Where to start
shellshock
PostPosted: 21:20 - 05 Mar 2005    Post subject: Where to start Reply with quote
Ok, I am going to give my ZXR a spring clean next week, or rather my other half is, stripping it down , so that it looks like a very fugly bike.
What methods do you chaps and not so lazy gals use, and what products do you use/avoid?
Best way to use a jet wash ? Best method of cleaning a slightly rusty chain ?
etc etc.
Cheers in advance.
lurker
PostPosted: 00:53 - 06 Mar 2005    Post subject: Reply with quote
best way to use a jetwash:- unplugged
Seriously shortens the life of bearings etc, i know some will prob say theyre ok but ive had wheelbearings go well b4 there expected life after using one a couple of times.
Also theyre not really any good for much apart from rinsing the bike off after its had a good wash and they wont take any of the crud thats flung up by your wheels or chain off anyway.
As for the chain, soak it in parrafin and get scrubbing with an old toothbrush.
strag
PostPosted: 01:35 - 06 Mar 2005    Post subject: Reply with quote
I share my toothbrush with my chain...
carbon bling
Fruit'n'nut
PostPosted: 10:56 - 06 Mar 2005    Post subject: Re: Where to start Reply with quote
etc etc.
Firstly, to repeat some of the above - once you've removed all the body-work, get your chain off and leave it in an old washing-up bowl to soak in paraffin (available from B&Q if you've none in your garage.)
Give your plastics a wash with soap (car shampoo) and water; if there are any tar-like/greasy deposits in the belly-pan area, WD40 may help you get it shifted - either that, or scrubbing like mad with a sponge and brush Very Happy
(I wouldn't use a jet-wash personally, or even a hose.)
Dry off and polish - you can get silicon sprays, but I just (lightly) use normal furniture polish.
Going back to the chain, give it a scrub with a stiff brush to remove any muck/rust, then dry it off with some old rag. Don't refit it at this point; wash the rest of the bike first.
Wash the rest of the bike: you've got the body-work off so you can get into all the nooks and crannies. Soap'n'water for the lot, but try not to soak your electrics.
I towel my bike dry afterwards, then apply some WD40 to things like brake/clutch levers, brake pedal, gear selector, side-stand cut-out, pegs. I also thoroughly wipe my exhaust downpipes over with a rag soaked in WD40 after drying them (it will smoke a little the first time you start the bike up after doing this Shocked Very Happy )
Check things like: throttle-action - is it sticky or does it snap shut when you let go? Do your electrics work? - lights etc. Is your clutch dragging at all? (I'm trying to say it's an opportunity to do any little maintenance jobs while the fairing is off the bike Smile )
Refit your chain, fairing etc. When you reconnect your indicators, give the connector blocks a squirt of WD40, and apply copper-slip to any fairing/frame bolts.
Your chain needs lubing now. You could take the bike for a quick spin to warm the chain first, as this will help the lube work into the links. Try not to get lube on your tyres as you apply it, as it's slippery stuff Shocked Wink
Smile
Power Ranger Very Happy
distortion
PostPosted: 11:16 - 08 Mar 2005    Post subject: Reply with quote
well this is how its going, ive got about 40 pics but wont bore you with them all.
Distortion
distortion
PostPosted: 11:18 - 08 Mar 2005    Post subject: Reply with quote
now another piccy, this was before cleaning work started, is a slow process but well worth it in the end Thumbs Up
Distortion
p.s. - cheers 4 the advice ppl
PostPosted: 12:05 - 08 Mar 2005    Post subject: Reply with quote
Pressure washers are really bad for bearings and electrics, the solution is therefore just to not pressure wash and of your electrics or bearings.
Use a pressure washer and just don't point it into any of your electrics or bearings, using a pressure washer to clean the rest of the bike won't make some magical force destroy your bearings. Smile
The last post was made 21 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 54.38 Kb
