model airbrush kit help?
Hahadumball
PostPosted: 20:19 - 03 May 2017    Post subject: model airbrush kit help? Reply with quote
a fair while ago i purchased a model airbrush kit and compressor..
today i decided to go grab some paint and thinners and have a practice on shit
mixed acrylic and thinners at 2:1 put into the pot and had a go but it was sporadic and hardly anything came out had major issues..
changed pot to a gravity fed pot and still the same if not worse..
went 3:1 thinning and no change
tried a different needle as it had an extra in the box but no change still.
eventually thinned it mega loads to get the same as before.
tried loads of air and tried hardly any air but still not a consistent spray thats usable, it doesnt work more often that it does.
any help on how to start?
https://i.imgur.com/pLlH3Y5.jpg
https://i.imgur.com/JXIcoru.jpg
https://i.imgur.com/LRrqJoV.jpg
tried with these
https://www.theatermakeup.de/item/images/1002034/1200x1200/Airbrush-Glas-Farb-Becher-34141-1002034.jpg
and the metal pot like in this pic
https://2.bp.blogspot.com/-F5TptE88wi8/TdtVileXOTI/AAAAAAAAB1M/0iCcHxYw4qA/s320/gravitylrg.gif
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Nobby the Bastard
Harley Gaydar
PostPosted: 20:29 - 03 May 2017    Post subject: Reply with quote
You spelt your name wrong....
https://www.imdb.com/title/tt0097742/fullcredits
Triumph Sprint ST 1050
PostPosted: 20:38 - 03 May 2017    Post subject: Reply with quote
Nobby the Bastard wrote:
spelt
https://i.imgur.com/v7grFRl.jpg
Nobby the Bastard
Harley Gaydar
PostPosted: 20:50 - 03 May 2017    Post subject: Reply with quote
spelt
My apologies. I'll blame the aphasia...
Edit:
https://grammarist.com/spelling/spelled-spelt/
Hahadumball
PostPosted: 21:00 - 03 May 2017    Post subject: Reply with quote
keep up that talk of working please ashley, more you work the more benefits i receive Wink jokes on you son
Wonko The Sane
PostPosted: 21:48 - 03 May 2017    Post subject: Reply with quote
Is the airbrush dual action or single?
Single action is where you press down and the air and paint both flow at once,
Dual action is where you press down to start airflow and pull back (while pushing down) to get paint to flow.
Setting up the air pressure is a big part of getting things right, or so I recall. I was using ink last time I was airbrushing so can't comment on paint thinning.
Hahadumball
PostPosted: 21:50 - 03 May 2017    Post subject: Reply with quote
its a dual action sorry should have mentioned that
Shaft
PostPosted: 23:46 - 03 May 2017    Post subject: Reply with quote
Not having bought either since the last time I was learning to use an airbrush (nearly 40 years ago) things may have changed, but ink was considered the ideal medium for learning, as you got more for your money and it's water soluble and it's much easier to clean when you're finished.
And there's the clue - I think Tamiya water soluble acrylics used to recommend up to 50:50 thinning for spraying.
Get the paint mix right so it consistently flows, then play around with the pressure until it doesn't bounce off the surface you're painting.
A single action brush is much easier to learn with (and much cheaper) as there are less variables.
Revell used to do a really cheap single action, perfect for the novice to play around with paint mixing and technique.
linuxyeti
PostPosted: 07:30 - 04 May 2017    Post subject: Reply with quote
You want to get the mix to roughly the same consistency as milk
Beware what photos you upload, or link to on here, especially if you have family members on them
Hetzer
PostPosted: 08:06 - 04 May 2017    Post subject: Reply with quote
Do you get air coming out the tip when you run it without paint?
PostPosted: 08:13 - 04 May 2017    Post subject: Reply with quote
I didn't say it was wrong, I'm just shilling for Big Wheat.
+1 to does it even blow when it's dry?
Hahadumball
PostPosted: 18:24 - 04 May 2017    Post subject: Reply with quote
i do, it works fine without paint and with paint i get random squirts here and there
Nobby the Bastard
Harley Gaydar
PostPosted: 18:33 - 04 May 2017    Post subject: Reply with quote
Prostate trouble?
AngelGrinder
PostPosted: 21:16 - 04 May 2017    Post subject: Reply with quote
It's all trial and error really, there's Alot of variables to work out, but once you get there it will click eventually.
Make sure your needle is always clean.
Make sure your paint is good enough for airbrushes, there are some specific airbrush paints like the Vallejo line. Use thinners rather than water, as it doesn't dry so quickly and clog the nozzle and needle.
Hahadumball
PostPosted: 17:16 - 05 May 2017    Post subject: Reply with quote
i shall have another go not holding out much hope
ZRX61
Victor Meldrew
PostPosted: 01:47 - 08 May 2017    Post subject: Reply with quote
Did you disassemble & inspect it before you started to make sure it was all as it should be?
They're not one night stands, they're auditions.
Stephenniall
PostPosted: 19:41 - 08 May 2017    Post subject: Reply with quote
Put some water in it & check your spray pattern on a piece of paper, I usually use about 15-20 psi with my Iwata airbrush.
If it sprays nicely with water you need thinner paint/higher pressure.
duhawkz
PostPosted: 21:12 - 08 May 2017    Post subject: Reply with quote
Getting pol to take anything apart will only ensure it will never work as it should.
PostPosted: 09:45 - 09 May 2017    Post subject: Reply with quote
Hiya
What thinners are you using? Just checking you are not using one intended for enamels.
Which acrylic paints are you using? I find the Tamiya ones work best (for me) in the airbrush (although I find them useless with a paint brush). Acrylics do tend to dry quickly and clog up the airbrush rapidly. It is worth stripping the very thoroughly cleaning the airbrush on a regular basis.
Al the best
Katy
Hetzer
PostPosted: 08:54 - 13 May 2017    Post subject: Reply with quote
Try it with nothing but water next.
If it works ok with water it means you're fucking up the paint mix.
One has to assume you're cleaning it after you've tried to run it with paint, otherwise it would still be blocked when you try it with only air (presumably with the paint-cup attached?). Does the paint-cup have a lid? Edit, I see from the pic it does. Run it with the lid OFF.
What are you finding when you clean it? How are you cleaning it?
The last post was made 9 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 119.13 Kb
