| nazK |
 nazK Two Stroke Sniffer
| nazK |
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
| nazK |
| nazK |
| Nobby the Bastard |
| Rogerborg |
 Rogerborg nimbA
| nazK |
| nazK |
 Posted: 19:06 - 29 Apr 2017 Post subject: Re: Honda CD125 Benley - Doe snot stay running? |
BENLY
doe this make you happy? Mr. internet spelling police ____________________ NEW TO BIKE MAINTENANCE- HAVE CD125 BENLY |
| jaffa90 |
 jaffa90 World Chat Champion
| Chris45 |
 Chris45 Nitrous Nuisance
 Posted: 19:13 - 29 Apr 2017 Post subject: |
Leave it for a few hours. Sounds like you've flooded the carbs.
Is the fuel tap in the Run or Res position?
If the battery has been discharged completely due to excessive cranking, you'll need to recharge it.
Alternatively, if there is a residual charge, i.e., ignition light - then try bump starting it. Get a pal (the wife will do) to push it as hard as possible, hold the clutch in, put it into 2nd gear and drop the clutch whilst opening the throttle.
Sometimes dealers say a bike has had a "recent service" when in fact it was twelve months ago, by the previous owner!
If the oil is really black and sooty it needs changing.
Don't blame Sooty  ____________________ Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS |
| nazK |
| nazK |
 Posted: 19:25 - 29 Apr 2017 Post subject: |
| Chris45 wrote: | Leave it for a few hours. Sounds like you've flooded the carbs.
Don't blame Sooty  |
here is what I am going to do
1) charge the battery
2) change the oil
3) asked girl friend to push it but she said she is saving it for later when our baby is due, so will get a pal
will let you guys know how it goes
but then again hat was my initial issue? ____________________ NEW TO BIKE MAINTENANCE- HAVE CD125 BENLY |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 19:48 - 29 Apr 2017 Post subject: |
First UP by the haynes manual - you are gong to need it.
Seconds.. the 1980's was quite a long time.... and saw the CD125 updated a few tmes, from a 6v points ignition motor, through to a 12v CDi igntion motor.. it also gained an electric self starter.... so narrow things down a bit... identify what you have... and DO NOT assume that because t says CB125 Benley on the side-panel and has a reg plate that has say a 'B' pre-fix issued in 1983, that that is the year the bike was made, or that the bike still has ANY of the bits it was fitted with in the factory, whenever it was allegedly built....
Next up, its an old bike..... t was probably first used legally on the road before I was, and I aint no spring chicken! It's got a log hstory, and little learner bikes tend not to fair well n the hands of know little learners; there s every liklihood that what you have, has been thrashed, crashed and trashed by more than a few owners, and between times been layed up derelict for long peroids to rust in pieces.... before this latest 'resusitaton' that doesn't eve make claims at any 'restoration'...... and done little but get t making motorbikie noises and a MOT man happy......
Cutting to the chase, I would, from my rather too extensive experience of these little motors lay odds on the fact that the motor is most likely in dire need of a thorough top-end over-haul.... From handy How2's in my profle; see " HOW2: Top End Rebuild Honda CB125 (Benley Motor)
It's actually not as major a mechanical melodrama as it looks, BUT it is the likely 'conclusion' to your pokings and proddings, ad IS likely to be a couple of hundred quid job, when you have got all the bts and tools to DIY.... if you try farming this out to a paid for mechanic, then, sorry, but the bike, as is is most likely beyond economical repair; you'd be better off punting to back on as is, to cut your losses, and sticking cash into something newer and more ride-away ready..... you have been warned.... make sure you are prepared for this before you start poking and prodding and hoping for the best... in ALL likelihood, all you will achieve is a lot of frustration of a bike that never does anything but play up, one way or another, waste a lot of time NOT making it much f any better, and spending a lot of money to avoid grasping the asty nettle along the way......
These bikes have TINY twin cylinder engines; each cylnder is barely the size of a mopeds, and expected to make twice the power a moped does.. not that it adds up to much at the end, a mere 10bhp in the case of the single carb benly engine... but t IS 'smooth'.... However; it has tiny pistons, a mere 43mm in diameter, with very very 'fine' piston rings, sittng in very narrow and very th grooves in the piston, ad those rngs have to be 'sharp' to hold compression and let the engine run right... they will wear out and cause poor running long before you observe significant cylinder wear, but that too wont help, nor will long periods of being laid-up, when the iron piston rings corrode in the alloy grooves and start to 'stick', and corrosion and crud n the oil gumms u the 'coil control rings' that spray oil on the cylinder wall and scrap t back off to keep the piston lubed..... IE they do NOT like being left to rust!
