| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
 Posted: 20:23 - 01 May 2017 Post subject: Counter shaft threads knackered |
I recently bought a FZS600, was hoping that it wouldn't have a welded sprocket, it didn't but I have now found out that the threads have been stripped on the shaft, and the new nut will tighten a small amount, then become loose again.
https://i.imgur.com/HjwmgY3.jpg
I'm leaning towards installing a new set of chain and sprockets and getting the nut welded to the shaft by a garage, unless the threads can be re-threaded?
I'm not going to replace the shaft as it seems pointless if I can just grind the weld off and re-weld when the need arises?
Would a few tac welds suffice just to hold the nut on? ____________________ DRZ400-SM
FZS600 |
| Pete. |
 Pete. Super Spammer
 Posted: 20:28 - 01 May 2017 Post subject: |
Simple answer: yes. Tack-welding the nut to the shaft would cause it to act as a sprocket retainer. It's an almighty bodge but not as much as if you tried to weld to the sprocket directly.
Apart from that, those threads don't look so bad. I would bet that the most of the damage is in the nut threads, and a new nut would work on those shaft threads without resorting to weld-bodgery. ____________________ a.k.a 'Geri'
| DRZ4Hunned |
 Posted: 21:10 - 01 May 2017 Post subject: |
Cheers Pete,
I have actually tried a new nut and it does the same thing? I'd read that the nuts were made of a softer material than the shaft, so it strips the threads in the nut, rather than the shaft.
I'll go to my local garage tomorrow and see if they can help weld it.  ____________________ DRZ400-SM
FZS600 |
| Paulf |
 Paulf Nova Slayer
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| Raffles |
 Raffles World Chat Champion
| Pete. |
 Pete. Super Spammer
| P.addy |
 P.addy Red Rocket
| DRZ4Hunned |
| skatefreak |
 skatefreak World Chat Champion
| DRZ4Hunned |
 Posted: 10:17 - 02 May 2017 Post subject: |
I've just found this, interesting idea:
https://foc-u.co.uk/index.php?action=downloads;sa=downfile&id=43
How would this compare to drilling through the nut/shaft/nut and putting split pin through?
No idea how hard it would be to drill through these hardened shafts with HSS drill bits. ____________________ DRZ400-SM
FZS600 |
| DRZ4Hunned |
 Posted: 18:01 - 10 May 2017 Post subject: |
So I've got this far... 15mm Circlip on like what was done in that PDF. Does the circlip look seated correctly here?
https://i.imgur.com/GCeYmly.jpg
Also, tried drilling the shaft with a Bosch HSS drill, wouldn't even touch it. Do I need to get something like a cobalt bit? ____________________ DRZ400-SM
FZS600 |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| DRZ4Hunned |
| zark |
 zark Trackday Trickster
| DRZ4Hunned |
| zark |
| DRZ4Hunned |
| zark |
 Posted: 20:55 - 10 May 2017 Post subject: |
Now you've started the groove, slide the sprocket off so you're just working on the spinning shaft? But yeah, not much to play with...
How much sideways force will there be typically anyway?  ____________________ CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou... |
| Pete. |
 Pete. Super Spammer
 Posted: 10:46 - 11 May 2017 Post subject: |
If you can cut a grove in the shaft with a hacksaw you can drill a hole in it with a decent drill. ____________________ a.k.a 'Geri'
| DRZ4Hunned |
| DRZ4Hunned |
 Posted: 18:22 - 13 May 2017 Post subject: |
No luck with the cobalt bit either
Anything else to suggest?
How likely am I to potato myself with only using the circlip?  ____________________ DRZ400-SM
FZS600 |
| kramdra |
 kramdra World Chat Champion
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| DRZ4Hunned |
The last post was made 8 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
