Sam_brycee
PostPosted: 18:56 - 30 Mar 2017    Post subject: Reply with quote
I got the bike and it didn't run because it had no battery. Got a battery. Cleaned the carb so I might not have put the cable back in properly but I only took off the bottom part of it.
RhynoCZ
PostPosted: 19:03 - 30 Mar 2017    Post subject: Reply with quote
Sam_brycee wrote:
Yeah I can hear a click sound when I turn it .
So the throttle works as it should. Did you fiddle with the idle screw?
Sam_brycee
RhynoCZ wrote:
Yes,
Yes I hear a click sound.
Sam_brycee
PostPosted: 19:04 - 30 Mar 2017    Post subject: Reply with quote
Nope not fiddled with it. Maybe the previous owner did?
Sam_brycee
PostPosted: 19:11 - 30 Mar 2017    Post subject: Re: Moped Stuck on Full Revs Reply with quote
Closed
https://i.gyazo.com/6ab3238b7cf8fc99af868e6473aa2a3b.png
Open
https://i.gyazo.com/ab99fe753fccbfb490a11b164c60adc1.png
Evil Hans
PostPosted: 20:32 - 30 Mar 2017    Post subject: Reply with quote
I'm ok with someone calling a 50cc scooter a moped. People that refer to larger scooters as mopeds offend my inner sperg immensely.
M.C
PostPosted: 21:18 - 30 Mar 2017    Post subject: Reply with quote
I've had people refer to my bike as a ped Evil or Very Mad
jaffa90
PostPosted: 21:42 - 30 Mar 2017    Post subject: Reply with quote
I KNOW.
Also that carb slide / needle should be lower in pic 1.
Sam_brycee
PostPosted: 21:47 - 30 Mar 2017    Post subject: Reply with quote
jaffa90 wrote:
I KNOW.
Do I adjust the air/mixture screw for that?
RhynoCZ
PostPosted: 23:18 - 30 Mar 2017    Post subject: Reply with quote
Don't touch the air/fuel mixture screw. Find the idle screw, start the engine and fiddle with that. The odds are the idle is just set sky high, for some reason.
The click sound, when you release the throttle means, the throttle gets to the idle position just fine.
A picture of the side of the carb would help, but I assume the brass screw with the spring is the idle screw. Thumbs Up
Billy Balthorpe
PostPosted: 00:00 - 31 Mar 2017    Post subject: Reply with quote
That little brass thing sticking out into the throat of the carb is stopping the throttle slide from going all the way down, start by unscrewing the brass screw (which looks like its wound all the way in) until the slide goes all the way down, start the engine and then adjust it to give you a sensible idle.
jaffa90
PostPosted: 00:18 - 31 Mar 2017    Post subject: Reply with quote
Sam_brycee wrote:
jaffa90 wrote:
I KNOW.
Ok then check the auto choke as well.
Sam_brycee
PostPosted: 06:55 - 31 Mar 2017    Post subject: Reply with quote
Thanks Very much, I will try this today and I'll let you know how it goes.
Sam_brycee
PostPosted: 06:56 - 31 Mar 2017    Post subject: Reply with quote
Thanks, I shouldn't start it when it's all the way closed should I?
Billy Balthorpe
PostPosted: 00:21 - 01 Apr 2017    Post subject: Reply with quote
Yeah you can, it probably just wont tick over if its closed too far. Just wind the screw out until the slide closes completely then wind it back in half a turn, start it up and set the tickover at a point where it isn't pulling too much, job done.
The last post was made 7 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 126.27 Kb