And comment that the seller said he changed the oil, but ts still black and tar like, doesn't bode well... Gven they take barely 1/2 a litre of cheapo oil, I wouldn't doubt that it has been changed recently... but see handy-how2's ad cleaning the oil strainer.. I doubt that has ever been done, and between old crud not flushed out with oil oil left settling for however many years, and some new use, with fire getting past knackered rings... yup, that would turn it tarry black pretty quick So I would not have too many hopes of avoiding a top end rebuild, TBH....!
IF IT WAS MINE..... first up would shelve any ambitions of riding it in much of a hurry... not that the Benly's like to hurry much to start with.... quick, they are not... a good CG125 push-rod single makes as much power and is lighter, and just as eager..... Benly is err... slow ad steady! like I said, its smooth and comfy, but 'spritely' it aint!... but I detract... were it mine, and plenty of good reasons it isnt' even though this does seem to be the place Little Honda Twins come to, like Lauds, in the hope of drinking from the fountain of youth, and re-living thier teen-dreams again.....were it mine!
1/ I would put any ambitions of ring in, i the immediate future out of my mind. Rushing be fast way to hurt when it comes to two wheels, and little different i the mechaics of'em.
2/ I would put little or no store in seller's claims or the worth of a fresh MOT cert... and I would start from scratch, givng t a thorough renovaton.....
See links in Profile I have done a few over the years, though most lately, and as far as Benly twins concerned on the slightly more spritely 125 Super-Dreams, that share the same basic engine
A-N-D the engine would not be the first thing I tackled..... Before you go, make sure you can stop! Then steer! Top of my list of priorties would be to check ad overhaul the brakes; these are, on the earlier Benly's quite nice cable operated drums, and as they use the same siz shes frot and rear, I would have the wheels off, and look for the old bodge of simply swapping shoes around to even out wear, and tightening the cable up, possibly even shimming the shes with old bake-bean tin to get a bit of extra bite..... Iroically, ew shes ad ew cable are remarkeably 'cheap' and not oo hard to 'do'... but before I spent that money, I would pull the tyres off, and check the state of the steel wheel rims and spokes.... steel rimmed wire spoke wheels rot from the side, and an MOT inspector cant look in there! It's also a diffcult or expensive job to rebuild wheels; new spokes and new rims are probably cheaper than tyres... which also beg attension... these thngs usally get pretty cruddy 'budget' ruber, that never wears out, but also seldom offers much grip.. even when new... and again, all the MOT man s concerned wth is whether there is legal tread depth or 'obvious' damage... crap old tyres can easily get through an MOT..... So those would be early targets on my to look at list, and long before the 'engine'..... especially as problems there can much more rapidly mount costs and make project even more BER.
Woking up from the floor, then, suspension and steerng would be next on the hit-list, and the head-race bearings would (again, see handy How2's!!) come n for scruitny. Bikes left drelct rust, and moisture in the steering arings collects around the balls, and rusts in 'pts' where they sit..... should make the steerig 'notchy' and MOT man should fail it...but very easy to drop the yokes, clean p the bearng racs with a bit of wet ad dry to smooth the pits a bit and fit new balls, to make it smooth eough to satisfy MOT man.... for the 20min of test.... after that, wear sees the bearing slack off, and the pits retrn, and steering likely horrble and fail the next MOT.... Modern 'taper roller bearings' are about £30 and I tend to ft them as a matter of course these days, rather than eff about with loose balls.... that, IF you replace the races, which s the problem part, is a bit, but not much cheaper...
Forks would the get stripped, stachions checked, and again, early Benleys had shrouds to 'hide' the bits that wear/rust, later ones usually given rubber gaters to do the same..... MOT man can't lift them, all he can do is check theres no oil leaks and there is 'some' damping effect.... So, I would strip and inspect the forks; and if the fork stanchons 'shot', like the wheel-rims, bike's probably BER and not worth wasting money on anything else... if not, new seals, new fork oil, careful rebuild... front end should be 'good'.
Back suspension is simple on a benly, ts a twinshock. It has two hinges on the swing-arm and two pogo-stick things either side. The shock-absorbers were ever great to start with; but the swing-arms do rot and the bushes do wear, ESPECIALLY on a bike that has been left to rust, and then pressed back into use with minimal attestation...... This would all get some attension and inspecton and f o more, strip clean and grease... but good bet new shock-absorbers would be very very worth-while.
