Today, I have mostly been melting bike parts
nowhere.elysium
The Pork Lord
PostPosted: 14:50 - 06 Apr 2017    Post subject: Today, I have mostly been melting bike parts Reply with quote
A couple of you have expressed interest in the fact that I now have a small furnace, so I've decided to do a brief writeup.
https://c1.staticflickr.com/3/2842/33063666493_455be114ef_k.jpg
So, first things first - I wanted to get my new crucible sorted. My previous melts had been done with the first thing I could lay hands on (namely a cheapo ASDA cocktail shaker), just to get a feel for the process. Since then, I wanted to have a proper go at this, so needed something a bit more robust. Luckily, a mate of mine had an empty CO2 canister from his MIG welder, so we cut it open, and sized it up for a crucible.
https://c1.staticflickr.com/4/3703/33877298795_d680d3d471_k.jpg
Now, being as lazy as I am, I realised that I really couldn't be bothered to have at it with a flap wheel to get all the paint off. Instead, I just decided to put it in the furnace and run it up to a low temperature to bake all the paint and shit off instead.
https://c1.staticflickr.com/3/2844/33747784571_21e3531239_k.jpg, on Flickr
...Resulting in a fairly clean proto-crucible vessel:
https://c1.staticflickr.com/3/2930/33747783741_5874d0d430_k.jpg
In order to make this into a properly useful object, as opposed to 'a thing what I scavenged', I reasoned that I should at least give it a stable base, so cut a section of it down (to keep it short enough to fit in the furnace) to provide a ring for the base.
https://c1.staticflickr.com/4/3927/33033290564_262d9fa200_k.jpg
With that done, I lined it up...
https://c1.staticflickr.com/4/3894/33836093906_f4b09682e7_k.jpg
...And proceeded to make a complete pig's arsehole of welding it together:
https://c1.staticflickr.com/4/3941/33747782121_18b7143b32_k.jpg
In my defence, I only got the welder yesterday, and I've never done anything with MIG before. Regardless, it scrubbed up OK (if you squint a bit, and the lighting's poor).
https://c1.staticflickr.com/3/2873/33747781541_f595e79e6f_k.jpg
That said, it's not like the furnace will give the slightest shit, so meh.
https://c1.staticflickr.com/4/3938/33063670133_bf38d0e7dd_k.jpg
So, beyond this point it's largely a case of applying both metal and heat to the crucible to make the magic happen:
https://c1.staticflickr.com/4/3816/33747779741_a443e722f1_k.jpg
With enough of that, you'll eventually end up with this:
https://c1.staticflickr.com/3/2862/33063668493_7be26f5d3a_k.jpg
Which is a bean tin full of molten aluminium. I'm melting down a lot of stuff at the moment for a future project that's coming up. I want to have as much material ready to go as is possible, and, well, a tin-sized object takes up a lot less room than the ZZR subframe it started life as.
Also, bonus video! Before anyone passes comment, yes I know my breathing makes me sound like a rapist - allergies plus diminished lung capacity will do that.
nowhere.elysium
The Pork Lord
PostPosted: 15:02 - 06 Apr 2017    Post subject: Reply with quote
Now that stuff has cooled down sufficiently to peel the bean can off, we can see the final result:
https://c1.staticflickr.com/3/2900/33836095586_7c1f54637e_k.jpg
Hahadumball
PostPosted: 15:04 - 06 Apr 2017    Post subject: Reply with quote
awesome write up, i was thinking you wouldnt deliver
ive toyed with the idea myself as i have a LOT of aluminium i could melt down and cast into weird and wonderful things.. maybe a new spine
also, i have those gloves... well not those because they're yours but mine are the same style
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
PostPosted: 15:10 - 06 Apr 2017    Post subject: Reply with quote
Whats the white stuff?
nowhere.elysium
The Pork Lord
PostPosted: 15:12 - 06 Apr 2017    Post subject: Reply with quote
Dross, from previous melts. Drinks cans produce an inordinate amount of the stuff, largely because they're so thin that the ratio of aluminium to aluminium oxide is fucking abysmal.
Well fuck you too Laughing
I'll do the new garage/toys writeup once I've got everything tidied and in a fit state.
Not something you'd really want to do with reduced mobility - you trip or stagger with a crucible full of molten aluminium, and a knackered back will be the least of your worries.
They're the cheapest welding gloves I could find at short notice.
PostPosted: 15:18 - 06 Apr 2017    Post subject: Reply with quote
I meant in the forge? Looks like insulation.
nowhere.elysium
The Pork Lord
PostPosted: 15:23 - 06 Apr 2017    Post subject: Reply with quote
Oh, yes it is. Ceramic blanket, it's called.
owl
PostPosted: 16:25 - 06 Apr 2017    Post subject: Reply with quote
only the first picture loads for me the rest are
https://s9.postimg.org/3kl61kksv/image.png
tried on a few devices Neutral
Observation is the greatest source of wisdom.
nowhere.elysium
The Pork Lord
PostPosted: 16:28 - 06 Apr 2017    Post subject: Reply with quote
Not sure what's happened there. They're all hosted on Google images, and I've made sure they're not https addresses.
PostPosted: 17:02 - 06 Apr 2017    Post subject: Reply with quote
I have a ally TDM frame and front wheel you are welcome too if you can do anything with it Give me a shout next time you are back these 'endz' if you want it.
Quote Me Happy
PostPosted: 17:03 - 06 Apr 2017    Post subject: Reply with quote
Same here.
nowhere.elysium
The Pork Lord
PostPosted: 17:27 - 06 Apr 2017    Post subject: Reply with quote
OK, pictures should be sorted now.
Chris - I might be in London tomorrow if you're about. Failing that, I should be down over the Easter weekend.
PostPosted: 17:37 - 06 Apr 2017    Post subject: Reply with quote
I won't be, but my dad will if you wanted to stop by, all the stuff is at his anyway. I have a wedding easter sunday but should be about for the rest of it. Thumbs Up
BillyJ
PostPosted: 01:20 - 07 Apr 2017    Post subject: Reply with quote
Very cool Thumbs Up
Reminds me of this guy
https://youtu.be/y2RYYBRFu1A
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
Baggyman
PostPosted: 09:00 - 07 Apr 2017    Post subject: Reply with quote
BillyJ wrote:
Very cool Thumbs Up
Check out "Forged in Fire" on one of the satellite channels - hillbillies, rednecks and sundry sophisticated muricans forging zombie killing blades out of scrap or cars or Abrams Tanks etc.
Plan to book a day in a forge and have a go at doing that at some point
Old fart
Baghira, modded GS1000 and the T150 I bought in 1978 when I was 21
The last post was made 9 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 95.35 Kb
