Author |
BikeRdean |
![](images/spacer.gif) BikeRdean L Plate Warrior
Joined: 06 Apr 2017 Karma : ![Good Karma (Level 1)](/images/karma/green_9.gif) ![Good Karma (Level 1)](/images/karma/green_1.gif)
Back to top |
You must be logged in to rate posts![](images/spacer.gif) |
![](templates/standard/images/spacer.gif) |
Isj0321 |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
![](images/spacer.gif) Isj0321 Two Stroke Sniffer
Joined: 04 Apr 2017 Karma : ![Good Karma (Level 3)](/images/karma/green_9.gif) ![Good Karma (Level 3)](/images/karma/green_9.gif) ![Good Karma (Level 3)](/images/karma/green_9.gif) ![Good Karma (Level 3)](/images/karma/green_1.gif)
Back to top |
Kickstart |
![](images/spacer.gif) Kickstart The Oracle
![](https://www.alfa-pages.co.uk/pictures/avatar00.gif)
Joined: 04 Feb 2002 Karma : ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 22:29 - 06 Apr 2017 Post subject: |
The front calipers are twin piston sliding calipers. The pins they slide on can seize, and the pistons can seize. Personally pump the pistons out (carefully as you want them to come out at the same time - at least for each pair on a caliper to come out at the same time). Take the seals out carefully. Clean up thoroughly behind the seals and clean the pistons thoroughly. Take the caliper off the pins it slides on. Clean them up and lube them. Reassemble the calipers (if you are at all unsure about the seals then replace them with new ones). Lube the seals with either brake fluid or red rubber rubber grease.
Rear caliper is probably the standard Suzuki nightmare. The pins that hold the pads seize in place. If you can get that out then pump the pistons out. With these you do have the option of pumping out the inner piston first, and pushing out the outer piston through the banjo bolt hole.
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
Back to top |
Nobby the Bastard |
![](images/spacer.gif) Nobby the Bastard Harley Gaydar
![](images/avatars/181183627654e6302043e79.jpg)
Joined: 16 Aug 2013 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_8.gif)
Back to top |
iooi |
![](images/spacer.gif) iooi Super Spammer
![](images/avatars/16548521854c0b6ee61064b.jpg)
Joined: 14 Jan 2007 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_6.gif)
Back to top |
Isj0321 |
Back to top |
Rogerborg |
![](images/spacer.gif) Rogerborg nimbA
![](images/avatars/8746860315b228070d9353.jpg)
Joined: 26 Oct 2010 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_6.gif)
Back to top |
Isj0321 |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 12:34 - 07 Apr 2017 Post subject: |
Rogerborg wrote: | Isj0321 wrote: | Grab two flat screw drivers, put them one at either end inbetween your pads. Push and pull/ lever the [dirty, corroded] piston into the caliper.. |
Good job. OP now has chewed up pads, and torn seals. Where is he sending the bill? |
He recieved free advice on an open forum, i gain nothing from giving my recommendation, he must assess the quality of the information for himself and take the best course of action taking into consideration his own skills and capabilities.
Are you telling me roger, that op has damaged his brakes? In which case he should have been more careful or better yet employ the services of a mechanic. I merely offered him a method which has worked for myself, a method which, most probably many bikers and mechanics have themselves made use of.
Are you offering any advice to the op or merely criticism of the completely free, measured, considered advice i offered? ____________________ Nothing worse than a cheesy penis |
Back to top |
Isj0321 |
Back to top |
Ste |
![](images/spacer.gif) Ste Not Work Safe
![](images/avatars/12289216435ee0c5ffddaaf.jpg)
Joined: 01 Sep 2002 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_1.gif)
Back to top |
Rogerborg |
Back to top |
Isj0321 |
Back to top |
Rogerborg |
Back to top |
Isj0321 |
Back to top |
Ste |
Back to top |
Isj0321 |
Back to top |
Rogerborg |
Back to top |
Isj0321 |
Back to top |
Isj0321 |
Back to top |
Rogerborg |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 13:02 - 07 Apr 2017 Post subject: |
Does your mother know you do this type of stuff? ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
Fizzoid |
![](images/spacer.gif) Fizzoid World Chat Champion
![](images/avatars/32872644557d139bf07c8b.png)
Joined: 06 Sep 2016 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_9.gif)
Back to top |
Isj0321 |
Back to top |
Nobby the Bastard |
Back to top |
Rogerborg |
Back to top |
Isj0321 |
Back to top |
![](/images/spider_left.gif) |
The last post was made 7 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
![](/images/spider_right.gif) |