That running gear, looked at, THEN, I might start looking at the fancy bits.... not that I would be in a hurry to 'pretty it up'... but the petrol tank is where engine work starts.... ad they again rot fro the inside, and again, as a matter of course, I gve them a POR15 lining treatment, as a precaution against so many presumed 'carb issues' where they such sludge flaking off the inside of the petrol tank! That would beg I look at the outside of the tank, and whether I would want to strip it to bare metal, and possibly patch any p-holes before lining and re-paintng, begging matchig to the side-panels ad other painted bits....
Handle-bar, switch gear, controls, and wirng, would all have to me messd with to do the headrace bearings and forks... so again, that would get some scrutiny.. early Benly's have loverly metal swtches and stuff, that can be wonderfully reconditioned with patience, sand-paper, and light oil... but is awkward and time-consumng... can make a bike a lot less trouble thogh... and beg followig through, going down the wires, looking at old corroded bullet conectors and conector blocks, cleaning making good and assemblug with lots of WD40.....
At that jucture I would probably also pay rather a lot of attesion to teh Starter solenoid... another wonderful bt of old fashoned engneering made with screws and bg bits of brass, that can likewise be stripped, cleaned, and reconditioned to aid potetial 'starting issues'...
These little engines have a 'self exited' ignition; that s they dont get sparks from the battery, they get sparks fro the magneto on the end of the crank; if they dont get spun up too fast by the battery, either 'cos that's a bit weak, or the solenoid is robbing volts, or the starter motor itself is rather tired, you will NOT get a decent spark, and all the 125 motors have a high compression ratio, so NEED a decent spark...
So, working down, after looking at the soleboid, I would pull, strip and recondition the starter motor; again, old fashoned screws and big chunks of metal, t is eminently reconditionable, and some elbos grase, LM grease and some new brushes (about £10 fro DSS_ will do wonders.... THEN I might worry about a ew battery... and I would not take seller's word about how good an unknown one may be for the sake of £20 and SO much potential frustrtion.....
Whlst in that vicinity, I would probably have many ideas to 'upgrade' the elevtrcs and fit better lights and 'stuff'' would try and rein in... make as good as standard before tryng to make etter tha standard.... BUT if it wasn't a 12v CDI system, I WOULD be sorely tempted to upgrade to that later standard, whilst I was faffing..... other than that, only 'mod' I would recomend is chucking away the old fashioned electro-mechanical indicator flasher, that has a habt of fllling with water and fitting a sold state electronic one....
That would beg I start prodding and poing indicators, cleaning contacts, replacing seals, and looking atthe headlap and teh spaghett situation in there....
THEN..... after pondering gitio swtch and petrol cap 'sets' to finish off those detaol jobs.... I MIGHT be ready to start looking at the motor.....
And as said, were it me, wouldn't look too hard.... I would like as not cut to the chase, haul the engine out, pull the head and barels off it, and do full top end rebuild, with a £120 barell kit of e-bay... new cylinders, new pistons, new rigs.... and as part of fitting, would beg that the cam-haft be accurately timed in, and the tappets correctly set, and whilst I was in there, I'd almost certainly strip the head, clean and lap the valves, to the seats, and replace the stem-seals.
So rebuilt, likely that engie would start, run and deliver it's all, and ot give a heart-beat's trouble there-after, for the sake of puttng i the time, effort and moey upfront for graspng the nettle..... provided I pay some attension to the exhausts and exhaust gaskets when put back n the frame......
A-N-D... I could take a bike from a derelict or scrub-up, like that, and do all that, ad probably have the thing up ad running and running very sweetly, in ooooh.... maybe a month? IF I was really keen.. more likely two, proably three,,, but realistically.... six-month to a year to almost never... (I have 'done' three, and have two work in progress, from the last seven years, in which my 750, 'err nibs 750 and the yellow one, all vied for Project D'Jour, honours!)
WHICH is back to that warning....... how optimist / naively hopeful are you?
IF you don't want to grasp that nettle... you can spend an awful lot of time poking and prodding and meddling i the margins, getting into a confusion of conflicting symptoms, never really storting ANY.....
Without grasping the nettle; hoping for the best, first thing I would do s pt a compression tester on the thing..... I have a pretty sophistcated one, that has all the adaptors I need to work on these little engine's with thier tiny cylinder heads and spark-plugs..... as they have a tiny 62cc cylinder, and a 6cc combuston chamber though, it's still not all that accurate, a push-in type car compression tester leaving the volume of the spark-plug threads, to add to the tiny combustion chamber, will tend to make a mockery of any reading you get from such a device... you'd be as well off using the old rule of 'thumb'... can you hold your thumb over the hole whilst you crank!
But, I would want some sort of confidence that the motor had healthy compression... as it stands I don't.... ad cost of buying tool to find out or paying some-one to tell me that bad news... I'd be 1/3 the way to buying a new barel kt and making the question redundant!
Whilst I had the plugs out, I would be comparg them to the pictures in the Haynes manual; fro described symptoms, of motor starting then cutting out, I would not be at all suprised if they weren't sooting up, either from too much choke being used, or ore likely burning oil....
Black shitty plgs and little compression, I probably wouldn't even other more poking... I'd be on e-bay looking for a barel kit..... but to percevere....
With some compression and a not too bad plug.... These little motors like to e spun up well to get going, and stay goig... it starts, which is a start, ad doesn't say that the battery/solenoid/starter are immediate issues... but as above they dont help if they are at all lazy..... So assuming they aren't too bad for now...
Basic service procedures of tappet adjustment and cam-chain tensioner adjustment are oft neglected, ignored or just plai cocked u on these bikes.... back to the handy-how2's... follow instructions there and the Haynes, and gve yourself the best chance of it all working as it should...
I would lookat the carb.... the floats on the do have a tendancy to stck, and fiddle fingers have a habit of screwing up teh settings.... they work wonderfully at the 'book'recmendations, though... so I'd stck the needle height back to that, I'd set the pilot air screw bak to that and then wind out the idle screw, and use the throttle to try ad keep it alive and find a settg where it will 'idle' and ot conk out... all when warm enough it dot need 'choke'..... good gayme... good gayme....
They are also a single carb on a branch manifold, with a heat insuator block between the head and the manifold to top engine heat boling fuel in the carb..... This is often omited during re-assembly or is cracked, or not sealing with new gaskets where needed or piched 'O-rngs either on the manifold or carb......
Carb would probably come apart in my hands, and be treated to new needle, new float needle, new jets, new pilot air screw and new gaskets, as well as thorough clean, to make good in this area... when I cant get it to 'idle' and stay alive......
Not that t would make much difference, and have me scratchig my head over the state of exhausts and exhaust gaskets... and back up the pipes at the fel pipe, ditch any after-market 'in-line' fuel filter, looking at the fuel tap, and the straier on the top, in the tak, and pondering that POR15 liner treatments......
And goig around the loop, probably lookig for other falorn hope 'problems' to avoid the nettle and a top end rebuild, and probably wastig more time and ffort and possibly money too, in the doing......
Which is why I cut to the chase and do Top-End rebuilds 'as course', same as lining petrol tanks!!!
BUT.... that's your call... like I said, I SUSPECT that this is no cheap and easy two minute fix, twiddling a screw or swapping a filter..... you might get some iprovement f you fiddle in the rght places, but big risk that fiddling wll make more problems than it solves, and the long and the short of it will come back to biting the bullet and doing that full top-end rebuld.....
And, Have't mentioned, IF it s an earlier 6v poits system.... then sparks can drop ot as they get warm when old condesners start to get warm and workig 'randomly'.... IF its a ponts ignition model, then as course I would replace both points AND the condenser as imediete precaution against ignition anomolies......
But otherwise; sticking your finger n the wind, and asking for suggestions.... there are possibly hundreds..... BUT.... my experience with these little motors, and I have rebuilt half a dozen of the chuffing things i recent years... do yourself a favour, ct to the chase, do a top ed rebuild, and make the motor as good as you can, before you start meddling round the margins.... but before you do THAT... make sure that the rest of the thing is worth ANY time and attension at all.... they are ot and will never be very valuable bikes, and what it's likely to cost to make one 'good' ad even notioally everyday reliably rideable, will be chasig the sort of money you can go buy a five or six year old, if ot newer YBR125, with just as much performance, and likely a lot less problems, if not so much 'charecter'.... or character building 'frustration'... So think LONG and hard about advice at the top, before you go much further, IF this bike is worth the effort...
There aren'tmany folk aroud as daft as I am... you MAY be in that minority, and find it all 'fun'... if so welcome to the club... there's no hope for you, seek psyciatric assistance at the earliest oportunity!!!! Otherwise... go see how 'cheap' good, road-worthy, runig YBR's may be procured for these days.... And see Snowie's Pup-Block of our marathon 'good as new' renovation of her 125 Super-Dream that cost as much or ore than a brand new YBR....... UNLESS you actually enjoy getting your hands dirty and playing spaners, this bike, I'm sorry to say, here ad ow, is likely to prove much more trouble than it'll ever be worth, either in cold hard £'s on the open market, or the functional value of riding the thing for the few miles it lets you for all the time, money and effort you invest it..... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:01 - 29 Apr 2017 Post subject: |
Mea culpa.
I'm so, so sorry.  ____________________ Biking is 1/20th as dangerous as horse riding.
| Nobby the Bastard |
 Posted: 20:03 - 29 Apr 2017 Post subject: |
Fuck me ragged, tef, that was excessive even by your standards. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| nazK |
| Rogerborg |
 Rogerborg nimbA
| WD Forte |
 WD Forte World Chat Champion
| jaffa90 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 05:10 - 30 Apr 2017 Post subject: |
| nazK wrote: | My bike is Honda CD 125 TC Benly 1984
You mentioned CD but later called CB in your quote above, does your reply and the other link still apply in my case? |
Of the countless typo's in that lot, you pick on that one? YEs, it makes no difference.
This series of Benly 'twin' engine came along around 1976/77; the CD-Benly was a 'mini-tourer' (lol!), the CB125 'sports' was a derivative, as was the CM125 'cruiser'. All were basically based on the same 'bits', just dressed out differently to suit different style.
Most significant difference was that the CB125T, 'sports' got a different cam and crank; on the CD & CM the pistons in both cylinders go up and down at the same time; (360 degree timed) four strokes, suck, squash, bang, blow; so on the CD/CM one cylinder is on the suck stroke, whilst the other is on the bang. On the CB motor, one piston is up, whilst the other is down, (180 degree timed) so one piston is three strokes behind, or one stroke ahead of the other.....
360 timing, makes it sound more like a old Brit Twin.... and vibrate like one..... on the old Brit-twins, it could also save a middle crank bearing, they used a crank like a single, just with a longer crank-pin. Also allows a single trigger 'lost spark' ignition, like a single, so they are cheaper t make and easier to set up.
180 timing, is a bit more complicated; and begs a better supported and more complicated to make 3-main bearing crank, and twin trigger, 'duplex' ignition, a separate circuit for each cylinder, so t's a bit more involved and expensive to make and set up... but, with the wight of one piston coming down, counter-balancing the piston going up, it helps them be a bit less vibratory, whilst the extra crank bearing they usually have will help stop them shakig themselves to bits quite so quick, as the Big Brit-Twins like Bonavilles or BSA's were prone to, if tuned...
Which is why Honda did it, for the 'sporty' model... not that a 125, especially a 125 twin should ever have that much mass wizzing up and down, or make enough power to do itself too much harm... B-U-T... Sochiro Honda hated two-strokes with a passion, and wanted to prove they could build a four-stroke every bit as powerful as two-stroke competition....
So to make the CB125T, his engineers 'tuned the bolloks' off the otherwise rather 'sedate' Benly motor, and in an era when 10,000 rpm was audacious for a four-cylinder engine, and few twins ever reved much over 7K, and singles probably not much over 6k if that..... they encouraged the little Benly motor to rev to over 14,000rpm.... through two tiny valves per cylinder, and make 17bhp or 135bhp per liter.... which is still, what, forty years on, 'impressive' for a two-valve air-cooled engine in a production bike.... and still more than just about any four-stroke production 125 road bike..... now they are all built to meet the 14.5bhp limit of European A1 licence regs....
At the end of the day, all a little futile... The 125 'Twin' was built to answer the criticism's that the Over-Head-Cam CB125 'Single' that made a pretty respectable 13bhp, was a little fragile.... that engine soldiored on, in the 'street scrambler' CL variant for a while, to become the XL125 engine, that was used a whole ruck of little bikes right up until the SL125 'Cty Fly' until quite recently, and could, even de-tuned some, for better reliability deliver a pretty healthy 12bhp or so...
Meanwhile, for develop markets, where the two-strokes low, and 'easy' maintenance were more important than their hi-performance, a parallel development project saw the CB125 'single' re-engineered with low-tech, low maintenance push-rod valve actuation, to produce the CG125... which, encouraged to rev to a petty impressive 10,000 rpm, managed 10bhp.. rather making the merits of the twins a little dubious.. espcially the more concervatvely tuned CM & CD, which on a single carb, didn't really deliver very much more oomph for it all....
They are however smooth, aided by extra weight in the bike, and the power delivery is too, and they will pick-up from a wiff of throttle from very low revs a lot less jerkily than the singles will; they 'trickle' wonderfully in traffic or through CBT cones.... and the single carb versions are remarkably miserly on fuel, probably because they don't particularly urge you to thrash them very much very often!!
As said the little twins all have 'character'... the more sporty CB125 has that little bit more oomph about it; and that extended rev-range, that can be quite intoxicating, un-muted by a water-jacket.... the sigle carb variants are just wonderfully 'refined' for a little bike, and so 'smooth', not snatching or jerking ad reving out like a turbine without any great drama or harshness....
But? As every day utlity transport? They are old!!! They are old tech, and practically they dot do a heck of a lot any other 125 might, or do it any better... and they take a LOT of nursing to get what they do have... and if they are a bit sick? There's a LOT more 'bits' in there to beg attention.
For any of them to be worth that attention, you have to have a pretty masochistic mind-set, and mechanical sympathy, AND appreciate the pretty small virtues, including their 'classic' appeal, a awful lot....
Sensibly? If you don't mind giving a bike that sort of spanner attention, much as I say if you know enough to live with one, you'd never buy one; a Chinese CG derivatve, like a Lexmoto Nevada, is probably as or more every day viable proposition!!! It'll still beg a lot of looking after, but thirty years or more younger, and with half the cylinders to worry about, it's a lot less likely to find SO many ways to beg time with the spaners, or cause as much consternation when it does... and t will STILL go just as fast ad sup as little fuel!
So that gives you a pair of bench-marks to weigh the value of your CD by., at one end, a reletvely new YBR, that's boring but easy to live with... or a 2nd hand Lexmoto, that's 'cheap', slow and likely to be 'hassle'; which on quids-per-go... are both likely to offer as much or ore real world ride time for your time and money...
How much is the genuine, we kid ourselves 'old' means 'classis' cudos worth? How much, if and when you get it, is the 'smooth and soft' nature of the twin, over a single; really worth, in time, hassle, frustration,and cold hard pound notes?
THIS is why there aren't many CB/CD/CM125's still knocking about on the roads.... ad so many are hidden away in sheds left derelict, or some-times, maybe, never 'projects' being 'restord' or turned into geeknick cafe-scrambler bike-shed wannabee fantacies... pobably never to turn a wheel in anger again....
Think long and hard what you want out of a bike, and whether, all told, the old CM has any hope of doing that... and if it does... how much you will have to put in up-front to get it, and in ongoing maintenance along the way....
Seriously, the here and now you have to face is, that; AND trying to 'tickle' it into action, and coax it into doing what you hope, is likely to cost you time and money, for little real gain, and just forstall the inevitable "I GIVE UP!" that is a route to a LOT of frustration and bother, with a lot of risk of spending lots of money to at best make things no better, more likely make and find more problems than you solve, and have something even harder to shift on for it when you do give up... so better to cut your losses now, and ether punt it back on, as a bad job, and be a bit more clued up ad prudent in your next purchase, OR, bite the bullet, treat it as a 'project'; start not with the obvious niggles, but where the bite you in the bum ones lurk, and tackle the whole thing, so as to avoid chucking money and effort to be wasted when a bum-biter rears its ugly... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| nazK |
 Posted: 08:23 - 30 Apr 2017 Post subject: |
@Teff Thanks mate, I am going to waste time, money and energy on it. I will learn something new and not to forget make friends here on the forum or to least get some banter out of it which has already started
I will need a lot of help from you and other senior members when it becomes a project after I get it pass this start/stay on issue to some degree
I bought the bike because I like it and yeah I could have bought a newer or Chinese bike but where is the fun or character in that..
every man has his tipping point, mine will be tested by her:)
@All: A friend of mine is going to lend me the charger, ordered manual on ebay and looking to buy owner's toolkit..
the battery seems a bit alive this morning after it went flat and gave relay ticking noise yesterday. Didn't know they are self charged while idle Back to square one, tried again which I should not have but could not help, it turned over but did not stay on same like when i first tried when delivered...
Now will not touch it until battery is charged and have the manual on me. ____________________ NEW TO BIKE MAINTENANCE- HAVE CD125 BENLY |
| nazK |
 Posted: 09:58 - 30 Apr 2017 Post subject: |
The last post was made 9 years, 197 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.13 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 166.04 Kb
